Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Computer stalls during startup
I have a Free Agent go 250gb attached to my Dell running XP. If I have it plugged into my USB hub during startup the computer stalls at the welcome screen. If I unplug the external drive the computer will restart normally. Then I can plug in the external drive and it works fine. This problem started after about 2 weeks of it working normally.
  • 77 Answers
How Old is your computer (depending on age, it may not have USB 2.0) that is what you may need to have a external HD now a days
or is it the drivers?
Posted on Feb 04, 2009
Safe startup programs to disable?
Press F8 during boot to access Safe Mode.
To disable startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 06, 2012 | Dell Dimension E521 Athlon 64 X2 3600...
Mine keeps saying "USB Over
The power adapter could be faulty.
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Apr 14, 2011 | Western Digital 250GB MyBook External USB...
How do i retriev my stuff of it to put on computer?
Assuming the harddrive is working, plug it in and click start and my computer( or computer if you are running vista or 7) and then in this window click the name of the harddrive. Then drag and drop?
If you used 3rd party software to back up your data you will need to install that first and run the recovery option
May 02, 2010 | Western Digital WD Passport 250GB Portable...
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
I connected the external floppy drive to a USB hub which in turn is connected directly to a USB port on my Dell desktop which runs Windows XP Home Edition 64 bit version and the drive just runs and will...
Yes, the external floppy drive must be connected directly to a USB port on the computer instead of to a USB hub.The PC can't see the drive thru the USB hub. Applies to both 32 and 64 bit.
Sep 07, 2009 | Computers & Internet
Pop up message says that I have a USB device that is not recogniz
Do you have anything like a printer or scanner or an external USB drive connected to the computer. If yes, then remove it. If not let me know.
May 14, 2009 | Toshiba Satellite 5005-S504 Notebook
KVM converter
Buy a usb hub and an usb extension, so that you can have 4 or 6 free usb at the front of your computer, and you can switch devices using usb rather then the mouse converter . Using the converter on mouse and keybord make easier for the plugs to slip out, and usb is better. Note some usb modem and some other device do not support usb hubs, you have to plug them straight into the free computer plug , if you have any.
Apr 09, 2008 | Computers & Internet
Error message "power surge on hub" when attempting to upload from N C 5200
Hi, are you using a USB hub or attaching directly to the computer USB port?
  1. If you are using a USB hub, which is then connected to your computer ... you either need to
    1. Plug the camera directly in to the computer so that the computer supplies the USB with more power to the camera.
    2. If the USB hub has a power plug/adapter, use it so the USB hub gets more power to handle the task.
    3. Buy a different USB hub that has a power adapter so enough juice can be supplied to the tasks that USB is asking to do.
  2. Some USBs on the computer aren't giving enough power, you may have a bad USB port, try another one.
  3. Use a Card Reader, which is much faster to download pictures than from the camera.
Reason: some times, the USB task is asking for a lot more power than is being supplied through the current USB path. You have to either add power through an adapter or plug directly in to a power source (like the computer directly, or a reader that doesn't require as much power to operate it).
This should help, if so, please mark as FixYa!
ThankYa!
Dec 01, 2007 | Nikon Coolpix 5200 Digital Camera
DELL STARTUP
There was problem at one time with IOGear KVMs not working correctly with the USB chipset on the Dell motherboards. This problem was resolved by using a USB hub between the KVM cable and the computer. The user could take the USB portion of the KVM cable and plug it into a USB hub and then take the USB hub and plug it into the Dell computer. That should help with the problem.
Oct 16, 2007 | IOGear GCS632U 2-port KVM Switch
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
270 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
