Question about Seagate STT320000A Travan Tape Drive
Seagate Travan backup gives error code "333 Unexpected bus free".
Backup unit was installed in a new computer and was working fine. After about a week it started with a "hard tape error"; 1st on the Thursday tape- changed tape, seemed to remedy it. But now it is giving the above error code on the last 2 consecutive daily backup atempts. This is backing up 1 unit on a network. No other units are accessing the network while this is backing up. I do not know what the error message means. Thanks for your help; this is my "server" for my small office network and it of course is imperative that I back it up daily, reliably. I look forward to your help. Note I am using all new tapes.
Mark
Bought a seagate backup plus hard drive to backup files, installed on computer but cannot backup files, problem says could not be performed because of anI/O device error.
Connect the external drive to a different computer, and try to copy a few files to it. If you still get "I/O Error", then the unit has malfunctioned.
Mar 09, 2015 | Seagate Backup Plus 1 TB USB 3.0 Portable...
Tip
How to Clean a Travan 40
<p>Travan 40 tape drive, manufactured by the leading data storage and backup device manufacturer Quantum, uses the tape storage business to 40 gigabytes of data. It can be installed on any Windows computer, and works as an additional unit similar to a CD-ROM or DVD-ROM. Like a tape of age, Travan 40 used with the recording heads for data storage on tape. These heads have to be cleaned, and Quantum recommends using a cleaning tape.<br /> <p> <br /> <p>1. Turn on the computer. Remove the cleaning cartridge of your case.<br /> <p><br /> <p>2. Insert the cleaning cartridge into the Travan 40 drive, with the metal plate down. Gently push the drive mechanism that pulls and keeps everything in the device.<br /> <p><br /> <p>3. Look at the LED on the drive Travan, should stop blinking and turns off in about 8 seconds. Note that the LED will remain on the cartridge is used more often than not meant to be used and, if so, remove it and put a new cleaning cartridge.<br /> <p><br /> <p>4. Slide the unit Eject button and hold and pull the exposed sides of the car once the disc is ejected.<br /> <p><br /> <p>5. Record the date on the label of the cleaning cartridge with a marker pen so you can track when your Travan 40 drive yet again and how often you use the cartridge.<br /> <p><br /> <p>6. The return of the cartridge cleaning your plastic box.<br /> <p><br /> <p>7. Repeat the process of cleaning every week if your drive Travan more than 3 hours per day, or every month if you use it with less than 3 hours per day. Clean it twice if you have your computer in an area with a large amount of dust, like a room without air conditioning or a warehouse.<br />
on Jun 21, 2011 | Computers & Internet
I have a Seagate Tapestor 20GB tape drive. I have upgraded to a XP driver but the software does not recognize the tape media to do a backup.
Try to use a cleaning cartridge. If the tape drive is still not recognizing the tape media after you clean it then your heads are bad
Sep 16, 2010 | Seagate Travan TapeStor Travan Tape Drive
Seagate STT63200P Win XP Driver
I would suggest you have to put it on a Windows 95 computer as I have a unit and the Driver should go with a windows 95 just to get your data.
Cheers
Mar 04, 2009 | Computers & Internet
Xp pro repair/reinstall problem
check the connection of your hard disk, its properly conect or not
change the cd of windows and check it,
Sep 28, 2008 | Maxtor Hard Drive
Installed identical replacement STT320000A but won't recognize tape
The STT320000A is IBM version? some IBM version STT320000A will rewind the tape when inserted. But It can recognize the media after rewind. If can't, try to used the cleaning cartridge or change one new media. regards
Jul 20, 2008 | Seagate 20GB TRAVAN SCSI 5 1/4 TPE DRIVE...
DLT V4 Driver
Most tape drivers are loaded from withing the backup software. Symantec and CA work like this. I'd start there.
If not you have to start the remote storage service and check in device manager to see what it defaults to and see if will find the device for you.
Chuck
www.SanDiegoFixMyPC.com
May 06, 2008 | Seagate Travan (stt220000a-sst) Travan...
Backup starts before the scheduled time
Check the system time in the system BIOS, by hitting one of the Function keys. If this is not it, then make sure the time, date, and time zone are set correctly on the desktop.
Jan 17, 2008 | Seagate 20GB TRAVAN SCSI 5 1/4 TPE DRIVE...
Seagate STT320000A Travan Tape Drive Logo
140 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
