Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The washer just stopped pouring water. Only faint humming sound.
Today I loaded and started my washing machine, just as always. A few minutes later, I noticed that the laundry room sounded quiet. When I checked on it, I found that a little bit of water had begun to pour in but then it just stopped. I could hear a very faint humming until I turned the dial to off. Of course, I then tried just adjusting the dial to reset the wash. All that happened was the light humming sound began again until I rotated it to off. I'm stuck. Could there be a simple solution?
  • kimberlymfar Feb 04, 2009
    Good news for me! You were right - it's a water supply problem. I called the water department and we figured it out. Our water had accidentally been cut off. I didn't realize it until an hour later when I tried to use the sink. Thank you for your help.
  • Mark Egan May 11, 2010
    Turn the water off at the wall behind the washer.
    Pull the washer away from the wall and disconnect the hoses at the washer. Look inside the hose, and inside the washer connection point and see if there is a plugged screen.
    If there is no screen in the hose, then bend each hose, one at a time, back to the wall and stick down into the drain. Turn the water on for that hose and make sure you get flow. If you do, you've identified if the problem is a water supply problem from the house, or that it's inside the washer.
    Reply back what you find.
  • 1,214 Answers
How 'bout a FixYa for the effort, and let me know if you need anything else.
Posted on Feb 04, 2009
My Miele W1119 washer won't run. It was fine earlier today and I just completed a load of wash. When I started the next load on the Normal cycle, the timer lights to 58 minutes as always and the...
sounds like bushes mine done the same changed them now all good check it is not leaking water on to the bottom of machine this will activate the sensor to stop washing and drain water
Jun 04, 2017 | Miele Touchtronic W1119 Large Capacity...
Washer stop before completely filled with water.
beko washing machine when turn it on it trips
Dec 12, 2009 | Kenmore Washing Machines
Bleach leaking out bottom of washer.
Not sure what model yu have since there is none posted but sounds like the hose from the bleach reservoir has come loose.
Sep 15, 2009 | Kenmore Washing Machines
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Front load kenmore washer model 417 will not enter any wash cycle. It will do the rinse and spin cycle but not a wash
will it fill with water? if not listen by the water hose when you press start to wash and see if you hear a faint buzz/humming sound. If so you need to replace the water inlet valve. cheers
Mar 25, 2009 | Washing Machines
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
117 people viewed this question
Dan Webster
Dan Webster
Sal De
