Question about Slant Fin GF-240 1.9 Ga Germ-Free Cool Mist Evaporative Humidifier Humidifier
Crust of sediment in hot water pot
When I remove the filter the pot has a crust of (Calcium?) How do I clean it I want to be carefull of chipping the crust and damaging the pot.
  • 257 Answers
Hi, Go to your grocery store and buy some cream of tartar which you can find in the spice section, it is a white water soluble powder. Dissolve about a teaspoon full in a pot of your coffee water, put in a filter with nothing in it and cycle the water through the coffee maker, if it is really scaled up do this a couple of times, discard the filters which probably will have some little white and yellow chunks in it and this should clean up the inside, you may have to soak the pot in the warm water with a little stronger solution. Good Luck!
Posted on Feb 04, 2009
  • Jim London
    Jim London Feb 05, 2009
    Hi, Sorry I confused your humidifier with a coffee pot as that is the category that was on my screen. But as with any device that heats water, and you use tap water it will probably scale. Use the cream of tartar like I suggested as this works really well to remove lime and calcium(scale) without chemicals that you don't want to breathe or drink. Again sorry about that but let me know how it works out for you! Good Luck!
I just installed a Hamilton whole house humidifier but am not getting enough water to the filter. The solenoid is opening for 2 seconds every minute to release the water as it is suppose to do, but the...
Most humidifiers have a strainer on the inlet side of the solenoid valve, if this strainer is clogged up it will reduce the water flow to the humidifer. Usually sediment builds up in the strainer and all you need to do is remove it and clean it up and reinstall it.
Jan 19, 2011 | General Filters 1099-LH Humidifier
I have two questions. How do I properly clean my humidifier and recently it has started coating my furniture with a white powdery film. Why has it started that?
there is some cleaning tablets you can use periodically called protec beads ... cleaning can be done using high acid vinegar soak .. then hydrogen peroxide can be used on any mold .. this unit as well as ultrasonic type models will put out calcium dust if your water has calcium added or is hard water .. calcium is often added to water to give it a good taste .. one way to keep the unit clean for a long time is to use only distilled water .. and make sure there is no calcium added .. (read the small print on the container) .. its hard to clean the fan chamber in this unit .. lots of people complain about the dust .. the wick/filter type humidifiers dont put out dust but the calcium does accumulate on the wick/filter .. so you have to change that frequently (6-9 weeks) .. yours doesnt have a wick but still needs cleaned regularly ..
Sep 26, 2010 | Vicks V4500 1 Gallon Humidifier
I only used my machine for just about two weeks (only in the evenings)with a brand new filter and already the top of the filter has turned yellow/brown and brittle. Is it normal to go through a filter so...
how long the filter will last depends on your water .. if your water has a high mineral content then that is left behind as the water evaporates from the filter/wick ... the yellow brown sounds like calcium deposits .. calcium is often added to water to give it a good taste .. that may be beneficial for you but will build up on the filter .. it doesn't hurt much until it starts to clog the voids in the filter material .. as long as air gets thru then the deposits will be ok .. normally the filter should last about 3 months .. if you use distilled water (with no calcium added) then much longer .. if you have hard water then less .. there is a tablet that you can add to the water to reduce the calcium buildup .. the manufacturer of your humidifier will likely recommend that .. thats often available from hardware stores also ..
so your choices are:
1. don't worry about it until the filter becomes clogged
2. use the anti calcium tablet or something like ProTec PC-1 Humidifier Tank Cleaning Cartridge
3. use distilled water for really long filter life
4. plan on replacing the filter every 3 months
other types of humidifiers have other problems .. the hot water type gets calcium deposits on the heating element requiring cleaning a couple times a year, usually with vinegar or a calcium solvent .. that takes awhile..
the Ultrasonic type doesn't generally have problems with internal deposits because it blows moist air out including the calcium .. that produces a fine dust on surfaces in your house ..
of those types the filter system like yours is easier to maintain than the hot water type and doesn't leave dust behind like the ultrasonic all work better and longer if the water is pure .. distilled water doesn't cost much but you have to be careful .. read the small print .. some of it will say "calcium added" .. you don't want that .. if you use only distilled water then the filter should last the whole year ..
Sep 26, 2010 | Vicks Cool Mist V3500 Humidifier
EE-3191--This is a frog humidifer that i got from toys r us, there is lime (white crust)build up where the water goes how do i clean the inside of it ?
There is a product called CLR (calcium, lime, rust) that will do the job well. It is available at almost all hardware and grocery stores. Be sure to rinse the reservoir well before use. If you use distilled water, you will not get the build up. Hope this helps:)
Feb 07, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
How do I clean my hunter humidifier 33201? the filter blocks have white calcium? built up. I have sick kids and want it to be clean and running properly.
Soak the filters in a solution of 8 oz of white vinegar per gallon of water for about 20 minutes once per week and rinse well.
Better yet, do this once every 2 weeks, and on the off weeks soak the filters in a beach and water solution (rinse well) to keep the mold and bacteria growth from becoming a problem. I also add about a teaspoon of vinegar or a teaspoon of bleach (one or the other, not both at the same time) to the water when I fill the tank.
That helps keep the calcium scale from forming and it keeps the unit itself MUCH cleaner.
Oct 13, 2009 | Hunter 33201 Humidifier
Humidifier filter clogged in one month with white residue
thanks for you question,
the residue that you are seeing is Calcium, it is a natural mineral that is found in all water, the easiest way to remove the calcium build up from your humidifier screen is to use (CLR) it is a calcium, lime and rust remover, a simple diluted mixture with water, then soak the screen for about half an hour, rinse the screen then reinstall, a soft water system would help with the calcium build up as well, but tend to be alittle on the spendy side, your could try inline mineral filters that need replacing yearly, I really hope that helped ansewr your question, let us know with some feed back, thanks again for your question, mr.grzz
Jan 21, 2009 | Honeywell HE220A1019 Whole House...
Appril air 600 wont work
the change water panel light is just a timer. it does not sense that the water panel actually needs to be replaced. sounds like you have a solenoid issue. if you have water to the solenoid and are certain you are getting 24v to it, the solenoid is ethier bad or plugged with calcium. most likely calcium. sometimes you can take them apart and clean them. so, it you can hear clicking at the solenoid when you turn the humidstat up and down. try cleaning it.
Jan 14, 2009 | Aprilaire 600 Humidifier
Honeywell HCM-525 owners/operation manual NEEDED PLEASE!
The filter should be located below the tank. the tank should lift off of the unit and there should be a rectangular cavity where the filter fits. You will most likely find the old filter dried up and filled with a white crust. That is salt and other minerals in the tap water that the filter catches.
Jan 01, 2008 | Honeywell HCM525 Humidifier
Noisy ultrasonic humidifire
The grey circle (diaphram) needs replacing. Try Maplin electronics.
Mar 31, 2007 | Swiss Air-O- 7135 Warm Mist Antimicrobial...
The humidifier doesn't make enough vapor
Soak it with vinegar for several hours then use a soft nylon bristled brush to scrape off the minerlized crust and rinse. You probably need to replace the silver stick & mineralization cartridge more often.
Jan 04, 2007 | Air-O-Swiss 7133 Humidifier
Slant Fin GF-240 1.9 Ga Germ-Free Cool Mist Evaporative Humidifier Humidifier Logo
299 people viewed this question
Top Slant Fin Humidifiers Experts
Jim London
Jim London
Matt Olenzek
Matt Olenzek
Rich Brown
Are you a Slant Fin Humidifier Expert? Answer questions, earn points and help others
