Question about D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337)
Want to use Dlink DI-514 with Qwest modem to hardwire 2 computers
Hi have an older dlink di-514 that I want to use with an Actiontec GT701 modem that I get my Qwest broadband through to hardwire my new computer to the old one long enough to transfer files.
Can I do this?
  • 1 more comment
  • wonder814 Feb 04, 2009
    I don't have the wireless version of this modem and I don't need wireless. Just want to wire the 2 computers together for a month or so.
    I will try your method of reassigning the DI514 a new IP and then try again right after I get some new cable as I think that may be part of the problem as I suddenly can see the WAN on the DLink and couldn't before :) Can also see this puter from the other but neither connects to the Internet through the modem as of yet.
    Any specifics about how to reassign the DI a new IP address?
    Yeo that's the one but I took your advice and bought a cheap switch while I was out getting the cable. The switch was less than $25 and works beautifully.
  • wonder814 Feb 09, 2009
    Yes that's the modem.
    Sorry so slow. Had this working straight through a switch but I had to reformat the HD on the new computer (another story) and now it isn't working at all again. Didn't change any of the settings when I set it up again so don't know yet what I've done wrong.
  • 2,794 Answers
Believe it or not, Actiontec modems from Qwest are setup as a router already (even though ports are missing from it). You should use a switch instead of another router. Otherwise you will have to configure the DI-514 to act as a switch rather than a router. This is done by assigning a new starting IP address into your DI-514. By default both routers use 192.168.0.1 as the default. You will have to plug the DI-514 seperately into a computer (to take it off the network) and assign a new starting IP address for the DI-514 such as 10.150.1.1 for example. Then you will be able to get it work. I would strongly recommend using a switch instead and turn the wireless on the modem itself (this is why the modem is the router). It will save you some headaches if the power goes out.
Posted on Feb 04, 2009
  • Tim Babcock
    Tim Babcock Feb 04, 2009
    It's been awhile since I have set one up. Look in the configuration section and see if there is a way in there to assign an IP address to it.
    I had to do this in my office. It's a pain. I'm used to seeing Qwest giving out the wireless model. Is this the modem you have:
    http://www.qwest.com/internethelp/modems...
D-Link DI-514 Router Firmware Upgrade Error Message
This is an old post, but just in case someone else needs this...
The dlink website for the Di 514 rev B version actually links to the rev C versions' firmware. I got the same error.
browse to here ftp://ftp.dlink.com/Gateway and grab the right version for your rev B device.
Best,
Kevin
Oct 04, 2012 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these...
you should type in 192.168.0.1.
In your request you have:
i can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these componets are hardwired to cannot.has worked fine for years but stopped suddenly!!!!!!!!!!!
Nov 11, 2010 | D-Link AirPlus DI-524 Wireless Router
Unable to access internet through DLink DI-524 wireless modem
I would suggest downloading the manual and check the settings for your country.. it can be found here.
http://support.dlink.com/emulators/di524_revc/h_lan.html
Oct 25, 2017 | D-Link DI 514 Wireless Router (DI-514)
Can not connect to the internet using my DLink 514 wireles router
May be the wifi modem drivier is not installed properly. check it using device management
Apr 19, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I can get on the internet if I connect directly from my cable modem to my desktop, but not if I connect through my dlink di-512 ethernet port, however the wireless works ok on my laptop with the same...
1. check the status lights on the router if they flashing you have lost connectivity.
2.unplug or press the reset button on the back of the router hold in. this will reset the router
3. reboot the PC. this will reset the PC.
4.when connected you will have to update the firmware.
I looked at the manufacturer's site and this router is discontinued but there are resources to troubleshoot this issue
http://www.dlink.com/products/?tab=3&pid=DI-514&rev=DI-514
go to this page above to do further troubleshooting.
Feb 20, 2010 | D-Link DI 514 Wireless Router (DI-514)
How to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
Apr 03, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Hoe do i hook my Dlink up to a cable moden
The way mine is hook up:
1. Internet coax cable to cable modem
2. Ethernet cable from cable modem to router
3. Ethernet cable from router to my computer
Jan 19, 2009 | D-Link DI 514 Wireless Router (DI-514)
D-link 614+ will not connect with Qwest M1000 modem
Well what everybody really doesnt know is that if Qwest provided you with a modem named Actiontech that modem has the same ip address of router so just change routers ip address to 172.16.0.1 and subnet mask to 255.255.0.0 and the problem should be solved.Im a product specialist for dlink.
Aug 27, 2008 | D-Link AirPlus DI-614+ Wireless Router
Connecting 2 computer thru DI-514
Well I believe wat ya need to do is simply obtain a NEW "Account" with NEW Logon & Password with a NEW Internet Service Provider. Then you set up the modem to connect to the new ISP, at the NEW ISP's address, with the NEW Password & Logon. When you got the modem ya should have got a "Setup" CD that should walk ya thru the connection routine... Below is a link for a "Users Manual" that should help you get connected. ftp://ftp.dlink.de/di/di-514/documentation/DI-514_qig_en_Quick-Install.pdf
Aug 15, 2007 | D-Link DI 514 Wireless Router (DI-514)
D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337) Logo
280 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
