Question about Compaq Presario 2190US Notebook
Wont stay off
Compaq Presario 2190 us
when I shut down, it turns off-
walk away, come back later
and low and behold,
its back on
  • marty684 Feb 04, 2009
    Thanks. This problem happens with the battery out and only using the power cord to run computer. Is the power suppy in the computer and is it easy to fix?
    Problem Solver:
  • 19 Answers
Sounds like it needs a new power supply.
Posted on Feb 04, 2009
98 Montero sport idle drops at light than goes back up
Engine stalling and rough run issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Aug 26, 2012 | 1998 Mitsubishi Montero
Hi, so I'll start up with me updating the bios on my compaq cq60-615x, when it froze. And later shut off after a while. Now I boot with NOTHING. No beeps. No screens. Just black. I'm almost po
you will have to take your pc apart google the type of pc to see how to take apart and you will need to flash your bios when inside you will see a big flat battry take it out (unplug it) turn on pc then shut down pc and plug back in and restart remember to wait 15 seconds before turning on any computer or you will fry something never turn off than turn back on right away i fried my graphics card that way
Aug 21, 2012 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
I'm having video problems with my sr5710f compac presario. PC is up and running, and the moniter will flash on just for a second. Monitor is recieving signal, but wont stay on. Is this video card problem?...
its old and old pc have problems, just like cars.
a desktop
NO OS stated, came with VISTA. (a dead OS now)
no monitor stated,?
series 5000 is obsolete, and near worthless.
the unstated monitor is first.
if the OSD screens is dead?, yes then the monitor the monitor is BAD
all monitors 2000 year and newer have OSD
the OSD is the monitors brain inside
you push the menu button on the front and behold , this.
this pc has onboard GPU/VGA chip (unless upgraded to PCI slot VGA)
a key missing fact if true. (but is possible)
if running and old CRT monitor , do tell which one (model number)
here are all simple tests on that monitor.
http://www.pcdied.com/monitors.html#desktop
Aug 19, 2017 | Compaq Presario 5000US (D70008-261) PC...
I have a 2010 viking heritage 2 spa. the owners manual says that for the primary pump, there are low, high, and off settings, but mine only goes from low to high. no matter what setting it is in, the pump...
If you have a timer and it is on a maintenance cycle that will keep it on low, A freeze control that will keep it on under about 38 degrees. If the thermostat is controlling the pump it will keep it running also. If it has a cool down mode to let the heater cool that will keep it running. These are some reasons it will stay on and their may be more. I would turn the thermostat down and if it's cold out run a heater under the cabinet and make sure that no timer is controlling the pump. Set it to low and walk away for half an hour if it won't shut down turn it up to high and back down again. One of these low speeds should be off. Good luck.
Oct 24, 2010 | Heritage Pool and Cover Pump
Compaq presario v5000 won't stay
sounds like overheating , probably due to the cpu or gpu fan/heatsing loosing contact, even a little knock could have caused this
Jul 16, 2010 | Compaq Presario Notebook
My Compaq Presario CQ50-103NR Notebook PC keeps shutting down. Sometimes right away sometimes after a few minutes. The left side of laptop seems to get hot while the right side stays cool. Can You please...
Hi:
You most likely have a heat problem, as you have realized. To fix the problem, your heatsink/fan assembly needs cleaned, and then reinstalled with new heat sink compound. Some disassembly is required, so this isn't an easy job. If you go to a reputable shop, and tell them what you want them to do, rather than just tell them your laptop is shutting down, you should get it done for a fair price!
Apr 23, 2010 | HP Compaq Presario CQ50-103NR Notebook PC
I have a compaq presario x1000 that wont let me get past the logo. It was working fine one day, but then I shut it down. The next morning I booted it up it the computer never went past the Compaq logo.
It is likely that the hard drive is bad or a memory issue. I would start by removing the hard drive and see if it goes past the compaq screen. If it does then you know what is wrong. If not message me and will walk you through the next step
Jun 30, 2009 | Compaq Presario X1000 Notebook
Power issue
plz check if there is any disc in the drive?
if not this time the system restart keep tapping on f 8
and go to safe mode type msconfig in run clk ok
new win will *** up go to startup tab down at bottom disable all
apply ok restart teh computer clk on the chk box dont show this mesg again once the computer will boot let me know if teh thing doesnt work
May 22, 2008 | Compaq Presario 700 470024-192 Notebook
My compaq presario R4000 just stopped working and shut down - no warning - nothing!
bad battery. best way to kill a battery is to always have it charging and never using it or discharging it.
take the battery out and use it just with power cord, see if it shuts down again. or try to use it with JUST the battery if battery is bad the PC will not turn on or stay on
Jan 04, 2008 | HP Compaq Presario R4000 Notebook
System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Jan 02, 2007 | HP Compaq Presario SR1220NX (PJ517AAR) PC...
Compaq Presario 2190US Notebook Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
