Question about Cameras
My Vivitar Series 1 24-70 manual focus ais lens won't work on program in my Nikon FA. I bought both new, but have stored them for a long time. It works on aperture priority, shutter priority, and manual, just not in program. All my other lenses do, including other Vivitar lenses, so it must be the lens. Fresh batteries in the camera. I get the FEE message, which means the lens is not set on the smallest aperture, but it IS set on the smallest aperture. I have tried dismounting and remounting the lens, same thing every time. What can I do? Can it be repaired? Where?
  • deb_huskerfa Feb 04, 2009
    I have tried clicking to the other end of the f-stops and back, still get the FEE message.
  • deb_huskerfa Feb 05, 2009
    That's well worth the $9.95. Thanks
  • 15,935 Answers
You are correct - the lense should work with the Nikon FA!
It sounds like there is a communication problem, and the lense is in need of repair.
Your local camera shop should be able to take care of it. The repair should be less than $50USD.
As long as the aperture ring is set to its minimum aperture, you should not get the FEE error. That little lock tab does not need to be in the locked position, which is for preventing the aperture ring from slipping out of its minimum setting. The next thing I would try is to clean the electronic contacts around the lens mount, on both the body and the lenses. Make sure that you have a good metal-to-metal electronic contact.
Finally - If the lens has an aperture ring, i.e., it is not a G lens, it must be set to the minimum so that you can control the aperture, in its entire range, from the body.
For example, if you have a 50mm/f1.4 AF-D lens and its aperture range is from f1.4 to f16, if you lock it to f16, you can then control the aperture from the body to anywhere between f1.4 and f16, inclusive. If you set the aperture to f5.6, there will be no way it can close down to below f5.6, and the range you could control from the body would have been limited to from f1.4 to f5.6. That is why the body displays FEE to inform you that you are doing something wrong. The Minimum range of the FA is 25mm. You are trying a lense with a lower value of 24mm. Set it on 25mm or above and see if the camera recognizes it.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 05, 2009
  • 11,896 Answers
Check this out, i'm sure it will help
Big difference between Nikon type D and G lenses? [Archive ...
www.dcresource.com/forums/archive/index.php/t-4506.html
  • Nate Stansfield
    Nate Stansfield Feb 05, 2009
    Sure - they'll fit onto the body but they won't work with it. .... Manual focus, manual aperture (as in set it on the lens, because it has no way to tell the camera, it's a non-cpu lens. ... Of course, since AIS lenses were Nikon in cheap mode
    President:
  • 1,990 Answers
DWelcome to Fixya! I am a Licensed PI and have the Same Model. I had almost the Same Lens for my Camera and wound up having to Exchange it and it was OK, Nobody could figure out why it would not Work. Tried everything But, Nothing Worked. It all works like new with the New Lens at this Time though. I would Suggest Replacing that Lens. Please Rate My Response! Thanks!
Posted on Feb 04, 2009
  • 679 Answers
Many times dust particles go inside the leans area cause camera leans not working properly,
so first of all clean your camera using a soft cotton.
And let me know for further assistance
  • Cameras Master
  • 19,396 Answers
Vivitar lens are quite inexpensive, but often give this kind of problems, depending on the camera model you want to mount them. Get better lens.
  • Ginko
    Ginko Feb 05, 2009
    The lens are clearly not faulty, If you keep getting the FEE message that means that there is a compatibility problem between the lens and your camera.
    If you call Nikon support, they will end up telling you the same.
  • Ginko
    Ginko Feb 13, 2009
    Let us know if you have solved your problem and give us feedback according.
    Many thanks.
  • 13,433 Answers
Try adjusting the lens aperture to the opposite end and back, see if it helps the camera to detect that its now on the smallest possible aperture.
  • Ekse Feb 04, 2009
    The lens is most likely faulty, check the contacts and try the lens on another camera.
