Question about Microsoft Windows Vista Ultimate Edition
Full screen TC
Can i run turbo c++ in full screen in vista???if yes then plzz tell me how to run it
How to run tc in full mode for vista
Posted on Apr 29, 2011
    Guru:
  • 829 Answers
Hi Yes , You can run C++ in full mode. Plz follow the below step.
Hold Alt Key and hit Enter key it will move in full mode.
If you want permanent full mode option then right click and select proprties. In display select full screen and that it.
Posted on Feb 04, 2009
Turbo c in windows 7 full screen
HERE is the simple trick :To use Turbo C++ IDE in windows 7 or in Vista; For those who wants to learn C/C++ just uninstall your "Graphics driver "
For that Computers->properties->device manager->Display Adapters->graphics driver version u have uninstall that...And after log off Run your "C:\\TC\\BIN\\TC.exe".it will open in full screen...
Apr 10, 2010 | Microsoft Select Application Center...
How to run turbo c++in vista 64 bit os
You can run Turbo C++ 3.0 on Windows XP 64 bit , Vista 32 bit and 64 bit OS (in full screen)
Install the software DOSBox ver 0.72 (Freeware) from the link below (Direct Link)
http://prdownloads.so urcef orge.net/dosbox/DOSBox0.72-win 32-in staller.exe?download
Before going to the details u have to create a folder (any name will do).
Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
For example (Type in the following commands after the Z prompt):
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
C:\> cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
source site :
http://mycomputer.freefor ums.o rg/running-turbo-c-in-full-scr een-m ode-help-t1241.html .
Sep 03, 2009 | Microsoft Windows Vista Ultimate Edition
Plz tell me how i can run c++ in full screen in vista ultimate
Hello
Use the command prompt. Maximize the window size. Change directory to c:. You will have a line that fits 75 characters and a window that occupies about 2/3 of the whole window. That's enough fore all reasonable problems. If you are not happy with what you get, you may try developping your C++ program under Linux.
Hope it helps
Aug 29, 2009 | Compaq Presario 700 470024-192 Notebook
Problem for installing turboc++4.5 in wista
ok man i too had teh same prob dont back to xp
Before going to the details u have to create a folder (any name will do). Here we name it as Turbo
Now , Type in the following commands after the Z prompt:
Now type d: to shift to d: prompt .
D: cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
D: cd Bin
D: TC or Tc.exe [This presents u the Turbo C++3.0 screen]
On the Turbo C++ goto Options>Directories>Change the source of TC to the source directory [D] ( i.e. virtual D: refers to original c:\Turbo\ . So make the path change to something like D:\TC\include and D:\TC\lib respectively )
In order to get the full screen use the key combination of Alt and Enter
When u exit from the DosBox [precisely when u unmount the virtual drive where Turbo C++ 3.0 has been mounted] all the files u have saved or made changes in Turbo C++ 3.0 will be copied into the source directory(The directory which contains TC folder)
It is a good idea to backup your files in the source directory prior to running DOSBox 0.72
For additional help go through the readme file located in the installation folder or look on the website of the DOSBox forum.
The above procedure has been successfully implemented on Windows Vista Ultimate 64 bit
IMP : Don't use shortcut keys to perform operations in TC because they might be a shortuct key for DOSBOX also . Eg : Ctrl+F9 will exit DOSBOX rather running the code .
Jun 17, 2009 | Microsoft Windows Vista Ultimate Edition
I have a hp laptop with windows vista home premium.i want to work on turboc++, but i am unable to do so. kindly giv your assistance.....
Install the software DOSBox ver 0.72 ( 1.2 MB ) (Freeware) from the link below.
http://prdownloads.sourceforge.net/dosbox/DOSBox0.72-win32-installer.exe?download
D: cd Bin
Mar 07, 2009 | Microsoft Windows Vista Ultimate Edition
Turbo c++ in vista
Step 1: Open TC++ (normally C:\TC\BIN\TC.EXE). In the startup it will show a dialogue box that it
doesn’t support full screen mode as seen in the picture below.
Just select ignore option. Then it will open the small screen mode
Step 2: Go to the top left of the window and click. It will show a menu as shown in the figure.
Then select properties from the menu
Step 3: Now it will show the properties window, in which you select the Font tab.
There you can see two font options as Raster and Lucida Console. The default will be Raster.
You select Lucida Console and select the size from the size list as 28.
Step 4: After selecting the fonts, now you have to select the layout tab where you can see
screen buffer size, window size, and window position options.
First unselect the “Let system position window” option from window position options.
Now make the following changes:
Screen Buffer Size: Width: 82 Height: 28
Window Size: Width: 80 Height: 26
Window Position: Left: -4 Top: -4
OK
comments @
roxy111in@yahoo.com
Oct 19, 2008 | Computers & Internet
ABOUT TURBO C++
Vista doesn't support full screen mode while operating Turbo C++,
and its also doesn't support graphics(bgi) while operating it.
There are lots of compatibility problems with Vista --
I have Vista Home Premium and have warning when I start VC++ 2005 Express!
I just tried running tc.exe and did not get the warning message you reported.
Although it would only run in the small window.
Your best bet is to download either VC++ 2005 Express or Dev-C++.
They both run full-screen.
Sep 10, 2008 | Computers & Internet
Turbo c doesnt have a full screen version on vista..
FOLLOWS THESE STEPS TO SOLVE THIS PROBLEM...
  1. Copy the “DOSBox0.72-win32-installer.exe” from http://www.download3k.com/Install-DOSBox.html
  1. Install it with default settings.
  2. Create a folder “Turboc” in your C:\> directory.
  3. Copy your turbo c folder such as “TC” in the folder “Turboc”. This is shown in the following diagram.
fifth.jpg?w=625&h=526<!Run the software you installed. Its icon is present on the your desktop.
  1. This will run the software, as shown in the fig:
first.jpg?w=573&h=507<!
Write these lines in the screen:
mount c c:\>Turboc
Press Enter
Following message will appear on the screen
Drive c is mounted as local directory c:\Turboc\
Now write:
C:
Press Enter
Now write:
cd TC
Press Enter,
Now write
cd bin
Press Enter,
Now write
Tc.exe
All these steps are shown in the following figure:
8.
Now following screen will appear:
10. Press Alt + Enter. Full screen mode of Turbo C will appear.
[updated]IMPORTANT : Don’t use shortcut Ctrl+F9 bcoz it is a shortcut for dos box to exit
Happy Coding
Jul 02, 2008 | Microsoft Windows Vista Ultimate Edition
How to run turbo C editor in full screen in windows vista
for more visit www.hackersorigin.com
or
forum.hackersorigin.com
Mar 22, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
149 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
