Question about HP Photosmart R707 Digital Camera
HP R707 wont take pictures - get F2.8 1/60 message
When I press the shutter button, nothing happens. If I press and hold it for about 5 seconds it displays F2.8 1/60 on the bottom of the screen. Before this happened it was slow to take the pictures. You had to press often before it would take the pic.
This problem showed up shortly after changing batteries. Could it be a software glitch? I have reset the process to no avail.
Everything else seems works OK.
Any suggestions?
Jeff
  • 43 Answers
Does it work while connected to charger? If yes, you need a new battery.
Posted on Jan 29, 2010
Mi camera digital Nikon D 60 got a messaje: ERROR PRESS SHUTTER RELEASE BUTTON AGAIN Cant anyvary help me to fix it
It is nothing to lose to try this:
1. Remove the battery (the charged and good working battery),
2. Switch the power to ON position,
3. Press the shutter button for 5 seconds.
4. Switch the power to OFF position,
5. Insert the battery,
6. Switch the power to ON position,
7. Try to take a picture.
Please post the result here.
Mar 03, 2014 | Cameras
The camera went blank and I changed the batteries and now the lens is stuck half open and the camera does not work
Same thing happened to mine. Here is one fix.
Remove battery and any memory card. Then press the on/off AND shutter buttons at same time several times. Reinstall battery or plug into wall and it should work again. JUST fixed mine today. Good luck. Henry
Dec 25, 2010 | HP Photosmart R707 Digital Camera
Hp 537 photosmart camera. my picture is frozen. i can,t access my previous pictures nor take any other picture. camera will flash but no new pictre is shown. please help.
Try to reset the camera - take out the battery then push the reset button with a straightened end of a paper clip. Hold the reset switch depressed for about 3 seconds. Reinsert the battery.
Sep 28, 2009 | HP Photosmart R707 Digital Camera
Kodak DX 7440 Won't Take Pictures
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...thank u!!!
rate me!!
May 27, 2009 | Kodak EasyShare DX7440 Digital Camera
No power after dropping it accidentally...
try pushing the reset button by the battery slot, use a paper clip and hold for 5 seconds without the battery in it. good luck
May 10, 2009 | HP Photosmart R707 Digital Camera
Everything works....but hit shutter button & it goes dead.
Hold the power button in the ON position for 10 seconds, then release (obviously making sure the batteries are in first). This forces the camera to do a full reset - you will have to set the time etc when it restarts.
Hope this helps, it worked for me...
Nov 23, 2008 | HP Photosmart R707 Digital Camera
Shutter not closing when taking photo
Try to take video or take picture in dark conditions. If video records correctly, then the CCD sensor is broken. Contact HP and ask if they would repair it for free.
Nov 07, 2008 | HP Photosmart R707 Digital Camera
Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
Sep 08, 2008 | Nikon D40x Digital Camera
Menory card unreadable etc.
ok check the card slot for the memory card the pins are bent... for shore
Sep 03, 2008 | HP Photosmart R707 Digital Camera
No picture taken when shutter release is pressed
if you see no reation of the pressing of the button i.e. no focusing, no error message nothing , then most probably a simplest problem , the shutter release button may not be working for few reasons : 1) defective switch. 2) defective flex cable. 3) camera exposed to some physical jerk or dropping resulting into disalingment between inner switch and the shutter release button.
Jul 09, 2006 | Fuji FinePix S5500 Digital Camera
HP Photosmart R707 Digital Camera Logo
60 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
