well summer is coming and that means are three/fourths finished basement is going to suffer from humidity. i plan on getting a dehumdifier (50pt model should be enough i hope, 1300sq ft, 7ft ceiling) but don't want to empty the bucket constantly.
what condensate pumps are recommended that are quiet and reliable? also, is there any particular place a dehumidifier should be kept (i.e. closer to the window, center of the dehumidification area, near the dryer...)?
the back of the basement is unfinished, there is a washer/dryer and a sink. i was hoping to run the hose to the sink but it's about 40ft from the center of the finished area (if that's the best sopt for the dehumidifier).
i was looking at little giant pumps but i can't tell the difference from model to model. hartell maybe?
You can buy a condensate pump with a built in sump and float used for furnces and central ac at home depot or Lowes for around $50.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Aug 01, 2007
herself - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I've heard that dehum should be about three feet from the floor. Not sure where I heard that.
The Little Giant condensate pumps I've seen should handle that load, easily.
Do you have central AC? Makes me wonder if you can include the cellar air into the air flow, and use t he evaporator from the AC system as your dehumidifier.
Christopher A. Young You can't shout down a troll. You have to starve them. .
... well summer is coming and that means are three/fourths finished basement is going to suffer from humidity. i plan on getting a dehumdifier (50pt model should be enough i hope, 1300sq ft, 7ft ceiling) but don't want to empty the bucket constantly.
Was this helpful?
Yes
No
Solution #4
Bomber - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
A pump wouldn't need to move much water very fast in that application. Almost any low volume pump would work. I would wire it in series with a float switch (and possibly a control relay depending on supply voltage and rating of the float switch I get).
Lowest cost would be something like a fountain recirculation pump or one used in a diamond wet saw. They operate like a sump so they need somewhat deep pool to sit in.
A pump capable of draining the tank dry would cost a bit more but would be compact and neater as it can be connected anywhere along the drain tube.
Was this helpful?
Yes
No
Solution #5
Mini Me - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
i considered that but i thought it might be messy to look at unless it was in the back near the unfinished area. i was worried if i put the dehumidifier in the back area, the finished area wouldn't be as well dehumidified.
Was this helpful?
Yes
No
Solution #6
Kim1 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Dehumidifiers have drains just hook up a hose and raise it up so it drains the 40 ft, it doesnt need to be in the center of the basement.
My Soleus dehumidifier has stopped working after one year. The fan is running, the compressor seems...
(More)
My Soleus dehumidifier has stopped working after one year. The fan is running, the compressor seems to be hot and it is not condensing water. I have the controls on high and continuous run.
is there a reset switch for the compressor? The compressor is not running and the fan is. I even...
(More)
is there a reset switch for the compressor? The compressor is not running and the fan is. I even switched it to continuous run and the compressor still doesn't kick on. Blowing cool air.
My Soleusair 40E dehumidifier is not pulling the water out of the air. Lights are on &...
(More)
My Soleusair 40E dehumidifier is not pulling the water out of the air. Lights are on & running noises but nothing in the bucket for days; Just brought it about 10 months ago. I was hoping for a longer life than 10 months.
