Question about HP ProLiant DL160 G5 (445198-001) Server
Problem with SAS Configuration Utility
Hi all,
i have a problem with one HP DL160 G5. I want to configure RAID with 4 discks but i can not enter in SAS Configuration Utility. I press F8 to enter, then i have option for Invoking SAS configuration Utility. Then, it says, PLEASE WAIT, Invoking Configuration Utility... and nothing
What can i do?
  • Anonymous Mar 05, 2009
    Having similar issues.
    There is no SSCD for DL160 G5.
  • Tihomir Ciric May 21, 2009
    there is no startup disk for DL 160. i had to do it manualy
  • 14 Answers
Use the smart start CD!
Posted on Feb 06, 2009
Recently I had replaced one of HDD of my DL580 service Raid 5 configuration. After that everything working fine including user connectivity and database access. My question is both the LEDs on replace
After you replaced the drive, did you rebuild the RAID array? Some of the higher end RAID controllers will try to rebuild automatically (if set to do so) but most must be rebuilt manually.
Dec 22, 2014 | HP ProLiant DL580 G5 (438087-001) Server
Server won't start HP ML350 G5
Reseat the drives, but DO NOT swap slots. Keep exact, in case of RAID configuration.
Use the Smartstart disc. It may show you the current array config.
Oct 23, 2012 | HP ProLiant ML150 G5 Server
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
Raid 10
The porn site have installed it add-on your browser. Check and see if you can see any strange program on add and remove software program window. If you can remove it but you must be sure before doing that. Alternatively, download a malware removaMicrosoft
May 03, 2010 | HP ProLiant DL580 G5 (438087-001) Server
I have HP proliant DL160 server. How i will make RAID two HD?
Try going into the RBSU(Rom based setup utility) and configuring SATA RAID in the advanced section.
This doesn't work for all versions - if it doesn't help, please be more specific about your configuration, i.e. what "G" level is the server? Hot plug or non hot plug drive? etc.
Feb 23, 2009 | HP ProLiant DL160 G5 (445198-001) Server
Setup raid configuration
Just keep pressing F2 on startup to go to bios. In bios go to advanced screen and highlight "show raid" option. Hit enter and highlight show raid. Then save changes and exit. Press Ctrl + I when booting and you will open raid configuration utility. Make sure you backup all your files and create RDVDs before making any changes to raid.After pressing ctrl+i you will get raid configration utility. From there "delete raid" -> create new raid volume and select raid type as raid 0. Then boot from RDVDs and install operating system.Let me know if there is any trouble with that
Dec 19, 2008 | Sony VAIO VGN-AR630E Notebook
Run Compaq Array Configuration Utility
Hi Foambob,
Try all means to get a smartstart CD.
Normally new version will be able to use on older hardware , but no guarantees.
I have always found it easier to use smartstart CD auto mode.
You can also do the install and then run ntssd to update all the drivers etc., but I don't recommend it for novices. Use the auto mode , it takes longer but safely and surely.
Good luck
May 21, 2008 | Compaq ProLiant 5500 Server
HP ProLiant DL160 G5 (445198-001) Server Logo
1,517 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
