Question about Hoover Vacuums
How to remove the bag housing from the handle in order to replace the power cord on a Hoover vacuum U5209-930
Trying to replace the power cord on a older Hoover Vacuum U5209-930. I successfully removed the handle from the base by removing the nut and bolt that secures the handle to the base. During assembly, the vacuum cleaner manual says that the bag compartment attaches to the handle via a tab on the bottom of the bag housing and via hooks that go into slots in the handle. I have tried to remove the bag compartment in order to replace the power cord which is secured inside the handle...but have been unsuccessful. Any tips for releasing the hooks from the slot without breaking the hooks? Thank you!
2 Suggested Answers
Andriod Man
  • 271 Answers
SOURCE: How do you disassemble the handle to replace the
bad news to you.(don't get mad at me please). 2 prong means is a "DOUBLE INSULATED" vacuum. any electrical repairs are not recommendable other by a shop because after repairs they have to test for grounding with a special meter to prevent electirical shocks. for that reason I personally can not give advice on how to do it. if you want to take the risk, well.... good luck to you. I do this for your safety and ours. I hope you understand my position.
Posted on Feb 09, 2011
Testimonial: "I appreciate the quick responses and I'm not mad :). I did contact a local repair place prior to posting here but wanted to try it myself. Thanks!"
How do i open a hoover vacuum cleaner
Leave this to a professional. You can set the house on fire with a shorted out vacuum.
Jan 30, 2014 | Hoover S1361 Bagged Canister Vacuum
Can I get a replacement handle for a hoover wind tunnel upright? It snapped off
That part is available. Includes the handle, cord and "digital" switches. Here's the link:
http://www.vacuummedic.com/product.php?id=389
Good Luck!
Vac Dr.
Sep 29, 2012 | Hoover UH30010COM Bagged Vacuum
How do you change the power cord on the Hoover u5475-900 Wind Tunnel 6200? Thanks for your help.
This procedure worked for replacing the cord on my Hoover U6425-900. At a minimum, you will need a number 2 Phillips screwdriver, wire cutter, and two electrical wire nuts and electrical tape. Remove the accessory tools from the storage compartment. Remove two screws, these are recessed. Remove the cover from the bag compartment, remove two screws located at top corners of bag compartment. You may have to open the side filter door but the accessory tool storage compartment should be free at this point and can be removed. You should see the power cord and related wiring. If you have a digital camera you could take a photo at this point in case you need a point of reference. Make note of the power cord strain relief routing and length of wire. Too much wire will make reattaching the storage compartment difficult and the routing prevents the cord from being pulled out.
On my model the wiring colors were purple, orange and white. My replacement cord had black and white wires. The orange wire will not be involved in cord replacement. Using the wire cutters clip the purple wire about three inches back from the existing terminal. If present, clip the two nylon wire ties and discard. The white wire will have a crimped on wire connector. Clip the white wire about three inches back from the existing wire connector. The old power cord can be removed by pulling it out from the rear, it should just slide out of the rubber insulating boot. If not use a set of pliers and crimp the boot from the wiring side and push it outside the vacuum housing. If you have to do this make sure you slip the boot over the replacement cord before you insert the new cord back into the vacuum housing. Remove about a half inch of insulation from the purple and white wires and from your replacement cord unless it was supplied with insulation already removed. Use new wire nuts and connect the white wires. Use the other wire nut and connect the purple wire to the remaining new power cord wire. Use some electrical tape and wrap the nuts to the wires a couple of times so they won't loosen. Make sure you route the power cord around the posts as this is the strain relief and prevents the cord from being pulled out. Reassemble and test.
Feb 03, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
How to take apart to replace power cord
In order to access the cord on the Miele S183 upright, you'll need to first remove the handle from the vacuum cleaner. There is a large screw that holds the handle in place that is located under neath of the lower cord wrap hook. Simply remove this screw, and slide the off the vacuum by pushing the handle towards the back of the machine.
Once you have the handle removed, now ope the bag door as if you were going to replace the vacuum bag. You'll see two screws directly above where the bag fits inside of the machine. These two screws will open up the switch and cord housing and give you access to the electrical cord.
