Question about Agri-Fab Agri - Fab Snow Blower - 42"
826LE Power Max Snowthrower_ Drive belt keeps coming off
Help!!! I have replaced 2 drive belts and it keeps throwing belt off. The idler is OK as well as pulleys. I have adjusted according to manual but still throws belt. Anyone have any ideas. Thank you.
Rich
  • 5 more comments
  • Richard Doherty Sr Feb 04, 2009
    Hi: The model# is38620 serial # is 240000001. I called the dealer where I bought the 2 belts ,as well as snow blower in 2003,about problerm and they said there were fractional size belts, so I am assuming they may have sold me wrong belts. They do appear slightly larger in width. Anyhow they are picking it up tommorow. This snowblower was purchased in 2003 and has performed extremely well up to this point. I hope they can rectify problem but will probably eat cost of 2 belts. I will advise. Thank You
    Rich
    Hi: I will definately rate it. Thank you again for your rapid response.
    Rich
  • Richard Doherty Sr Feb 11, 2009
    Thank you for the info. The machine is at the dealer where I purchased and the mechanic called yesterday and comfirmed the info you have discovered,however according to him Toro has a part which will rectify problem. He and I am currently waiting for the part. I shall inform him of this service bullitin and keep you updated.
  • Richard Doherty Sr Mar 01, 2009
    Update: Received Snowbower from repair shop. Total cost was 215.97. They replaced traction sheave half,drive belt and hex trunion. Performs OK now. Thank you to all who responded.
    Rich
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    your welcome!
  • JERRY ABELL
    well since thay are goint to repair machine hope it's right and don't cost too much,good luck,MrFixIt. could you rate this solution anyway please,thank you.
  • JERRY ABELL
    hello mr d, i need the mobel #and serial # of your toro 826 power max snowblower,toro will not let me look for the schematic on your drive belt or parts list.please let me know.
  • 24 Answers
Part # 94-8812 is traction belt 106-4498 auger belt
There is a service bulltin on this I have not seen this yet, Ill paste it for you to look at .
this was issued dec 22-2003 you would think that it would have shown up as a problem by now.
UNITS AFFECTED: Model Number(s): Serial Number(s):
38620 240000001-240999999
38621 (Int'l.) 240000001-240999999
38632 240000001-240999999
38635 (Int'l.) 240000001-240999999
38642 240000001-240999999
38645 (Int'l.) 240000001-240999999
38652 240000001-240999999
SUBJECT: Traction belt jumps off the pulley.
SITUATION: Incorrect pulley alignment causes the traction belt to jump off, usually when the drive is disengaged or as a hill is crested.
CORRECTION:
1. Remove the belt cover, engine belt guide and the bolt securing the crankshaft pulley.
2. Remove the auger brake assembly.
3. Remove the crankshaft pulley and the auger belt.
4. On the left side of the machine, remove the hair pin cotter from the speed control link and slide the link out of the pulley pivot assembly. The traction belt can now be removed.
5. Shorten the pulley half nearest the engine (PN 106-7334) shown in Fig 1. Grind or machine 1/8” (.125”/3.2mm). from the hub end of the pulley. The new finished length of the pulley half should be 1.07” (2.7cm).
6. Chamfer the bore to ensure the pulley fully contacts the shoulder on the crankshaft. You can send the pulley to an outside machine shop if you do not feel that you can modify the pulley in house.
7. Reinstall the pulley with a new traction belt.
A. Chamfer edge after grinding/machining.
B. Remove 1/8”.
C. Masking tape used as a reference line.
8. With the engine off, engage both the traction and auger levers and inspect the alignment of both the auger and traction belt idler pulleys (Fig. 2). Since we have moved the crankshaft pulley it may be necessary to bend the idler arms slightly to center the belts. Adjust as needed.
9. Install the engine belt guide and test operate.
10. Install the belt covers.
PARTS: P/N 94-8812 Traction Belt
Posted on Feb 10, 2009
  • dr1plain Feb 11, 2009
    This shold only be done by your toro dealer ,if this is the problem
    it may still may be under warranty
Why can't I tighten the drive belt enough to keep snowthrower throwing snow? .
Perhaps the drive belt has been over stretched, meaning you need a new one...
Oct 13, 2015 | Garden
How to replace drive belts on a 1989 dodge ram b250 van
Most accessory drive belts have an idler pulley that tensions the belt. The idler pulley either has s 1/2 inch square drive hole or some other way to apply force to counteract the spring. Identify the idler pulley and push it in the direction to loosen the belt, then remove it.
Feb 25, 2015 | Dodge Ram B250 Cars & Trucks
Change belt on snapper 722 snow blower
1. Remove the belt cover with a socket wrench. Slide the belt cover off and set it aside.
2. Remove the two belt cover stud bolts with a socket wrench to get to the auger belt guide. 3. Remove the belt guide with a socket wrench.
