Question about Xante AW 1200 Laser Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Posted on Feb 06, 2009
Xante 3G - indicates 'print' then constant 'front paper jam' (any size)
That is cause the paper feeder is not working properly. It could cause the roller that feed the paper wear out or a bad tray release selenoid
Jun 12, 2014 | Xante Accel-a-Writer 3N Laser Printer
Front paper jam xante 3g
Dear you printer paper pickup sensor stuck,please removed all papers in tray and manual feed after that restart the printer,also clear the paper path,hope you understand.
thanks
Feb 19, 2014 | Xante Accel-a-Writer Laser Printer
Red and Green lights both stay on AW1200 and now
The temperature in my office was 38 degrees yesterday. After I turned the heat up the printer "dethawed" and started working normally. I believe the problem was environmentally induced and therefore solved with the more moderate temperature. Thank you for your reply.
Jan 03, 2010 | Xante AW 1200 Laser Printer
Front paper jam
Always try to remove a paper jam without tearing the paper.
If torn, make sure no scraps of it are missing.
Lokk for any tiny scraps, esp stuck on paper path sensor.
Apr 17, 2009 | Xante Accel-a-Writer 3N Laser Printer
HL 2040 paper jam light is blinking but there is no jam. the printer sounds like it dies out everytime it tries to print.
Often the paper jam light will stay on when the *back* paper jam door is not cleared.
Open up the back of your printer. There is a 2nd door behind this door that you can pull open. If there is a paper in this section, pull it out and it should clear your red light.
When clearing paper jams, clear the front first, and then if the red light is still on, you need to check the back hidden door for another piece of paper.
Dec 08, 2008 | Brother HL 1440 Laser Printer
Paper jam
There could be a tiny piece of paper blocking the paper path or sensor. See if you can find any.
Jun 30, 2008 | HP LaserJet 1200 Printer
Paper Jam will not clear
  1. I have identical problem with the Xante 1200.
Mar 14, 2008 | Xante AW 1200 Laser Printer
Front Paper Jam
I'm not 100% sure that this will work. I have a 3N, when we first got it I had the same problem. After clearing the jam - You have to open the top portion of the printer. Even if the jam is no where around that area... the printer won't reset itself until you lift that top piece. I even tried to turn it off, thinking it would reset...it didn't.
I know the 4g is much newer then mine...but being it's the same company.. this problem might be fixed the same way.
Good Luck.
Jan 05, 2008 | Xante Accel-a-Writer 3N Laser Printer
Error LED blinking after paper jam, won't print
I have a similar but different model B4300. Several others, & I have found that a small piece of paper 1/2 square may lodge under a plastic guide, holding open a switch. This is very difficult to notice if you don't know where to look.
Open top lid
Remove the ink cartridge/roller drum as a single unit.
Look in the printer at the metal roller in front.
A Plastic strip on top & in front of the roller covers 2 square holes which should look dark. On your LEFT, as you face the unit, there is a small magnetic switch, to the LEFT of the LEFT square hole, under the plastic.
In my case, the paper was seen as white in the hole, and extended under the switch. I was able to grasp it with a small medical forceps, next to the switch. By gently twisting, I pulled it out without taking the unit apart.
The printer then worked perfectly after the paper under the switch was removed.
Dec 13, 2007 | OKI B4100 Laser Printer
Xante AW 1200 Laser Printer Logo
409 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
