Question about Coleman Powermate Proforce 2500 Generator
Remove generator from engine
Briggs vertical shaft
green cart
2500 watt
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 55 Answers
Pull the end off the generator and you will have to buy or borrow an armature puller to remove the armature. It threads into the end of the shaft and pushes it off. I've seen many people destroy their generator by prying with screwdrivers. The engine has a tapered shaft and is sort of useless for any other application other than a generator.
Posted on Sep 09, 2010
Neighbor has a Briggs & Stratton Elite Series 5550 generator. How do you remove the generator from the engine. Need to repair oil capacity switch inside.
Hello; The Briggs engine front case is shaped to accommodate the internal mounting of the Alternator section. A service manual for this model would be very helpful. I believe you need to dismantle the back of the Alternator where the outlets are and then the outer case with the stator windings in it. This will leave the rotor ( the long shaft with windings on it ) which will be attached to the output shaft of the engine by some coupling device the you must dismantle. John
Aug 15, 2011 | Briggs & Stratton Power Products 5,550...
Engine runs fine but not putting out any power. thanks
Is the engine turning the shaft to the generator ? if it has a coupling device is it intact .. is there a reset button on gen output does it need reseting. or is it not working...
Apr 01, 2011 | Briggs Stratton Portable Generator 305cc...
How do I remove the case from the generator on a B & S motor / power boss 030249? the gov. is fried.
take the end case off the end of geny 3 x 10mm bolts?
on the end of the geny shaft is a 10mm bolt wip it out,
the geny is held to the motor by 3 or 4 bolts wip them out too,
then with a sharp rap on the geny case near the motor end the geny should pop off the taper its held on to the engine crank shaft,,,there tight as well!
Jun 26, 2010 | Briggs & Stratton Power Products 5,550...
How does the generator come away from the engine? regards dan
Most of these one removes the field and then a bolt is inserted in the end of the shaft and a slide hammer is used to pull the rotor loose. There is usually a Woodruff key to the engine shaft.
May 14, 2010 | Yamaha 2500 Watt Industrial Inverter...
Engine races
One thing I read is that on some the arm from the govenor shaft can slip on the shaft so the arm is rotated on the shaft to a point the govenor isn't even in contact with the internals driving the shaft. On those units a clamp bolt becomes loose causing the problem.
I suspect if there IS an internal problem it is severe and one would have to disassemble the engine before operating it lest damage occur from loose parts.
Mar 24, 2010 | Briggs & Stratton Power Products 5,550...
My propane generator engine has apark and gas
For a quick test.
Check engine oil.
Remove wire from low oil sensor and see if it starts every time.
If that works change oil and replace low oil sensor.
Hope this tip helps to solve your problem.
r/
David
Jan 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Have crafsman 5500generac generator need to seperate genhead from
Remove all wiring. Remove four stator bolts. Remove stator. remove rotor through bolt tap end of rotor us a shaft in the rotor tighten bolt in tapped hole to remove rotor.
Mar 25, 2009 | Watts Onan Portable Generator - 4000 ,...
Coleman Powermate Proforce 2500 Generator Logo
416 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
