Question about Samsung L100 Digital Camera
Short video I have just purchased a samsung L100 and when I try to video anything { I have no memory card } after a couple of seconds it says memory full. I am not very technical and am not sure what to do?
If you do not have a memeory card then you will not be able to record a long video as this camera only comes with 10MB. You will need to buy a memeory card.
Posted on Feb 09, 2009
How do I copy the internal memory to external memory
how about copy the pictures with partition wizard?
Jul 20, 2012 | Samsung L100 Digital Camera
I have a samsung l100 cam.but my cusine destry the lens.so what can i do please say..........................
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 25, 2011 | Samsung L100 Digital Camera
LCD screen comes on for about a second, lens extends then detracts at the same time then there are 3 distinct beeps then goes off. Full battery.
did you drop it? water damage?
if not, its a memory card or main board problem..
i hope youre under warranty...
take it back, or try the memory card in a different cam
Feb 17, 2010 | Samsung L100 Digital Camera
Digital camera
personally i never connect the cam to pc using the usb cable, i take the memory card out and put it in an sd card usb adapter, you say the images are protected, this tells me that you have the lock switch activated on the sd card...hope this helps :)
Jul 11, 2009 | Samsung L100 Digital Camera
You asked me to clarify my issue with an Acer Aspire L100. My problem is, there is no video output from the system. It appears as if the onboard video has gone out. The unfortunate thing with this mini...
You do have 1 PCI slot in that system. So, you could purchase a video card and place in that slot. Since your video is on-board you'll need to disable in Control Panel - Device Manager. Good luck.
Jun 19, 2009 | Acer Aspire L100 PC Desktop
Pushed the Format button on my L100 Samsung Digital camera and my memory card was erased??? Please explain this?
formatting the memory card automatically erases all the files in the memory card.
it's like restoring the memory card to factory settings to be compatible with your camera.
when you format the memory card using the camera the camera erases everything then creates folders that the camera needs to store pictures in your memory card.
you can try to look for software that can TRY to retrieve the images but i cannot assure you that this will work
May 31, 2009 | Samsung L100 Digital Camera
Memory card isnt recgognised!
If the card is inserted correctly and its not damaged, then the memory card should show up under media manager, you need to put the files onto the memory card not on the phone...
When you first insert the card into the phone, you need to format the card, some phones create specific folders for different things when they format, e,g images, Videos, etc. You may need to do this.
I cant remember if this phone had this option but try it anyway as if it works, it should be faster than using Samsung PC Studio...
Close Samsung PC Studio
Unplug USB out of the Phone and a couple of seconds later plug it back in, see if the phone asks you for Mass Storage mode... If it does select that, after a while the Memory Card should show up on your PC just like a USB memory stick you can drag and drop files to it and its faster than going through Samsung PC Studio :)
May 09, 2009 | Samsung C417 Cellular Phone
Card error on L100 samsung camera, help please.
copy all the pictures/files saved in your memory card to your PC then format the card, you can format the card by going to MENU > SET UP > FORMAT
make sure that you have a copy of the files in the memory card because formatting the memory card will erase all the files that are saved in it.
Mar 04, 2009 | Samsung L100 Digital Camera
SAmsung L100
take out the memory card look for a lock tab at the side of it, push it up and insert the memory card back. that should do it
card lock is a feature of the memory card so that you won't accidentally erase the files that are saved in it
hope this helps
Feb 01, 2009 | Samsung L100 Digital Camera
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
Samsung L100 Digital Camera Logo
55 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
