Question about Toshiba Satellite A135-S2386 Notebook
Toshiba laptop does not boot up.
Once the power button is pressed, it immediately turns from green to orange and does not boot.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Does this happen when the power cord is used to run the computer?
  • 4 Answers
Hi there this sounds like its going straight into stanby mode, when you close the lid of your laptop while the computer is on it puts your laptop into standby, there is a tiny button or pin underneath the lid which compresses when the lid is shut, try to see if you can find it to see if it is pressed in, if it is just carefully get a small pair of tweezers and try to pull it out without forcing it.
Posted on Feb 04, 2009
Reboot Toshiba laptop
Step One: Remove power (either pull the battery or press and hold the power button)
Step Two: Add power (either put the battery back in or press the power button just once)
Step Three: Press F2, F10, and F12 buttons repeatedly one at a time until boot menu screen displays.
Step Four: Navigate to boot options
Step Five: Boot in Safe Mode
Step Six: Once computer has booted properly restart computer.
Step Seven: (If asked, select launch last known good configuration)
If this doesn't work please send more information.
Image of boot menu screen attached
May 04, 2016 | Toshiba Computers & Internet
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
My laptop wont turn on and yet its fully charge. The power light keeps on blinking with orange and when i push the start button, it turns green and when i stop pushing, it turns orange again-blinking.
Hi.
This sounds like there is a problem with the battery.
Remove the AC mains power and take out the battery from the laptop. Plug AC power back in and try booting the laptop up.
If it boots up let it boot into Windows/linux and then shut the computer down as normal. Remove AC power and re-insert the battery. Plug AC back in and power it up, see if it does the same thing. If it does the same thing the battery is faulty. If it boots up with the battery in then there was a glitch.
Regards.
Jun 08, 2011 | Sony Computers & Internet
Can not turn the laptop on
Hi. Turn the computer on and press F8 when you see the toshiba screen. Select safemode then press enter. open the System Config Utility (msconfig) by pressing Start, Run (XP), or type the word msconfig then press enter for Vista.
Disable all start up items and restart your machine... See if it starts and boots to windows.
^_^
Jun 04, 2010 | Toshiba Satellite A205-S4617 Notebook
Toshiba tecra m1 : can't boot
this is due to the bios problem. check for bios update from service provider then press fn+esc+power button when light start blinking put your pen drive in the usb port after 1 -2 min, it boots up . that files are like flashget etc.
Aug 08, 2009 | Computers & Internet
Canon i560 Ink jet Error Code 5C00
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
May 05, 2008 | Canon BubbleJet i550 InkJet Printer
Starting up problem
I had the same thing. I was passed down this laptop to checkout for a friend. After overviewing the system turns out the processer board got loose. Pushed it back in and she fired up..
Issue was green power led then 2 short orange flashes that repeated untill I discoved the issue.
Feb 22, 2008 | Toshiba Satellite A135-S4427 Notebook
Canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
1. Turn off the printer.
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
Nov 07, 2007 | Canon BJC 8500 InkJet Printer
Toshiba Satellite A135-S2386 Notebook Logo
296 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
