Question about Whirlpool Washing Machines
I have a 12 year old whirlpool washing machine model lxr7144eq0
It will not agitate or spin. I can hear the motor running and I looked under the machine and the belt that attaches to the pump motor is in pretty bad shape. I,m hoping its just the belts and not the clutch in the transmission any suggestions.
    President:
  • 1,214 Answers
To determine if the transmission caused the belt to wear, then unplug the washer, and looking up inside toward the transmission, note the large diameter pulley that the belt goes around. See if you can turn it by hand. It should turn freely in both directions.
This isn't a 100% guarantee that the transmission is good, but will give you an indication. Make sure the washer is at the end of it's cycle when trying this.
If it turns, replace the belt and see what happens. If it doesn't, make sure none of the solenoids are engaging the linkage, otherwise, you'll be trying to turn the drum or agitator.
Posted on Feb 04, 2009
I have a Whirlpool Ultimate Care 2 Imperial Series washer that doesnt spin out very well. It will sometimes spin out but leaves the clothes very damp. Sometimes the washer will try to spin itself out but ...
First thought is that the cycles are off.we have the same problem with ours right now. That slow spin speed concerns me. The motor could be going bad. If this washer is 10-12 years old, you may want to look at replacing it. Does the machine ever start agitating before it finishes filling. If so, the cycle mechanism is going bad. This has a whole host of potential problems. Ave a rep look at it. He can narrow it down quickly.
Feb 06, 2013 | Whirlpool Washing Machines
My 15 year old Whirlpool washing machine did'nt agitate or drain, could it be the motor? If so, how do you access the motor?
Look for a broken lid switchthemobilian_1922.jpgAll the models over the years have changed the way you get into the machines but the basic concept is the same. The cabinet is removed to access and service this washerthemobilian_1923.jpgthemobilian_1924.jpgthemobilian_1926.jpgthemobilian_1925.jpg
Drain and spin is in the same direction on these washers.
It won't spin with lid open. Newer models won't spin or wash either with the lid open.
Basically the lid switch has a green ground wire and 2 hot wires. themobilian_49.gif
Jump them 2 hot wires as shown here at the quick connect to look for leaks and noises AND to see if the lid switch has failed.
Manual and more HERE
Mar 16, 2011 | Whirlpool Washing Machines
Whirlpool A5380XTWO will not spin or agitate. Is
check the "wig-wags" that shift the transmission in the washer,they are 2 coils(solenoids) located adjacent the motor on the transmission,if they get no power they wont shift transmission into next cycle of wash mode
Feb 03, 2010 | Washing Machines
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
Washing machine makes a clanging sound during agitation/spin
Without being there to physically see what it's doing or hear the sound, I would say there's 3 possibilities. 1) drive block is slipping on basket drive / brake assembly. 2) basket drive assembly is worn where drive block seats onto it. 3) clutch slipping.
Sep 26, 2017 | Whirlpool Washing Machines
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool lsr8233jqo - will not spin
if you hear the motor running then it is most likely the direct drive coupling between the motor and transmission. part #285753 you can see it from under the machine.477922b.jpg f3941f5.jpg
Jul 16, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
380 people viewed this question
Dan Webster
Dan Webster
Sal De
