Question about Sharp MX-2700N Color Copier
Sharp-MX2700N Maintenance Code VK
Please can someone help got a Maintenance Code from our Sharp MX-2700N which is VK. Please does anyone know what this means or how to fix.
Thanks
  • 3 Answers
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Posted on Oct 11, 2012
    Sergeant:
    Champion:
  • 373 Answers
Did you try sharp.com/maintenance
Posted on Feb 04, 2009
We have a code h4-30 on a sharp mx-2700n how do I reset?
You need to make sure the machine is in Copy Mode when you hit
# * C *
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jul 07, 2014 | Sharp MX-2700N Color Copier
We are getting a VK maintenance code on our MX-M850 copier. Does anyone know what it is and how to fix it?
This is one of the scheduled maintenance codes. it comes on at a certain "milage" and requires a technician to reset it.
If you're in Houston we'd be happy to help you out, and supply new machines should you need any.
Jun 19, 2014 | Sharp MX-2700N Color Copier
Line on copies in the same place all of the time sharp mx2700n copier
Replace drum OR main charger OR clean glass OR replace blade d
Feb 11, 2013 | Sharp MX-2700N Color Copier
Hello, I have (had) a paper jam on a Sharp MX2700N. I have removed all copies but am now advised to call for service Code H5-01. Any ideas?
after call for service, the machine will indicate an error code like H4, F2,etc. if you can give me the code i will know what to do
Feb 03, 2011 | Sharp MX-2700N Color Copier
Error code u2-10 on a sharp mx2700n photocopier
U2-10 SRAM user authentication index check sum error. I know, gibberrish right? To clear this error, put the machine in "simulation mode" by pressing "c" "*" "p" "*". then type 16, press the copy button, then press "execute" then press "yes". Hit the "ca" button to go back to ready. This should clear the error code. If the code returns, then the PCU PWB board needs to be replaced. I hope this helps.
Jan 27, 2011 | Sharp MX-2700N Color Copier
Hello, We have a sharp mx2700n and it says: maintenace code TA is there any code wich makes this undone? thx in advance
Ok so the TA code means that the all maintenance counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 04
Then you can select what you want to clear so the maintenance count all
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you
Mar 01, 2010 | Sharp MX-2700N Color Copier
Code U2-05 call for service code!
This procedure may help, it works on older models.
Press # key
press * key
press C key
press * key
enter 16
press start key
Turn the machine off and then back on
Good luck
Apr 20, 2009 | Sharp MX-2700N Color Copier
I have a sharp copier MX2700N with an error code of FK1. What do I need to do to fix it?
fuser count has reached 200,000 copies. hit P*C* then 24, start, then 4 start. select Fuser Unit and Fuser Acum Day then execute at bottom then yes. Hit CA button. copier should reboot and clear code.
Apr 17, 2009 | Sharp MX-2700N Color Copier
I have a sharp copier MX2700N with an error code of TK2. Will this cause the copier to stop printing and is there a way to clear it
The TK2 means its time to replace the secondary transfer belt. Depending on your copier and driver setup it may prevent you from printing. If you open your print driver properties and go to the ports tab and then click on configure port button, in the next window uncheck "SNMB printing" option - this should allow you to print. You can clear the maintenance code by going into the SIM mode. press the following keys one after the other "P" "*" "C" "*" then enter 24 and "copy start key" then enter 4 (maintenance clear) and copy start key then highlight the items you want to reset and press execute then yes. restart the copier by pressing the "CA" key. do not make adjustments to other sim code items as it can render copier useless!
hope that helps.
Apr 06, 2009 | Sharp MX-2700N Color Copier
Sharp MX-2700N Color Copier Logo
7,181 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
