Question about Desa International GWP20T GLOWARM Wall Mounted Panel Heater
Glo Warm propane heater won't light
Unit is not new (I bought it 5 years ago) but has never been used. I have a 100lb bottle and a 25 ft hose off the regulator connected to the unit. The pilot will light but the flame is extremely small and doesn't come anywhere near the thermocouple. I tried adjusting the regulator but I can't get the size of the pilot to change. If I heat the thermocouple with a lighter the main gas will come on but the unit goes out as soon as the thermocouple cools off.
  • elaine warfield Feb 06, 2009
    I just had this problem, which might be the same. It is the thermocoupler, which DESA tells you they no longer have. So I had to buy a new one, and did not buy from DESA. Mine was only 6 years old and used once in a while.
  • scamp36 Feb 11, 2009
    Mine was lighting fine but wouln't stay on so I cleared the air vent in the side of the piolt. worked fine the first time. now won't light at all.
  • 92 Answers
There is really not a lot to go wrong with the heater itself so my first guess would be that the regulator is bad, not letting the proper amount of gas through. You can check it for leaks with a bottlee of soapy water but even if you don't see a leak there is a rubber gasket inside with a pressure spring that is probably bad.
Posted on Feb 04, 2009
Pilot light wont light will spark, but no propane
verify the inlet pressure to the heater. those pezioelectric spark lighters are garbage. make sure all manual shut off valves to the heater are open. Pilot tubing may also be blocked
Nov 25, 2013 | Glo-warm 503284 30000 BTU Propane Gas Vent...
My father died 11 years ago and he bought a Glo-Warm Vented heater for propane gas only. It has never been used as we found it still in its box in an old attack. Can I use this to our natural gas system?...
check on line google make modle serial number btus etc and ask for nat gas converstion kit , age could be the problem here ,or try national energy they are on line or google the makes and ask them direct
Mar 27, 2011 | Heating & Cooling
I have a Glo-Warm "DESA GWRP16" LP wall heater.
sound like the reg is locking up turn off gas then turn on very slow see if you get gas flow , if not then you could try new reg
Nov 29, 2010 | Desa International GWRP16 16,000BTU LP Gas...
I Need to know whaat type of regulator is need for model ssu320rhl-gb Please
Here is a link to the owners manual and page 8 and 9 tell you about the regulator.
http://www.northerntool.com/downloads/manuals/177883.pdf
You need to a 8-11WC regulator for propane and if you are using natural gas you will want to keep the pressure between 3-10WC
If this is connected to a propane bottle you want o use at least a 100lb bottle.
Thanks
Oct 15, 2010 | Procom SSU320RHN-GB Heater
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Century Dyna-Glo Propane Construction Heater, fan stays on?
The heater is designed to continueously run the igniter , so as if there is a flame-out ,it will reignite the burner,and not dispurse unburned gas into your enviroment.
Jan 11, 2009 | Century Tool 2320I Heater
My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Nov 03, 2008 | Desa International Blower Glow Warm Wall...
Glo warm?
u need a 100 lb tank minimum for the heater to operate properly
Oct 19, 2008 | Desa International Blower Glow Warm Wall...
Dyna glo RMC95C6 kero heater
I suggest you replace the wick and clean the wick feeder assembly. I did not own that model but did have one a number of years ago. The wicks can begin to dry out.
Jan 08, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Desa International GWP20T GLOWARM  Wall Mounted Panel Heater Logo
463 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
