Question about GE 29385GE1 Corded Phone
The phone only rings twice and then stops.
How can I set the phone to ring six or seven times before it stops?
I have tried to use the menu to set it and it still only rings twice!
  • May 11, 2010
    What model phone so you have? This question is posted under a GE model which is not an answering machine, and has no programming for ring count.
  • 201 Answers
SOURCE: Intermittent Ring
Sounds like you are having a problem with the generated ring signal from the cable phone service. An old fashioned Ma-Bell ring signal is a pure 90v AC 30hz pulse. Your cable box needs to generate a simulated ring signal from a DC power supply. I have seen many examples of this fake ring signal not cooperating with specific phones. It's a long shot but your phones MAY have a setting for the phone line(s) (A/B) (Analog/Digital) etc... of you can find a setting dealing with the "CO line", "phone line" etc.. try changing it. I am surprised another phone in the loop will help the ring signal at all. I would think it could only weaken it. Try plugging your phone in question directly into the cable line instead of having the whole house connected. The ring signal may be trying to power too many devices or weakened by something connected to the network. Other than that, you are dealing with the ring signal generated by the equipment and I'm sure it's not adjustable.
Posted on Jul 07, 2007
  • 84 Answers
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Posted on Feb 14, 2008
SOURCE: Model 26990GE1-D
how do i change the anwering machine from spanish to english?
Posted on Feb 27, 2008
SOURCE: number of rings
I want the quik guide and the manuel instructions to activate in french sorry for my english,rivardsonia@videotron.ca
Posted on Sep 26, 2008
SOURCE: phone not working properly
my answering machine keeps syaing that you can not leave a message at this time but i set it up can you help me
Posted on Oct 10, 2008
How do I increase the number of rings on my Uniden DECT 1715 series cordless phone. It rings twice and then stops.
press menu, go to answering set up find ring time press menu adjust the number of rings press menu then exit button
all explained in the user manual
Dec 02, 2017 | Uniden Lands Phones
Does anybody know how to increase the number of rings on my dect1735 phone it only rings 3 times and goes to message bank.
press menu
select answering set up move to rung time select menu add ring time press menu and then press exit to save
Nov 18, 2017 | Lands Phones
Our phone rings only twice and then goes to the answering machine. How do I change the number of rings to 4 or 5. I lost the Uniden user manual.
With the phone in standby mode, press the menu/clock key three times.
You hear "Ring time" and the current ring time, and it is displayed on the main base. Then you hear the guidance for setting the ring time.
Press the volume/select-up-down until the desired setting appears.
Press the set key.
Full instructions are in the "Setting the Ring Time" section of the manual (page 36 in my copy). If you need a manual, you can download a copy at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DXAI5588-2om.pdf
Sep 16, 2011 | Uniden DXA15588-2 Twin Cordless Phone
How do I increase the rings before message answers?
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
thanks
Jul 01, 2010 | GE 28112EE2 Cordless Phone
Would like to increase number of rings before answering machine comes on.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Unwanted daily phone ring
is this a call ?
or do you have the alarm set on the phone for 7.30am. to ring ?
riz.
May 11, 2008 | Motorola Mobility W375 Cellular Phone
Ring times
I know the time before transfer is programmed by the installer, but you MAY be able to set that CALL TRANSFER TIME in your particular mailbox. Listen to ALL the menu prompts.
Apr 02, 2008 | Panasonic KX-T7630 Corded Phone
Number of rings
Looks like 6 is the Max, according to the Manual.
Ring Time allows you to set the number of rings the caller hears before your
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
3) Press the OK soft key. You will hear a confirmation tone.
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
Canon MF 3200 Series
There should be a setting, most likely under advanced fax settings that is called Rings To Answer. That normally can be adjusted from one to seven rings.
Feb 25, 2008 | Office Equipment & Supplies
GE 29385GE1 Corded Phone Logo
376 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
