Question about Philips Magnavox 51MP392H Rear Projection Television
Hello, I have just purchased an LG 32PG6000 and whenever I try adjusting the picture settings to my preferred taste, after 10 minutes or so the new settings revert back to default. I just can't seem to retain my new adjustments. Am I doing something wrong ?
I have a user manual in norwegian, and I have just solved this problem. Go to page 107 in the user manual, and it will guide you. :)
Posted on Jul 21, 2009
I find the colour contrast is very dark could you send me ideal colour settings for perfect clarity thanks
Adjust the contrast to 55 to 70%; brightness to 45 to 55% and colour to your viewing taste. Now the brightness will be very low I thinks. Advance the brightness and contrast after setiing the colour to Zero. Adjust for a well defined B/W picture first. The advance the coulour. Take reference of the face colour of a news reader at studio. The picture will be perfect. OK.
Jul 07, 2011 | LG 42LB1D 42 in. HD-Ready LCD TV
I need the picture settings for a trutech tv. For example : number for contrast .
The picture setting for any TV depends upon the taste of the viewer. Contrast is the deepness of details in black and grey level. In most TVs a 55 to 75% of contrast will give a good picture. you have to adjust the brightness level also according to contrast. It is best ot turn out colour to 0% first. Adjust contrast and brightness to get a well detailed B/W picture first. The apply enough colour to that B/W picture according to your taste. Face colour of a newsreader at studio will be the best reference to intensity of colour.OK.
Jul 06, 2011 | Televison & Video
What is the proper calibration settings for a panasonic tc-p50s2n. I have used it for over a 100 hours
Do you have access to a test pattern or color bar ? .If you have a THX certified DVD ( some Walt Disney movies ) it will have calibration setup guide in the DVD menu.Or else you have to buy a calibration DVD if you are serious about your TV setup.
First you have to set the contrast and brightness using the Grey-scale pattern. Seven set of vertical bars slowly progressing from white to black. If set right you should be able to make out all the seven bars with out each merging ( or overlapping ) into the other. You will be able to see the line of demarcation between each vertical bars. Then set the color to taste.
If you do not want to purchase the above mentioned DVD disc a close setup figure for your Panasonic TV would be
Picture Mode = Standard ( Normal )
Picture ( Contrast ) ---- 50
Brightness ---------------- 50
Color ------------------------ 33
Sharpness ---------------- 50
Hue ------------------------- In the middle
This setting should give you a decent picture quality assuming your TV is new.
Apr 12, 2011 | Panasonic Televison & Video
How do I adjust the color
To adjust colour and other picture adjustments
[1] Press "Menu" key to display the main menu.
[2] Use cursor UP/DOWN keys to hilight [green]; Picture or sound ; whatever you wants to adjust, and press ENTER.
[3] Use cursor UP/DOWN keys to hilight [green] AUTO [for factory settings] or MANUAL to set picture settings according to your taste. Here you have to hilight MANUAL as you wants to set it mannualy. Press ENTER after selecting MANUAL.
[4] User cursor UP/DOWN keys to select the option you wanted to change.
then cursor keys to make adjustments of the selected option parameter according to your taste.
[5] When you have finished all the adjustments according to your taste, press EXIT key to return to normal tv viiewing. This way you can adjust the sound parameters also. Proceedings are all the same, but the option choose to hilight [green] must be sound. That is all. Ok.
Jan 12, 2011 | Sanyo DP26746 26 in. LCD Television
What are the best picture settings for this tv?
Go to its menu and surf through and come to the picutre adjustments. Normally the factory set will be 50% of all the settings. You have to set it individually according to your taste. Anyway I'll give you a settings which finds me the better
Color = According to your taste
Brightness == 35 to 40
Cotrast == 70% of the maximum.
Sharpness == 35
Tint = If you are reciveing NTSC system programme you have to adjust this. If so adjust this to get a good flesh tone, and refer it to a stationary picuture, like a news readers face and so on.
Blue back = keep it on. It is best.
Jan 06, 2011 | Philips Magnavox 27MS343S 27" TV
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
LG 32'' LCD TV aspect ratio self switching
I have an LG LCD TV with the same problem.
The solution is to go to
And select HOME rather than STORE on initial setup.
Mine was set to store as it was a display model.
That means that whatever picture setting you make they will reset after 10 minutes.
Nov 19, 2008 | LG 42LP1D 42 in. LCD HDTV
Hi, I have just purchased the Samsung LE37A559 tv. I have been trying to get the best colour settings brightness colour contrast tint backlight etc. Is there a optimum setting for all of these ? I am...
The problem is that everyone has a different "taste" when it comes to these settings. I like to turn the color all the way down to start with. You should (if the set is factory adjusted correctly) have a black and white picture. If it's not B&W, then there's something inside the set that needs adjusted and you should get a service call. Then I adjust brightness and contrast to get the best B&W picture. Then I turn the color up until I'm happy with the color level, then I adust tint.
Hope that helps
Jul 29, 2008 | Samsung Televison & Video
Dishwasher leaves taste on glasses
hi there sounds like your rince aid level is set to high, the adjustment for this is located under the rince aid filler cap, try setting to position 2
Dec 13, 2007 | Electrolux 23 in. ESI6104 Built-in...
Sony KP-57HW40
Have a Tech. replace the focus/screen block if the problem continues you have a bad red CRT.
Sep 21, 2007 | Sony KP-57WS500 57" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
268 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