Will an auto focus Vivitar Series 1 100-400mm work on a nikon d80
Vivitar Series 1 lenses were available with a variety of lens mounts for different camera makes. If the lens has a Nikon mount then it will work on a Nikon D80. If it has some other mount then it will not fit.
Nov 05, 2012 | Vivitar 100-400mm f/4.5-6.7 Series 1 Lens...
I would like to know if a 24mm Nikon f2.8 Ai Manual Focus Lens will work on a Nikon N75 SLR Camera
Yes and no. It will fit and you can take pictures with it. You'll have to focus manually, of course, and you won't get any exposure help from the camera's light meter. You'll have to use the camera in the Manual exposure mode, setting the shutter speed on the camera body and the aperture by turning the ring on the lens and, as I said earlier, without any help from the camera's light meter.
Mar 17, 2012 | Nikon N75 35mm SLR Camera
I have been given a vivitar 70-210 series 1 lens 1:3.5 with a Canon AE1 would the lens work with a DSLR Nikon D3100 - would I need to buy an adaptor ?
No, and no.
The lens will not work on a Nikon camera.
Nikon cameras are deeper than Canon cameras. Even if a Canon lens fit onto a Nikon body, it would not focus at infinity. In order to enable a Canon lens to focus at infinity on a Nikon body, a lens adapter would have to have a negative thickness.
Sep 12, 2011 | Vivitar 70-210mm f/2.8-4 for Nikon AFD
Nikon Lenses
They will fit but will work only in manual mode
Jun 14, 2009 | Nikon 50-300mm f/4.5 Manual Focus Lens...
I can not auto focus this lens on my Nikon D60 I tried to do it as the write up but I need a manual or info Vivitar Series 1 28-300mm f/4.0-6.3
first check if you lens is compatible with the camera.
is your camera a digital or film camera?
this lense is designed for a film camera and is discontinued
May 04, 2009 | Vivitar Series One 28-300mm f/4.0-6.3 Auto...
Lens age
22801413- 22 means the lens was made by Kiron. 8 is the year- 1978. 01 may mean week 1, according to Vivitar serialization scheme. Week 1 is the first week of that year. But I have two 24-48mm Series 1 lenses, and one is a 227000xx and the other is a 22800xxx, so I'm thinking that on the 24-48mm, the only info is manufacturer (the 22) and year (the digit following the 22), and that the rest are sequential serial numbers for that year's run. So yours is the 1413th 24-48mm lens made by Kiron for Vivitar in 1978. Mine are in Nikon mounts- the 227 is non-AI, while the 228 is AI. I recently took them apart to clean the aperture blades, and the internals from the blades back are completely different designs. Both are built like tanks inside, however.
Mar 11, 2009 | Vivitar Cameras
Vivitar telephoto lense 500mm
Yes and no. If it doesn't come with one, you'll need a T-adapter for Nikon in order to mount the lens (you can get one from Vivitar, as well as from other manufacturers). The lens is not an autofocus lens, so obviously you will have to focus manually. It's also a mirror lens so it has a fixed aperture. It's what Nikon classifies as a non-CPU lens, so you cannot use the D90's exposure meter. You will have to shoot in Manual mode.
Feb 18, 2009 | Vivitar Telephoto 500mm f/8.0 Mirror...
Thinking of buying a vivitar teleconverter
If the vivitar 2x is not autofocus, then you will obviously give up 90% of the cameras focus, metering and flash functions. All 2x lenses loose 2 stops of light so the f2.8 lens will now be f 8. If that is acceptable then it may be worth the few dollars to get double the power for the lens
Feb 08, 2009 | Vivitar Series 1 for Nikon AF 2x (318604)...
Lense will not work with SLR Nikon D90
This lens is too old for the D90, it has not got the electronics for metering and autofocus.
You can use it manually in M mode but you will have to set the aperture and shutter yourself.
The D90 manual has a section on compatible lenses, page 228 in my version.
This recommends CPU lenses for the D90, type G and D.
Dec 25, 2008 | Nikon Zoom 80-200mm f/4.0 AIS Lens
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
