Question about Canon PIXMA iP1600 Printer
Printing wrong color
Before installing a new color cartridge I was printing a project in brown.
After the installation it is printing purple. I tried changing the doc color back to black which it did. Then changed it to brown, and it still prints purple. I reinstalled several times. I know the cartridge is in properly. I can't find my manual. What can I do.
  • 115 Answers
Bad ink, try with original cardridge or use a profiler.
Posted on Feb 04, 2009
Why won't my printer print purple?
Your Cannon printer is not the problem. You will get different print color depending on the paper you are using, For example you will get different print result if you print on color paper than on white paper and a different print if you print on photo paper. Another alternative is to lighten the tone of your purple. I don't know what your objective is and what project you're working on but I hope this might help.
Apr 26, 2014 | Canon MG5150 AllInOne Printer
Color cartridges are full but colored pictures are gross
Use the HP print utility and run through the tests. One bad cartridge will muck up the color completely.
There should be a clean print head option. Run it if the initial color test shows a clog.
Mar 20, 2014 | HP PhotoSmart Office Equipment & Supplies
Printer wont print the color brown
Try cleaning nozzle with dry paper towel, cartridge should leave 3 streaks: Yellow, Cyan, Magenta.
If colours on paper seams to be tinted or mixed the cartridge needs to be reclamated, there is no other solution.
If there is an lack of one or more colours try to wipe nozzle with wetted paper towel in window cleaner. After few wipes, 3 colours sholud apper
Oct 21, 2012 | HP 60 Tri-Color Ink Cartridge
Colors are off. Browns print green or purple. I
BROWN is made by mixing two of the three "primary" colours.
So, if the printer is out of RED ink, you'll get the "other" primary colour.
Print a "test" page, and verify that part of that page is RED.
Run a printer "cleaning" cycle, and consider replacing the RED cartridge.
Jan 08, 2010 | Canon i860 InkJet Photo Printer
I have a HP 4100 printer. Installed new ink.Purple streaks
That's a neat trick. The 4100 is a printer that uses one BLACK toner cartridge. It doesn't print in color. And it doesn't use ink.
Oct 24, 2009 | HP LaserJet 4100 Printer
Can't print in color
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark JetPrinter Z11 InkJet Color...
I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
May 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
Scanned pictures are printing with different colors
Are the ink cartridges refilled or compatible? They may be defective.
Are they installed correctly (not in the wrong slots)?
** Note that even if they are replaced it will take SEVERAL pages before the quality returns
Mar 11, 2009 | Canon PIXMA iP90 Mobile Printer
Installing without the disk
Gabbyone, Here is the page to download drivers for your printer. Just click on the link for the appropriate operating system you need: http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:525:0:0&emeaframe=&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&&req=::::: As far as why is it printing purple it could be several reasons but some common ones are; you?ve run out of a particular ink color, one of your ink jets could be clogged or damaged, your cartridge was refilled wrong and on occasionally a software driver gets messed up. Reinstall your printer, do a test and if it still prints purple try running your printers nozzle cleaning utility. If that fails post another questions and give us some history, how long has it been since you?ve printed, are you using new Lexmark or refilled cartridges and any other pertinent information.
Feb 28, 2007 | Lexmark Z611 InkJet Photo Printer
Canon PIXMA iP1600 Printer Logo
361 people viewed this question
old marine
old marine