4. Push down on the belt tensioner pulley with your hand. Remove the old belt and set it aside.
5. Install the new belt and release the belt tensioner pulley to tighten the belt.
6. Re-install the belt guide with a socket wrench and tighten the bolt.
7. Re-install the two belt cover stud bolts and tighten with a socket wrench.
8. Re-install the belt cover and secure it with the cover bolts. Tighten the bolts with a socket wrench.
I pulled the following from a snaper model similar to yours.
The snowthrower has two drive belts, one for the traction
drive-which transmits engine power to the wheels, and
a second for the auger drive-which transmits engine
power to the auger mechanism.
Each of these drive belts are of special construction and
should be replaced only with genuine replacement belts
which match the original equipment belts. These are
available from your dealer.
Traction Drive Belt Replacement
I pulled the following from a snapper model similar to yours. Believe it should help.
1. Disconnect spark plug wire and fasten it away from
the spark plug.
2. Remove belt cover. (Located in back of the discharge shute).
3. Pull the traction drive belt idler pulley arm (See
Figure 24) away from the belt to relieve tension, and
slide the belt off the engine pulley.
4. Slip the belt off from around the traction pulley (See
Figure 29) and pull the belt out of the unit between
the auger pulley and the traction pulley (the lower
cover need not be removed for this step).
5. Reverse the procedure to install the new belt. Be
sure there are no twists in the belt, and that the belt is
properly seated in the pulley grooves.
6. Replace the belt cover.
7. Start the unit, and check the traction drive for proper
operation. See "Traction Clutch Cable Adjustment"
for adjustment procedures.
There are also several videos on YouTube on changing snowthrowr belts. (Didn't see one for your blower, but most similar and should provide a good starting reference).
May 09, 2014 | Agri-Fab Agri - Fab Snow Blower - 42"
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Cub cadet SLT 1554 keeps throwing the drive belt
Double check the routing diagram. Check to make sure your idler pulleys are in good condition. Bearings are good. Lastly the tension spring may be worn. The belt should fit very snug. No more than 1 1/2" of deflection when you push on the belt with your thumb
Oct 15, 2012 | Garden
I have a Husqvarna YTH20B42 and the snowblower keeps throwing the belt...what size belt do I need to order? I can't see it on the belt...Serial # 122906B002271
Its likly the belt is OK the problem is there is on idler pulley that has an adjustment so when the augers are engaged it puts force on the belt witch tightens and makes every think turn and when disengaged every stops turning. There is always an adjustment involved with this. If you can remove the belt then with the mechine not running of corse engage the drive and watch how it fucnitions then look for the adjustment that would move the idler closer or further away from the belt
Dec 16, 2010 | Husqvarna Garden
Belt diagram
2 valve
Item Part Number Description 1 8679 Belt idler pulley 2 10344 Generator pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6312 Crankshaft pulley 6 8509 Water pump pulley 7 2E884 A/C clutch pulley 8 6B209 Drive belt tensioner pulley
4 valve
Item Part Number Description 1 19A216 Belt idler pulley 2 10300 Generator clutch pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6316 Crankshaft pulley 6 8A528 Water pump pulley 7 19D692 A/C clutch pulley 8 6B209 Drive belt tensioner pulley 9 19A216 Belt idler pulley
Oct 26, 2009 | 2003 Mercury Grand Marquis
How to install drive belts to 1996 nissan quest
go here for help
http://autos.groups.yahoo.com/group/villagerquest/files/
Item Part Number Description 1 — A/C Compressor Drive Belt Idler Pulley Adjustment Bolt (If equipped)
(Part of 8678) 2 — A/C Compressor Drive Belt Idler Pulley Tensioner Bolt (If equipped)
(Part of 8678) 3 8678 A/C Compressor Drive Belt Idler Pulley (If equipped) 4 8620 A/C Compressor Drive Belt (If equipped) 5 2E884 A/C Clutch Pulley (If equipped) 6 10346 Generator 7 10344 Generator Pulley 8 11719 Generator Adjustment Bolt 9 — Generator Locking Bolt 10 8620 Generator Drive Belt 11 6312 Crankshaft Pulley 12 — Water Pump and Power Steering Pump Drive Belt Adjustment Bolt (Part of 8678) 13 8678 Water Pump and Power Steering Pump Drive Belt Idler Pulley 14 — Water Pump and Power Steering Pump Drive Belt Idler Pulley Locknut (Part of 8678) 15 3A733 Power Steering Pump Pulley 16 8620 Water Pump and Power Steering Pump Drive Belt 17 8509 Water Pump Pulley A — Tighten to 16-20 Nm (12-15 Lb-Ft) B — Tighten to 33-37 Nm (24-28 Lb-Ft)
Mar 28, 2009 | 1996 Nissan Quest
Agri-Fab Agri - Fab Snow Blower - 42" Logo
2,965 people viewed this question
Top Agri-Fab Garden Experts
Joseph Mueller
Joseph Mueller
David Ellis Rhea
Ray Smythe
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
