Question about GE Spectra JBP78 Electric Kitchen Range
Glass stove top has a piece that has peeled back
Our GE Profile stove top has a piece (the size of a hole punch) of the protective coating over one of the burners that has peeled back. Does anyone know if that can be somehow put back on with some sort of adhesive? Can the burner still be used with this piece exposing the burner? Is there any other way to fix it without having to replace the whole glass top?
    Genius:
  • 2,920 Answers
Once they are broken they are broken you have to replace he whole top
Posted on Feb 04, 2009
After washing my stove top I can't get it to light without a lighter. It clicks, but won't light. Only the burners on the right side.
You most likely push the igniter too far away from the burner. The top of the stove should pull up u should see the igniter just push it with ur finger within a 1/16th inch to the burner.
Nov 12, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Tip
How to Stop the dishwasher from breaking my glasses
This shelving costs $16 plus $20 for powder coating.
Very easy to assemble taking about 2 hours.
It will stabilize your dishwasher trays so glasses wont fall over. Therefore wont break.
Buy 2 large Baking racks with 1 cm holes from Myers for $8 each.
Use your Angle Grinder to cut to size, making sure the cross wires running from left to right are on top of the long runs. This is because your glasses would slip all the way to the front, if you mounted the racks up the wrong way.
Basically I cut off only one side of the rack, using the cutoff piece for the middle hole.
Next flatten those legs that wont let the rack sit flat down, by using your vice and hammer.
See the diagram below how wide the framing supports wires are apart, that is why nothing stands up on them.
You may have to discard other supplied movable racking.
But the inserted racks, with a hole cut in the middle rack to allow a raised support wire some space, are very stable.
Now after cutting hammering and bending the racks loose some coating and will rust with little rust marks appearing on the edges of all your crockery and cups.
Therefore you will need to powder coat them any colour for years of protection.
Just find a powder coater in the yellow pages and give him the cutout racks.
To save money I told him to coat my Black racks to any colour in his machine, which turned out white.
Note the glass which now stands up stable and straight.
on Feb 06, 2015 | Dishwashers
I have a glass 4 gas burner stove top and cracked the glass, can I replace it? Its a GE Profile with a stainless steel front lip
Yes the glass is replaceable, you will have to order a new one, and you could do so through an appliance parts store. They can even put it in for you.
Mar 22, 2011 | GE 30 in. Profile JGP932 Gas Cooktop
I need to replace a cracked glass top (GE Profile Slide In... where do I find my oven model number and part number
If you dont see it around the door or inside the stove you'll have to raise the top and it should be there somewhere. The part number for the glass top I can get for you if I have the model number
Sep 08, 2009 | GE Profile 30" Self-Cleaning Slide-In...
Coating is peeling off my microwavww handle????
How nice of them!
Often it is caused by the use of hand cremes affecting and tarnishing the metal coating or the plastic pigments.Many items suffer from handremeitis
including the letters on keyboards car door handles, AC knobs etc etc.
Unfortunately it is the way of life that is associatedkin care and vanity.
Sep 02, 2009 | GE JVM1630 Microwave Oven
Counter top stove burner won't light
Hi, You asked a very generic question but I will try to give you a good answer. If the pilot is good and you can light the burner with a match, (this checks everything else) then the most common problem would be the burner holes in front of the pilot are clogged. When cool, remove the burner and inspect the holes, any debris needs to be removed, a bent paper clip works really well. Compressed air helps as well. If there is a tube to the pilot make sure it is exactly where it belongs and that it is clean. If the match didn't light the burner or the flames is not all blue like the rest, there is something else wrong and you need to get back to us with a make and model to better help you. Make sure the burner gets seated back on the orifice correctly and best of Luck to you!
Feb 05, 2009 | GE Profile JP930 Electric Cooktop
Stains on glass top
This is smooth glass - you can use a razor blade on it. Hope this helps!
Jan 13, 2009 | GE Profile Spectra JBP95 Electric Kitchen...
Replacing glass top on stove
its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
Jan 05, 2009 | GE Profile Spectra JBP90SFSS Electric...
GE Spectra JBP78 Electric Kitchen Range Logo
314 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
