Question about GE Nautilus 24" Built-in Dishwasher
JetDry is leaking out, under the door
I got this washer with the house I bought (new house, new washer, afaik....who knows, likely scratch and dent sale, since the builders were cheap all-around) - and I've recently started using JetDry in the JetDry compartment, and the JetDry is leaking out under the door, on the front of the washer.
Between the bottom "plate", and the door/hinge area....
  • ahoier Feb 04, 2009
    Wow, thanks for the response :)  And I was expecting to come back in 5 days and hope for a response :)
    I don't know all the details, I don't even know if we got a book with the washer regarding warranty, model/serial, etc...
    It's actually my parents house, I just noticed it today, because as I was filling up the JetDry, I was like damn, this thing is taking forever to fill!  So I screw the lid on, and close the door, sure enough, I see jetdry pouring down/out of the front panel.
    But ya, I'm gonna let my parents know when they come home, who knows, maybe Maronda will even come out and take a look at it, this house has been nothing but problems for them :P
  • Mark Egan May 11, 2010
    Is there a chance that the unit could be warrantied?Call GE and find out.
    Even "scratch and dent's" can still be covered.
    If not, the container is relatively cheap, I think. Let me know, and I'll look it up.
    President:
  • 1,214 Answers
Well, I'll be glad to respond of they or you have questions.
If you would, reward me with a FixYa, and I'll be sure to respond on future requests on this unit, unless I am traveling. But I will get back with you.
Posted on Feb 04, 2009
Rankam
Take it back to where you bought it, and get it replaced
Jun 29, 2013 | Grilling
Maybe a leak?
sounds like a faulty oil light sender that has a leak or has blown. Will drain sump verry quickly
Dec 10, 2012 | 1995 Chevrolet Camaro
The ice maker stopped working a year after we purchased. I was told the motor went bad and I need a new one...the spring on the door is broken too...what to do? Will Whirlpool fix it since my home owner...
Yes seeing how your unit is only a year old your unit would still be under warranty if you bought the extension as long as you bought the unit new and not from a second hand or scratch and dent type of business in which if you did then you would have to call them for the warranty. If you bought the unit at lowes on the other hand there is only a one year warranty on the unit so it depends exactly how long ago you purchased the unit and from where. If you have any further questions message me back Thanks Rick
Aug 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Purchased scratch and dent kenmore electric range model 96419. Did not see when I looked at store that the handle was broken, also the door does not want to stay shut. I close it and the door pushes...
not all scratch and dents are plug and play yours sounds like it was dropped or received a damaging blow you will need to look for door replacement parts and possible alignment of door or body frame
May 30, 2017 | Kenmore 96412 / 96414 / 96419 Electric...
I have a major dent in the right door of my french door Jenn air fridge what is the cost of a new door.Model JFC2089H Stainless.
Depending on the part supplier the door will run about $400.00 to 700.00, I know that is really high!
One option you may have is to call around to service companies that work on Jenn Air, they may be able to look out for a door that they are replacing for someone that only has a small dent or scratch, and rather than scrap the old one, recycle it with you.
Not sure if that is an option but worth a shot
Apr 18, 2010 | Jenn-Air JFC2089HE French Door...
Replace new moen 1200 stem, still leaks due to scratches housing
The proper fix for this is to hone out the scratches
take steel wool and wrap it around a dowel or piece of wood or ust stuff it into the housing and turn back and forth to smoth out the scratch
if the scratch is real dep you wll have to go to harbor freight and get a honing tol that fits on the end of a drill
the stem should have some type of crown washer that you should be able to get an assortment from lowes , ace or hd
If you are asing for a recommendation for a good silicone I always use GE silicone it is the best
as a last resort (if nothing else works to stop leak
I would take cartridge wall and streatch teflon tape as tight and smooth as possible to block water coming up between housing and
cartrideg this is not recomended by mfg just a spa (my initials) certified suggestion
Good luck
Jan 07, 2009 | Moen & Replacement Cartridge
LG WASHER AND DRYER LGWN1812CW&LGDLE2512W
hi there
i e-mailed you the one for the washer but im having a bit of problem with the dryer, as the model # that you provided does not exist. would you mind re-checking it for me please?
thanks
Sep 30, 2008 | LG DLE2512W Electric Dryer
Installing a whirlpool wall oven
You could call whirlpool and they can email you the instructions. Or your can go on whirlpool.com and enter your model number under the upper customer support tab.
Oct 23, 2007 | Whirlpool RBS305PDS Electric Single Oven
GE Nautilus 24" Built-in Dishwasher Logo
113 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
