Question about Brother CS-6000
My needle hits metal
While trying to sew a project my bobbin ran out of thread so i fixed that and put it back into its holder but then when I started to sew again my needle was hitting metal. No the needle is not bent. im making something for my grand daughter so can Someone Help Me? please?
  • 333 Answers
You have to be putting the bobin in the wrong way or it is not all the way in. I hopr this helps.
Posted on Feb 04, 2009
Simplicity sewing machine SL 9240 was giving to me and when I try to sew the needle keeping hitting the bobbin holderr.
On the right side you have two knobs to make adjustments. The lower knob will move the needle left or right so it won't hit the bobbin holder.
May 31, 2014 | Singer 7442 Mechanical Sewing Machine
I was sewing with elna machine and ran out of thread. This caused the thread to ball up underneath and "jam" the machine. I cleared it out and rethreaded it, but now the top thread doesn't catch the bobbin...
it is possible that the sewing machine has a timing problem, but check to see if the needle is inserted correctly into the needle holder
make sure the bobbin is inserted correctly into the bobbin case if the machine has a top loading bobbin
if the machine has a side or front loading bobbin also make sure the bobbin case is inserted correctly into the machine.
and also make sure the top thread has not come off the thread take up lever
Aug 20, 2013 | Brother XR-65t Mechanical Sewing Machine
I was sewing a straight seam and all of a sudden the thread wouldn't pick up the bobbin thread anymore. Now I can't sew and have much to sew for a wedding in 5 days. Can I fix this myself? When I turn the...
If you can hear a click then I'd say the needle is touching some part of the hook mechanics which could mean timing is out. However, it is possible that the bobbin case has just moved a little so as first trouble shooting steps, I'd suggest the following:
clean out the bobbin holder area as per manual (ie. remove the needle plate, bobbin, sewing foot and needle, take out the bobbin holder, clean the race area out, then put bobbin holder back in as per your manual, there is usually a stopper and knob or two red marks to line up. This is held by a magnet so it is possible to knock it out of place during a jam up.
Replace needle plate, bobbin, sewing foot and put in a new sharp needle, flat shank to the back and make sure it is fully up into the holder, thread up and very slowly using the needle up and down button, test sew a couple of stitches again.
If no stitch formation or you can definitely hear/see something touching then I'd say timing is out and no, its not something fixed yourself; best left to a trained technician.
Apr 11, 2011 | Elna Quilter's Dream 6003Q
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
I took out parts of bobbin to clean and when put them back the needle hits the metal of the bobbin case and i cant sew. it doesnt seem to be properly aligned.
Perhaps remove the bobbin case and check that you have put it back correctly. Check with the sewing machine manual to see how it is done correctly. Make sure that the top of the bobbin case is at the top of the bobbin case holder and make sure you change the needle as it will probably be dull or bent from hitting the metal of the bobbin case.
Aug 27, 2010 | Bernina Activa 130
Brother CS-8150 Problems with bobbin thread
Double check to see if the bobbin is in upside down and the thread is feeding from the bobbin spool in the wrong direction.
I did this once after several years using the same machine, some days are just not as easy as they should be!
Mar 04, 2010 | Brother CS-8150 Computerized Sewing...
My needle keeps hitting the plastic bobbin holder - how can I fix this? Is the bobbin holder inserted wrong?
change the needle and see if it is still hitting because once they hit the case or the feed dog they very often get bent always change needles with different fabrics and types of thread
Dec 12, 2009 | Singer Quantum 7350 Mechanical Sewing...
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Brother CS-6000 Logo
109 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
