Question about Canon PIXMA MP470 All-in-One Printer
Trying to print a webpage and get error code 30.
Downloaded regcure but didn't help. It said I had 800 problems to fix but it only fixed one. I have a canon pixma mp470
I made a dumb mistake. i had the wrong name in the "print" screen. instead of canon mp 470 i had quicken pdf printer. that's why i got the error code.
Posted on Feb 05, 2009
I hv error 6266 in tally and m not able to fix his error pls suggest me the way tom resolve this error
Causes of the error:
Windows Tally Error 6266 are caused by misconfigured system files.
So, from my experience, If you received a Tally Error 6266 message then there is a 97.5% chance that your computer has registry problems.
The Windows Tally Error 6266 are easy to repair. By downloading and running the registry repair tool RegCure Pro, you can quickly and effectively fix this problem and prevent others from occuring. Simply click the links below for your free download.
To Fix the problem you need to follow the 3 steps :
STEP 1:
Download & Install RegCure Pro for Free.
NOTE: If the download link doesn't work you may need to Download it Directly from a Mirror Here.
STEP 2:
Click "Quick Scan" Button to Scan Your Computer.
STEP 3:
Click the "Repair All" Button to Repair Your PC!
Nov 05, 2015 | Computers & Internet
How to remove from the error 5201
What Type of Printer is it? Each Company has their Own Trouble Codes...
Cannon for Example"
Problems with Error 5201
Cause: 5201 errors usually are caused by misplacement or broken system registry
structure.
Note: This is also a critical sign of an unstable system that is usually caused by improper
maintenance of the computer
Solution: RegCure is a Microsoft Certified tool that is tested to repair issues with code 5201 errors.
Download & Fix with Regcure Repair Tool Free!Windows 98/SE/ME/XP/Vista Compatible
Regcure Additional Features:
Repair ALL detected Registry Errors instantly!
Optimize PC's performance up to 300% Faster!
Prevents Freezing & Crashes - Completely!
Increase Window's Boot & Programs Speed!
Advanced Windows configuration settings!
Error Code 5201 Problems
JavaScript / Scripting Errors
Internet Explorer / Active X Errors
EXE / DLL / OCX Errors
Virtually all Windows related Errors!
How To Use:
Step 1: Download & install RegCure Repair Tool for FREE!
Step 2: Scan your computer
Step 3: Click the 'Fix Errors' button & your DONE!
Apr 12, 2013 | Office Equipment & Supplies
I can't print in my Canon Pixma IP1980... service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix...
service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix this?
Dec 08, 2010 | Canon Office Equipment & Supplies
Physical memory dump at working this error comes after 5 to 7minuts latter when system starts please help
When someone receives the error message,
“Physical memory dump ", usually accompanied with a blue screen. Chances are there is a possible problem with your memory. Before you download memory testing software, let’s try downloading some free software. RegCure is free to download. http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
RegCure will clean windows registry. It will safely remove problem keys.
If RegCure doesn't fix the error message try the next link; http://www.findmysoft.com/news/Free-Software-to-Clean-your-Windows-OS-Cleano-and-Instant-Memory-Cleaner/
Lastly, download & run Memtest86+ at this link; http://www.memtest.org/
Scroll down until you see the 3 screenshots. Choose the testing software to create a bootable floppy disk. This software will test your system memory. If Memtest86 finds a problem you will need to replace the problem memory stick.
Read each site & follow their instructions.
Thank you for using Fixya.
Mike
Download - Pre-Compiled package for Floppy (DOS - Win)
Aug 25, 2009 | Computers & Internet
Dell 926 will not print black and gives alignment error
Has this printer been sitting for a period of time? Inkjet nozzles will dry up...replace the cartidge, even tho it may be half full, it prolly has dried out
Jul 24, 2009 | Dell 962 Photo All-In-One InkJet Printer
I had the C:Program/myweb2/bar/2.bin/m3plugin.dll
What is the problem? Most of these "Reg Dr" type products do more damage than good.
May 28, 2009 | Intel Motherboard
The system cannot find the file specified. (0x80070002)
Problem with 0x80070002 Error? Don't Worry - i'm here to help you fix it!
0x80070002 Errors are caused in one way or another by misconfigured system files.
So, If you got error 0x80070002 then there is a 94% chance that your computer has registry problems.
To Fix the problem you need to follow the steps below:
Step 1 - download and install RegCure Registry Scan for FREE.
NOTE: If the download link doesn't work you may need to Download it Directly from Regcure Site Here.
Step 2 - Click the Scan Button.
Step 3 - then click the Fix Button and you're done!
May 12, 2009 | Computers & Internet
Error 17? what is that?
Error 17 Codes are caused in one way or another by misconfigured system files.
So, If you got error 17 then there is a 94% chance that your computer has registry problems.
Download and install RegCure Registry Scan for FREE.
Mar 02, 2009 | ASUS Eee PC 900 Notebook
PS3 update problems
Hello!!
Ok, no matter how you try to install the firmware it will always write it to the hard drive first before install. Now if it gives you the 800 error while downloading it's your hard drive and it may need to be re-formatted or replaced. If you get an error during installation, then therewas a misplaced piece of code during the download and it needs to be downloaded again.
BTW, the power button default reset is ONLY for the Video output settings.
Hope this helps. Good luck and happy gaming!!
Oct 22, 2008 | Sony Playstation 3 (PS3) Console
OCR program
You have to install a programe called: ABBY FineReader 5.0 Sprint. Although there are newer editions available, this is the programme that comes with the cd and is available to download free of the net. Hope this helps.
Feb 08, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Canon PIXMA MP470 All-in-One Printer Logo
90 people viewed this question
old marine
old marine
