Question about Epson Stylus Color 640 InkJet Printer
No color I have a HP printer when I click on pic to print it the pic turns black and white and prints that way. I have brand new inks also.Help me please
  • popette19462 Feb 04, 2009
    Ok that was helpful now How do I get to driver to open it.lolol
  • 115 Answers
The driver must be set on B&W prints. open it.
Posted on Feb 04, 2009
  • arnaud monfort
    arnaud monfort Feb 04, 2009
    on a mac, go to preferences system/printers/ and then doubble click on your printer. On windows, you go to configuration panel/printers and lokk for your printer. best regards
Printer will not print in color
Printer properties in "start menu" printing preff. (make sure you are not using a black and white driver) -Car
Apr 17, 2014 | Dell KDA1 Color Laser Printer 5100cn PC...
Why is my black ink not printing
Hi Colleen,
Try this > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences' or 'Properties'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc... , there click 'Ink cartridge settings'.
- A small windows opens, there select black only. See the image
- try printing, if it fails to print, just return the cartridge to the shop and get a genuine branded one. (dont forget to change the 'ink cartridge settings to normal to 'both black and color')
Hope this help, if you are not able to fix it still, then better come to chat here , thanks! 10_22_2011_5_46_32_am.jpg
Oct 22, 2011 | HP Photosmart C6380 All-In-One InkJet...
How to change the ink cartridge
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
I have a HP 4100 printer. Installed new ink.Purple streaks
That's a neat trick. The 4100 is a printer that uses one BLACK toner cartridge. It doesn't print in color. And it doesn't use ink.
Oct 24, 2009 | HP LaserJet 4100 Printer
My printer will not print in black and white, as my colour cartridge is low. How can I just print in black ink? Kodak esp3 all-in-one printer.
Believe or not, a bit of color ink is require to make true black. However, from most application you can go in to the printer preferences and click the Color tab. Check the print in Grayscale and click the Black print only option. My instructs are based on an HP model printer. The preferences can be a little different between brands. But, you should have similar options. Check your printer's manual for more specifics.
Oct 03, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My printer is not printing well. ink cartridges are brand new- just cleaned heads and recalibrated- also reset settings- can't make black and white copies at all- on color only prints very faded blue to...
are you sure already check the box "Black and White" ?
reconnect the printer, turn it on, & open the 'preferences' or 'options'.
Look for the Advanced tab, click, and check the box 'Black & White' printing. i hope that work..
Sep 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP Officejet 7110 won't print black and white w/o color cartridge. I never print in color; yet the machine will not print in just black and white without having a color cartridge with ink in it. Why would...
I've used HP Inkjet/Officejet printers for years. Many HP inkjet printers also use the color cartridges to some extent to create 'black' in slightly different shades, that can be un-noticeable to the eye.
To print using only black ink, try doing as follows:
When you click on 'Print' from your browser, the printer properties (or preferences) page opens.
You must first set the printer to not print in color (color is the default setting). Then you must set the printer to use 'black ink only' by using the 'advanced settings' as follows:
1. In most browsers there will be a box on the lower right of the printer properties page that says 'advanced'.
2. Click on that box to get the advanced settings page to open.
3. Once open, the feature you need to check is called 'print in grayscale'. (It is usually at the top of the list) It is set to 'off' by default. Just click on it and a menu box drops down and one of the choices is 'Black Ink Only'.
4. Click on that and then 'save' or 'apply' those settings.
Then your printer should be using black ink only.
You will probably have to set that each time you want to start a new printing job, as the default settings on these printers are tilted toward using the color cartridges in order to sell you more colored ink.
Also, if you are using Windows 10 and the 'Edge Browser' that comes with it, you cannot get to the 'grayscale' option. So either use a 3rd party browser, or use good old Internet Explorer, (which is still included in Windows 10) to open and get to the page you are trying to print.
I hope this helps. If not, go to HP.com and type in the model number of your printer and then do a search from there for detailed instructions for your printer model (which might be slightly different than what I have shared here.
Apr 28, 2017 | HP OfficeJet 7110 All-In-One Thermal...
Print in black ink only
I know you can print in Greyscale which prints in black and white only. On your Windows computer, you should just be able to click Start -> Printers and Faxes, then right-click your printer and choose Printing Preferences. Look for a tab that says Color and click it. There should be a selection, probably a check box, that lets you choose "Print in Greyscale". Afterwards, when you print, even color documents will print in black-and-white only.
Oct 07, 2008 | HP Photosmart D7160 InkJet Printer
HP 5610 Will not print Color documents, only Black and White
Chances are that your print driver is set to print in black and white while the copier side is automatically detecting that your original is in color. To have the printer print in color: Select file print, select your printer and hit preferences. Select the Paper/Quality tab and switch from Black and White to Color.
Henry
Apr 28, 2008 | HP Officejet 5610 All-In-One InkJet...
Epson Stylus Color 640 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
