Back to:
Tags:
FMI Ram Memory Cooling Kit Memory Cooler
CompUSA RAM Memory Cooling Kits
By Joey2 - usenet poster
Has anyone tried the "CompUSA" Ram cooling Kits, SKU #291979. The
instructions are on the back but sorta confusing & it looks like the
local store techs are also confused about the instructions. The
advertisement online states they are manufactured by FMI. Searching the
net I think its Fujitsu.
Tyronne
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Rogers
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks, You answered my question! That "spacer" really thru me off.
After checking out the Thermaltake site & one of their memory cooling
kits, I came to the same conclusion about single sided memory.
Tyronne
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on CompUSA RAM Memory Cooling Kits:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Gary10
Rating: 0%, 0 votes
I recall being confused by the instructions myself and so was the clerk. My
recollection is there was a part, a piece of double-sided tape I think, that
was not addressed in the instructions. I can't locate that part at the site
to verify this but I think I concluded that the sink was designed for
double-sided memory. In that case, they probably intended for the extra
tape to act as a spacer on the unpopulated side of a single-sided stick.
The spacer would be necessary for a proper fit.
Some manufacturers will void the warranty for adding a cooler. In my case,
I ran a test to see if ram overheating was causing a problem and it was not
so I did not buy the device.
Thank You!
Solution #3
Not Rated (0)
kioner
Rating: 0%, 0 votes
Thanks for the Info! If I don't find the instructions needed, It'll go
on my shelf to disappear along with the other stuff I never use.
Hopefully these will never become obsolete.
Tyronne
Thank You!
Solution #4
Not Rated (0)
lawyer
Rating: 0%, 0 votes
test
"callsignviper" <callsignviper-r-e_m_o-v-e_t_ message ...
Thank You!
Solution #5
Not Rated (0)
pandamama
Rating: 0%, 0 votes
I would be very surprised if Fujitsu had lowered themselves to CompUSA's
level.
That "FMI" name is used as the manufacturer for CompUSA branded products all
the way from keyboards to power supplies and everything in between. I can
guess that they buy in large quantities from many manufacturers who are
willing to provide CompUSA labeling for a nominal increase in the cost of
the product.
The ram cooling kit looks very similar to a Thermaltake product. You might
check the Thermaltake website and compare the two and then go from there.
callsignviper
The truth is out there. You just have look in the right places and ask the
right questions.
Thank You!
Can you Help with these System Cooling problems?
System Cooling
i am tryin to install microsoft office but the system...
System Cooling
n?o consigo configurar o outlook no meu pc atravez do meu...
System Cooling
i face the problem about driver bcos my driver are out of...
System Cooling
I don't think I'm in the right place, since my problem is...
System Cooling
Ac only works for a minute or so then goes off. Now when I...
Loading problems.
Repair Service
Find System Cooling Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
