How to record from the turntable using the TDK DA 5900
you need to run your rca cables from your amp/mixer depending on what your using,from the outputs into the inputs on cd recorder.
trhen make sure youve got the right cds cause i own a sony cd recorder an can only use sony digital audio cds,so you want to check that.
there should be a record button on unit press it and then play and you should be away.good luck any problems ask
