Question about IBM ThinkPad T21 Notebook
HD Pavillion Media CenterDv8225nr Notebood Pc. Verticle stripes
I have verticle white stripes on my screen from top of screen to bottom . one stripe is approx. 2 inches wide on the right side of my screen and recently I'm getting pin stripes on the left side. Any idea what is causing this. It's always there on every screen. navincsc
    President:
  • 1,902 Answers
I would try a couple of things. First and cheapest way is to try and update your driver. If that does not work, then try to remove and reseat your memory card(s), and if all else fails you will need to buy a new graphics card approx 75 to 150 depending on how good you want to go.
Posted on Feb 04, 2009
I have a blue verticle stripe that appears in varying intensity. How can I fix this?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Screen shots to defective LCDs are given. You can see and confirm about the fault.
Feb 17, 2014 | Mitsubishi LT-52151 52 in. LCD HDTV
Have a du42px12x plasma lg 2005 model. screen goes half verticle stripes, part time. a swift smack on case will clear up sometimes. bad connection ?
Hi billbrad50,
Yes this is an indication of loose connection. Open the back cover of the unit and then pull-out the connectors from the sustain boards and buffer boards, inspect and then re-insert and ensure that they are properly seat-in.
Thanks for using Fixya.
Jdvillanueva
Aug 08, 2011 | LG 32LH5000 32 in. HD-Ready LCD TV
I own an inspiron 1501. Half of my screen is striped, the other half is working. (Stripes run verticle)
Hii,
Check whether it is working normally when connected to the external monitor. If it is working normally then the problem is with your LCD controller that is located inside the LCD panel itself.
Dec 27, 2010 | Computers & Internet
My tv has a aprx 3" wide black stripe on screen, the stripe is verticle and is always there with tv on. is it worth fixing? thanks
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} in most cases this will be a bad buffer module. this board is called other names but they all do the same work.but a cost will range around $500.00. in some cases it is the display itself and a cost would be more than you paid for the unit. but this is not common.
good luck...
May 24, 2010 | Sony PFM-42V1 42 in. HD-Ready Plasma...
My Vizio Plazma 42in hdtv has a 2inch red verticle stripe on the left side and now the right side of the screen. It is a 4 year old 2400 dollar set I go at Costco.
Hello
This is most likely being caused by capacitors in the power supply changing value. Take it to a reputable repair person.
Good luck
Sep 23, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
I have a 42' LG plasma that has now has a 1 1/2 inch verticle stripe on the right side. It used to come and go but now rarely goes away. Any ideas?
I believe that this could be a type of "burn in". If you watch anything with a black stripe on the sides or bottom of the screen often, then this could be the problem. My suggestion is to watch things that have no black side bars for a while (>week) and see if this eliminates the problem.
Good Luck!!
Jun 11, 2009 | LG 42PC3D 42 in. Plasma Television
Sony kf50we610 hd pink stripes
That's a good one!
If you're using component video cables, make sure they are good and tight. If it's composite video or S-video inputs, you will likely need service.
Sep 12, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Dell 2300 projects verticle stripes accross the projector screen.
this is due to improper power supply or a loose connection inside. the symptoms are of power supply unit inside projector. check out the current and amperes inside the projector on board. sometime the current stable but the ampears are down.also check the switching transistors & filters inside.......
Feb 12, 2008 | Dell 2300MP Multimedia Projector
Portable DVD player
check settings and make sure your player is set to play NTSC AND NOT IN PAL MODE
Jan 02, 2008 | kawasaki PVS-10921 Portable DVD Player
IBM ThinkPad T21 Notebook Logo
174 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
