Question about Bunn GR10 Coffee Maker
Bunn GR10 has a hole in the panal where the water runs into the
Tank. There is an indention with a washer where the water is deposited to the tank and it has corroded and is leaking at the bottom of the unit. I would like to just replace the panel instead of buying a new unit, but I cant find a source to buy one.
  • Mark Egan May 11, 2010
    These units have a 3 year warranty unless it was previously factory repaired. Then it has a 1 year warranty.
    There is a date code somewhere on the unit. Contact Bunn and they will tell you where, and if the unit is still under warranty. Usually the only reason you would need the sales receipt is if you bought the unit within three years, and the date code indicates the nit was built more than 3 years ago.
    Reply back what you find.
  • 131 Answers
The only place I know of that you might be able to find a replacement tray for this style of brewer is from your local Bunn repair shop IF they have a used unit laying around that died from something else. Bunn will not even send out these parts to their repair centers. Good luck!!
Posted on Feb 14, 2009
Bunn coffee maker model gr10-b water will not heat in tank
If you will call customer service with the model and date code at 800-352-2866 we will be happy to help you with this issue.
Oct 17, 2010 | Bunn B10 Coffee Maker
Hot water leaks out the bottom when filling resevior with water of my Bunn coffeemaker GR10-B
If you will call 800-352-2866 with the model and date code and we will be able to help you resolve your issue.
Jul 01, 2010 | Bunn GR10 Coffee Maker
Bunn perks coffee very slow?
This is generally an indication of a lime build-up in the water tubing. If you take off the sprayhead and insert the metal deliming tool into the water tubing all the way leaving out about 1-2 inches and twist it about 5-6 times, this should remove the lime deposits from the water tubing. Then flush out the machine with 2-3 decanters of water. If this doesn't fix the problem, then call customer service with the model and date code for further assistance.
Aug 01, 2009 | Bunn GR10 Coffee Maker
Water wont come out of my bunn coffee maker
The first pot of water you put in the coffee maker just fills the water tank which is then heated up , once it gets to temperature you then pour second pot of water this pushes the hot water out of the tank through the coffee grounds into the waiting pot. This way you can make coffee faster than a regular coffee maker.
Jun 02, 2009 | Bunn GR10 Coffee Maker
My Bunn coffee maker boiles over the top vent
Try taking the top off the unit (3 screws) and remove the pour-in tray (1 bolt) and turn the thermostat down. Replace the tray - making sure you put the silicone washer in - put the lid on, and try it again. If this doesn't cure it, your thermostat is bad, and you need to replace the unit.
Nov 11, 2008 | Bunn GR10 Coffee Maker
Bunn commercial coffee maker does not pour water
clean your spray head by removing it and at the same time run the cleaning spring up through where the spray head screws to. before replacing spray head place your pot under and pour a pot of water through,to rinse.when done replace spray head .wait for it to heat up and your set to brew again...
Oct 28, 2008 | Bunn GR10 Coffee Maker
Owner of a GR10 Coffeemaker
take the spray head off, should have 5 holes clean it out and run the cleaning spring through where the spray head screws to.
Sep 21, 2008 | Bunn GR10 Coffee Maker
My Bunn coffee maker is leaking water
Dennis Karlen supplies repair parts for this problem. You can find the various kits on his website
http://www.jneuhaus.com/appliance/karlen.html
There are other suppliers who sell two silicon washers and a stainless steel washer in kits, but they tend to run considerably more.
The rubber washer would degrade quickly due to the heat. You may be able to get by with a new silicon washer. Check your local (not national chain but local francisee) hardware store.
Feb 15, 2008 | Bunn GR10 Coffee Maker
Bunn GR10 Coffee Maker Logo
339 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
