Question about Quartet gbc 30S Shredder
My GBC shredder has slowed to a snail's pace and won't turn off.
I've used it at my home almost daily ffor several years for mail with no problems. But just within the last month, it has gotten slower and slower to where I can even smell the motor burning and it won't switch off on its own. Might it need oil? I've never oiled it. If so where would I put the oil? Or might those oil sheets be better? OR did something become dislodged when my dog dumped it over repeatedly? If I were to open it up might I be able to fix something? Thanks for whatever ideas you can give.
I guess I have to say Thanks but No thanks. The gal from the company said that most likely the small piece inside the blades got broken off when my dog kept dumping the container so that it can no longer turn off on its own. As far as its slowness, maybe oil or age was the issue. Anyway I was able to find a similar style on line and already purchased one. BUT I will definitely remember your site for my next repair. Do you just do tech equipment or is other small electrical equipment included as well??? My thanks for your response.
Posted on Feb 05, 2009
Why is the motor of my sears kenmore sewing machine model 385.12714 running really slow? The machine has not been used for at least a year or two. We oiled it. It is sewing, but at a snail's pace.
it could be different things
have you checked to make sure the plug is correctly in the machine
one time I was sewing on my necchi electronic machine & it for some reason was going slow like you mentioned & so I started checking different thing & found the cord to the foot pedal was laying in side the foot pedal & it couldn't go any faster untill I moved the cord out of the way
it could also be the motor
& also the power cord & foot pedal
it's possible it needs to be serviced since it's been sitting up so long & since it's sewing at a snails pace
Sep 11, 2011 | Kenmore Sewing Machines
Modle AS662C year old, moderatly used. I just tried to use it and it will not feed the paper. It sounds like it is working but nothing is happening! Last thing shredded was one credit card. What could be...
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
May 27, 2011 | Aurora Electronics AS-650C Cross-cut...
Hi I have a GBC Shredder, made by swingline, model GLX2030. Since this morning the shredder didnt stop! Normally the shredder work only when we put paper into...but today we have to push the ''ON'' button...
There is an infeed sensor that isn't being made for auto on which is just a simple flipper switch and if it doesn't work it is because there is paper jamming it. Unplug it and turn it over where the blades are and see if clogged up and if so than put back on and reverse it and than forward again until it releases if it has a reverse ,reverse it. If no reverse unplug and use a narrow object to clear from the bottom side
Mar 28, 2011 | Gbc GLX2030 Shredder
GBC shredmaster 1150x shredder now runs only in reverse. And when I press the "reverse" button, the green "forward/shred" light comes on, rather than the red "reverse" light....
The first thing that comes to mind is that the switch is faulty and that one of the contacts has come loose and is shorting across the reverse contacts. There is little else that can go wrong with a shredder, so in this case try replacing the switch.
Jan 26, 2011 | Quartet gbc 1150X Shredder
GBC Shredmaster 3220S stopped taking paper in and makes a loud,
Myi shredder does the same thing so I removed the screws to see what was going on inside.
What happened is the fan tail that spins when the shredder is in operation and cools the motor had broken off. I got some gorilla glue, adhered the fan back on, then let it dry for 24 hours. Replaced the screws, turned on the shredder on it worked just fine. The loud grinding noise stopped and the shredder worked wonderfully. I am looking for a replacement part because I don't trust whether the glue maintains its hold when the motor heats up after excessive use . Darlene
May 21, 2010 | Quartet gbc 2230S Shredder
Drive Gear Striped, how do i get replacement parts?
there are several companies who specialize in parts for shredders. This is a good one: www.gbc-shredder.com/links/shredder1.htm
Nov 20, 2009 | Office Equipment & Supplies
GBC Quartet Shredder - Service manual
try this customer service number for help 800-541-0094. I believe that Acco is the parent company for GBC.
May 09, 2007 | Quartet gbc 3270M Shredder
Quartet gbc 30S Shredder Logo
85 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
Pie-man
Level 1 Expert
pantomac nv
pantomac nv
Level 1 Expert
Bill Boyd
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
