Question about Acer TravelMate 2300 Notebook
Touch pad and keyboard freeze after startup
My acer aspire 3000 has been behaving really weird of late. As soon as i start up, after a couple of minutes, the touch pad and the keyboard stop functioning. I can still move the mouse pointer using a USB mouse and the same using a USB keyboard. but that too not for long. I tried a system restore, the problem wouldn't go. I tried using the recovery disks provided by Acer to perform a recovery, but the problem still persisted. I then deleted the partition I had and formatted my whole hard disk and then did a fresh install of XP from one of my friends' CDs. The problem was still there. I have also tried booting the system from a bootable CD with an OS like "Reatogo XPE" . They keyboard and touchpad seem to function perfectly well in that environment (although such an environment gives me only basic functionality). Please tell me how I can solve this problem as I seem to have tried everything possible short of contacting acer. I have de same problem on my acer travelmate 4072. when I take out the batery the mouse and the keyboard start working ok. Otherwise both of them goes to freeze. Do you have any new solution for this trouble?
    President:
  • 1,902 Answers
Check your memory. Reseat your memory. Try that first. The next step would be to get *********** board checked. All I own is Acers and I have had that same problem. Usually after reseating the memory everything seems to work just fine. But this could even be your graphics card. I would try and run a diagnostic on it and reseat the memory. You can run a diagnostics by shutting down the computer then hitting F8 and click on diagnosis and repair. And see what kind of a reading you get out of it.
Posted on Feb 04, 2009
3 Suggested Answers
SOURCE: touch pad and keyboard freeze after startup
I've been having this problem myself. The thing is, whenever I disconnect the battery, everything decides to work fine. When I put it back in, everything turns into crap again. Try plugging your laptop in, but turning it on without the battery attached.
Posted on Mar 22, 2007
this is the link to acer's battery replacement program www.acerbatteryrecall.com
However, the replacement program is not related to any issues with keyboard and touchpad - it seems to be about batteries catching fire!
I have an acer aspire 5672wlmi (vista business) which has a bad battery. My battery sadly didn't mach the replacement criteria : (
Just taking the battery out and run on your adapter/powercord immediately solves the keyboard and touchpad issue. getting a new battery costs about 100€ and solves the issue aswell.
New drivers or any reinstall didn't work for me.
There is also a page wtih phonenumbers that you can call to check if you can get your battery replaced. I've tried the dutch number 078-150024 but it seems to be allways occupied
Posted on May 15, 2008
My touchpad still wont work for my acer 3000
There is a button to turn on and off the touch pad. Is there a button on your keyboard that has the letters FN on it? if so hold that down and see what comes up. If not search for any kind of switch near your touch pad or that is on the keyboard that is not a normal typing key.
Mar 14, 2010 | Acer Aspire 3000 Notebook
My acer Aspire 3000 with a fresh windows xp home install, is having issues with the touchpad pointing device. I plug in a wired USB mouse and have no issues, but with the touch pad i am getting very eratic...
you may need to reinstall the drivers for keyboard and touch pad, if you still have the drivers cd on hand look for these two important drivers, since you have the new xp installed all drivers have been erased.
hope this helps
Nov 19, 2009 | Acer Aspire 3000 Notebook
Acer Aspire 3304WLMi keypad and mousepad not working
if you take a hard look at your laptop you'll probably find a key that to disable keyboard that with fn will do it
what type of laptop and model
also check in control panel mouse then device settings see if you disabled in there
Feb 01, 2009 | Acer Aspire 3000 Notebook
Computer freezes on start-up
whenever your doing a cd recovery you need to remove the battery
use ac power
if its still freezing up you'll have to run windows again
Windows uses a lot of power to install
Jan 09, 2009 | Acer Aspire 3000 Notebook
Aspire 3000 Keyboard Lag
Try running an Antivirus and Antispyware application.
One of your other programs is interfering. (as it disappeared in safe mode)
Try deleting things out of the Startup in the Start button menu.
Mar 12, 2008 | Acer Aspire 3000 Notebook
Frozen keyboard acer 5100
for aspire 3050, try to remove the battery, battery can cause many strange thing.
if you still got problem after removing battery, it's look like motherboard need repair.
Mar 02, 2008 | Acer Aspire 3000 Notebook
Battery problem, remove battery... fixed!
Feb 19, 2008 | Acer Aspire 5670 Notebook
Well this might not solve your problem but it may help others. I thought I was having the wierdies! on my new Acer Aspire 5315 after happily installing Suse 11.0 and getting all but wireless to work. Yes even Crystal Eye was identified and Skype picks it up and give me a great pic.
Suddenly this morning for no apparent reason I could no longer use the touchpad only the mouse 'logitech' worked. Checked everything and then did a search using ixquick.com and got here. Tried all the suggestions including taking the battery out but nothing. Sat and pondered and then looking at the keyboard noticed that F7 had a little hand and finger pointing to a square icon just below and to the right of the F7. Umm! let see whar happens when I use the Fn and the f7 keys. BINGO!!!! Touchpad loves my fingers again.
Might help if anyone else has similar Aspires or laptops with lockout like this.
GaryC
Mar 15, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
189 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
