Question about Ricoh Aficio 450 Copier
I need feeder parts (rollers) - Where can I buy them?
Contact me [0]9434564100
Posted on Feb 04, 2009
  • Ricoh Master
  • 2,794 Answers
Check with precissionroller.com
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Multiple pages were jammed in feed tray in it not automatically ejected whay to do?
Jast open paper feeder tray. To open the paper feeder you need to open 6 scrue. there ware a roller in the left corner in the feeder whice is made by rubber of plastic( White or gray) . Push both end of the roller. When it will open, there ware spring inside the hole of the roller. Put off it. and reassenble the parts with out spring. If you apply it carefully, I thing you will be relive from your problem. Thank you
Shohagtush
Oct 16, 2010 | Epson STYLUS R230 InkJet Photo Printer
HOW TO CLEAN THE HP LASERJET M2727NF
To clean the Top Feeder rollers simply buy/get a can of WD-40 and clean both rubber rollers, also clean the smaller glass with alcohol if you get lines on your copies using the feeder and not the bigger glass platen. Take each drawer out and find the feed rollers, you should be able to clean those with WD-40 as well.
Mar 31, 2010 | HP M2727NF Laserjet Printer
HP 870Cse feeder/roller is dead
Take a very small amount of Goo Gone on a paper towel and roll it over the rollers. You can press and hold the top button to get the rollers moving. This will revitalize the rubber rollers. My printer is over ten years old and I do this about every two years and never get a misfeed.
Dec 08, 2009 | HP Deskjet 870cse Printer
Savin 9935DPE document feeder maintenance
GO ONLINE TO SAVIN: TYPE THE FOLLOWING INFORMATION:
WWW.SAVIN.COM/SERVICE_MANAUL
/TECH_SUPPORT
/SERIVES
/HELP?
CALL SAVIN ASK TECHICAL SUPPORT, ASK FOR A TECHICAIN THAT REPAIRS OR FIXS THAT TYPE OF EQUIPMENT AND EXPLAIN THE PROBLEM AND SEE IF HE HAS ANY IDEAS YOU CAN TRY BEFORE YOU GO OUT AND SPEND ANY TYPE OF MONEY ON THAT PART.
ROD
May 12, 2009 | Office Equipment & Supplies
Feeding paper for scanning/faxing - e-studio350
If u put stack of papers on the feeder, but it didnt pick well or paper jam occur, u need to check the feeder unit. Normally roller is wear and tear, foreign materials inside the feeder and etc will cause paper jam on feeder.
Mar 19, 2009 | Toshiba e-Studio 350 Copier
Doc.feder jam
Try cleaning the rollers in the ADF (Automatic Document Feeder).
It might temporarily solve the problem, but rollers do have a limited life time, so you will eventually need new ones.
Part info:
5851-3580 - Automatic document feeder (ADF) paper pick-up roller assembly
Price: $15.57
Dec 10, 2008 | HP LaserJet 3055 All-In-One Printer
Document feeder will not Operate
Try cleaning the rubber rollers onder the cover where the documents feed in, using a rag and some rubbing alcohol.
Jun 18, 2007 | Ricoh IS 330DC Flatbed Scanner
Ricoh Aficio 450 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