You'll see that there are two screws that secure the cord as it comes into the vacuum from the back. Remove both of these screws so that the cord is no longer secured. I think the easiest way to replace this cord is to simply cut the cord (MAKE SURE THE VACUUM IS UNPLUGGED) so that there is about 4-5 inches of the cord jacket (rubber coating around the cord) remaining. You may now just pull this cord jacket off of the cord, along with the paper insulation so you have two bare wires of the old cord. Now take your new cord and push it into the back of the vacuum so that it comes through the switch housing. Instead of having to re-secure the cord with the two screws, I've found that if you tie a small knot in the cord, this works just as well at preventing the cord from pulling through the back of the vacuum.
Simply strip the wires that are left from the old cord, and simply wire nut the new cord after tying a knot (or re-securing it with the two screws), and reassemble the vacuum cleaner. Test the vacuum only after putting the switch housing cover back into place.
If you have any questions about how to do this repair, please feel free to use the clarification request form here on the Fixya repair page. If you found this helpful, please be so kind as to rate my repair as helpful by clicking on the 4 thumbs up icons in the top right hand corner of the repair. This is what keep Fixya's repair professionals continue leaving free repair advice on this site.
Here's a link to a blown up parts diagram to help you visualize how the vacuum comes apart.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/miele-s183-upright-parts-diagram.gif
Feel free to check out our website for any Miele supplies that you need:
Miele Vacuum Bags, Filters & Belts
Thanks again for rating my repair,
Chris J.
GoVacuum
Apr 07, 2010 | Miele S183 Powerhouse Bagged Upright...
The power button quit working
Please click here to see the part diagram for the Hoover Windtunnel Self Propelled model U6446-900
Greetings from GoVacuum,
For replacing the switch, you need to remove the 2 screws that are in the back of the vacuum where the handle connects to the vacuum bag housing, Part # 50 on the first page of the diagram. After the screws have been removed, you may simply slide out the handle from the rest of the vacuum cleaner. You can then at this point view the outside of the switch, however as you'll find you can't replace it from this side. You'll then need to go into the where the tool caddy is in the front top part of the vacuum cleaner. Remove the attachments from the tool caddy, and then you'll need to remove the screws that hold the tool casing in place. Remove screws pictured # 35 on page 1, and the tool caddy is item # 17.
Once the screws and the tool caddy are removed, you may then see the rest of the switch, and the leads that connect to it. The easiest way to remove the screw is to use a flat head screwdriver and pry the switch out from the back of the vacuum cleaner after removing the leads from the switch. The new switch that you'll need to purchase is Hoover part number 28161067 which can be found online here: Hoover Windtunnel Main On / Off Switch Part Number 28161067.
I hope that this helps you replace the faulty switch in yours (and your parents) vacuum cleaners. If you need to place an order for the switch, please give us a call at 1-866-468-2288.
Thank you,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Hoover U6446-900 WindTunnel Bagged Upright...
Bad on/off switch hoover U6476
It's probably the power switch. My switch was dicey for a couple years, finally gave out. Easy to replace.
Remove the two screws just above the WARNING on the rear of the upper handle assembly, then slide the whole assembly to the rear of the vacuum.
Remove the dust bag cover. You will see two holes just above the upper corners of the dust bag. Remove the screws from these recessed screw holes.
Open the furniture cleaner cover and remove the cleaner attachment. Remove the single screw that was hidden behind the attachment. Then remove the attachment housing by pulling it towards the front of the vacuum.
Inside you will see the rear of the power switch. Pull off the power wires (don't worry, easy on/off male/female connectors, no soldering).
The switch is held in by tension bars at the upper and lower rear of the switch. Firmly press down on one of both of the upper/lower tension bars, and push the switch through the housing from the rear of the switch.
Replacement part number is 28161067, about $2.50. Shop will charge about $85 to repair it themselves.
Feb 01, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Replacing the electical cord on Kenmore Progressive Vacuum
To the right of where the cord comes out of the machine is a large screw. Remove it, and slide the upper handle assembly free.
Then, on the front of the machine, remove the screws located toward the top of the vacuum just inside the bag chamber cover. This will allow the front panel to be removed, giving you access to the cord from the front.
-R
Sep 15, 2008 | Kenmore 31913 Progressive Direct Drive...
Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Jan 26, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel
If it goes in just at the bottom of the handle, take off the handle, then remove the tool holder, then you can replace the cord. If it goes in near the bottom, then you will have to remove the motor cover and light to get to the connecting wires.
Oct 11, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
27 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
