Question about Philips Televison & Video
Is it Digital
I have a Magnavox TV but can't find the manual to find out if it has a digital tuner. Do you know if it has a digital tuner or how to find this out. There is no info on the Magnavox website. I have a Magnavox 32MF231D/37 Need to know if this is digital ready or if it is not, what do I have to do to make it digital ready Thank you
  • Philips Master
  • 1,779 Answers
Yes it is HD ready. You have atsc/quam tuner which means you can receive digital stations by over the air ( rabbit ears or outside antenna) or on cable.Your ready to roll. Hope this answers you question....Have a nice day.
Posted on Feb 04, 2009
The display on my Magnavox zv457MG9 DVD/VCR Combo is blinking.
Fault at its main digital board [System control part]. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 25, 2017 | Magnavox Televison & Video
Is the Magnavox TFT LCD 17 MF200v/17 have a digital or analog tuner?
I believe it has an analog tuner (NTSC) only. The original remote is pictured here: . The TV is listed as having been available in 2004 from The manufacturer didn't have to include a digital tuner until 2005 for 36"+ models. For a 17" TV, they didn't have to have a tuner until 2007.
I hope this helps.
(You'll need to have a set-top box (digital-to-analog converter) to watch over-the-air signals.)
Jan 25, 2016 | Magnavox Televison & Video
I cannot record digital when I try to set up my Magnavox ZV457MG9 (DVD). The unit will only record in the external L1. I have a Comcast box.
This is normal for the ZV457MG9 units. The Magnavox ZV457MG9 does not have an analog (NTSC) tuner; additionally there is no digital (ATSC or QAM) tuner either. It will only record on line in (L1) which is a composite input (limited to SD). The HDMI port on the recorder is an HDMI out to TV, not an input. The component video jacks are also only outputs.
The manual for the Magnavox ZV457MG9/F7 is available here: . The unit was manufactured for Magnavox by Funai; thus another link to the manual is .
I wish that I had better news for you.
(If your DVD/VCR recorder had a tuner, it would record off a coaxial (antenna) cable input. Many DVRs can record off the HD connection (HDMI or component); that may be a better option for replacing this Magnavox unit.)
Oct 01, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
Vcr/dvd combo recording problems
I would need your exact model # to get very specific, but in general:
The "External tuner" will need to come from your TV or a cable/sat box, generally. If your TV has a Video OUT or a Monitor OUT (most television don't), you can hook a yellow AV/RCA video cable from the TV to the Magnavox. You will also need to hook a red/white audio cable from the Audio OUT of your TV to the Magnavox.
Your TV probably doesn't have a Video OUT, so you will need to buy a box. A digital cable box for your cable service would be the best investment. Alternatively, if you can find a digital-to-analog converter box (but these are iffy). Once you have one of these box types, you will need to hook a red, white, and yellow AV/RCA cable from the video/audio OUT of the box to an available video/audio in on your television.
Once your connections are correct, the general rule with tuner-less recorders is: If you can see the channel that you want to record on the television screen, then you will be able to record it.
One final note about Feb 17, 2009: Thanks to Congress, the digital transition date was moved to June 12, 2009 - many areas have already switched, but there is at least a chance that you are in an area that hasn't switched yet.
Let me know the exact model # of your television, and I can tell you if it has a video/monitor out - or, let me know what type of box you decide to buy.
-Tha Mp3 Doctor
Mar 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Does a magnavox model 27ms4504/17 have a digital tuner? Manufactured September 2005
Hi, Sorry it does not. It has an NTSC tuner which is analog. It will work after the change if you have cable or satellite. Hope this helps!
Feb 05, 2009 | Philips Magnavox 27MS343S 27" TV
Is it Digital
go to this website
enter you model # in the search box and search.
This should get you an answer and/or a link to download the owners manual
Please take the time to rate this solution a Fix Ya
Thanks for using
Feb 02, 2009 | Philips Magnavox 27MS343S 27" TV
Phillips magnavox smart plus Model TP3284C101
if there is a DTV label on it , then it is digital .check the manual
digital would have the following : atsc ,hdtv ,digital tuner ,dtv
Jan 02, 2009 | Philips TP3284C 32" TV
Do these Combo TV/DVD's have digital tuners?
if any of these are connected to a cable box you dont have nothing to worry...if not yes you need the converter
Oct 16, 2008 | Apex Digital AT2014DV 20 in. TV/DVD Combo
Is my tv digital compatible or not What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
Here are some general guidelines that may help:
TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
Apr 07, 2008 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
214 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
