Question about IBM Netfinity 5500 M20 4RY (86624RY) Server
Not Starting up
System was working fine, howerer cover was off and it got some rain in while it was on.just the sprays. the power supply was checked and found to be ok what is the most likely problem, now as ther is no power to the board,is it that the voltage regulators at the top could be faulty.
  • lpbrathwaite Feb 09, 2009
    Thanks for your help. i already had the power supply check and will spend time taking a closer look at the motherboard.
    Scholar:
  • 127 Answers
Since your SUP is working OK....Your board might be fried because of the water that got in and shorted some parts....better send it to an electronic technician and let them check for damage/burned parts.
Posted on Feb 04, 2009
2006 ford free star when it rains the PCM gets wet and runs rough. Today it has rained for 3 days @ won't turn over. Battery is fine. Only a problem when it rains.
Rain should not affect your car starting. It sounds as if your battery is failing. Put your headlights on and get someone to turn the key with you looking at the headlights. If they dim to a glow-worm, your battery is not powerful enough. Sometimes a cell will fail and although your get 12 volts, you don't get enough cranking amps.
Regarding starting in damp weather, you can try this. Spray all the ignition leads with WD40 and also the inside and outside of the distributor cap. You can also try this which worked for me on an old Datsun that didn't like damp weather. Get some broadsheet newspapers and tape them together to make one large cover for the engine compartment. Make is about 10 sheets thick. Run the vehicle with this all over the winter. When you drive the paper warms and keeps the leads warm. When you park, any moisture in the air goes into the paper and doesn't condense on the ignition system. Make sure the paper is away from moving part like the radiator fan and the exhaust manifold. Check it after your first short drive, it should stay in place.
Dec 02, 2015 | Ford Cars & Trucks
Raining for 3 days and my 2006 ford free star won't turn over. Battery is good, starter clicks no more. PCM has been wet before. Waiting for dryer weather and try again.
Location of fuse in Intelligent Module
Fuse panel B contains fuses that supply power to washer functions. 25A fuses 34 and 33 and 30A fuse 32 supply power to the vehicle electrical system control module. 30A fuse 38 supplies power to the wiper motor control module. 5A fuse 19 supplies power to the rain/light recognition sensor. 30A fuse 36 supplies power to the headlight washer relay. 10A fuse 15 supplies power to the instrument cluster control module for washer fluid level sensing. 10A fuse 13 supplies power to the windshield wiper/washer switch in the steering column electronic systems control module. In addition, 5A fuse 20 supplies power to the washer nozzle heaters. Troubleshooting all this could lead to an answer.
Jan 28, 2014 | 2007 Audi A6
HONDA GL1500 wont start when it rains
Easy! moister is getting into your electrical system. Sounds like its starting at your switches and probably just need to pull the switches apart, clean the contact points and apply a little grease. Your best bet is to not let the bike get soaking wet, cover it and and only wash it by wetting a towel and not spraying it with a hose.
Jul 19, 2013 | Motorcycles
My 94 jettas power sterring seems to fail in the rain from slipping !is there a chance the could be a cover missing and can be replaced?
Yes. there are suppose to be lower covers to keep water from spraying up on the belts when it is raining.I would check to make sure all covers are present and also make sure tension on belt is good as well.If all covers are present I would check into replacing p/s belt and having it adjusted properly.Hope this helps
Mar 06, 2013 | 1994 Volkswagen Jetta
My KLX 150s Coughing/ Dying when under the rain.
Sounds like coil or plug wire is getting wet. Could also be ignition system also. Check everything and try spraying the wires with silicone spray to water proof it.
Jan 17, 2013 | Motorcycles
Moped not starting when raining or high humidity.
on a dry day when its starting fine spray all around the spark plug with hair spray its a cheeap and easy fix it worked for my suzuki gn 125 motorcycle every few weeks it needs done but it should sort it out basically whats happening is that due to dampness the electricity must be shorting out and not throwing the full kick into the spark plug i recommend going around any electrics that sit out and spray them its a great water seal
May 28, 2012 | 2008 Jonway yy1501
Will not start after heavy rain storm my bike is a 1997 kawasaki ninja 750 zxr
You may have a simple problem with water in the electrics.
IF you have no spark at the sparkplugs.
Disconnect your battery.
Check voltage and recharge if necessary.
Check the fuses, (as per Owner's Manual) as water in connections are akin to a short circuit and fuse's blow to prevent component damage.
Remove sparkplug leads and spray some water repellent agent like WD-40 or RP7 into them and shake out. Spray a liberal amount onto sparkplug tops (do not remove plugs at this stage). Replace plug leads.
Spray around the joins of the handlebar switch cluster that has the Engine Stop button.
Spray around the ignition coils and CDI unit.
Some water may have entered your magneto/generator cover and contacted the stator coils and pulse coil. This provides the power to recharge your battery and run the lights. You can remove the generator cover and spray around the back edge of the rotor to displace any water present...let stand on sidestand to help with drainage.
Reconnect charged battery and briefly check function of all lights, then try the starter.
If you HAVE spark but still not starting, likely to be water in the fuel system.
Place bike over a tray or work area.
Turn fuel tap off and disconnect fuel hose.
Place glass beaker under tap and turn on to reserve...check fuel for water at the bottom of beaker under fuel. Drain and replace fresh fuel if water present.
Undo drain plugs beneath each carburetor and let fuel drain, replace fuel hose and turn fuel tap to reserve and let a small amount of fuel to run thru lines and float seats to flush. Turn tap OFF and replace carby drain plugs.
Take out air filter element and check for moisture, blow dry if present, wipe out airbox.
Might be an idea to drain and replace your engine oil (water in oil will give it a milky look) once she's been warmed up again. Goodluck and cheers.
The site below has the bike in sections with exploded views and names of parts for you assistance!
http://www.cmsnl.com/kawasaki-1997-p2-zx750-north-america_model12923/partslist/
May 17, 2010 | Motorcycles
Wont start first start of the day just replaced
If you are referring to the power booster for you brakes, that would have something to do with your starting ONLY if the hose leading from the booster to the engine were not connected correctly or is leaking (it is a vacuum hose and it would effect your overall vacuum).
Here are some things you can check:
If you have an automatic transmission, I would check 1) the fast idle thermo-valve. 2) the starting air valve, and 3) the IAC valve. The IAC valve and the Fast Idle valve are on the front of the cover that has PGM-FI on the top. They are connected at the bottoms by small water hoses. The starting air valve is at the right hand end (facing the car) of that cover. All of these valves affect your starting air mixture, in one way or another. They get dirty, or the vacuum hose to the starting valve might start leaking.
You will probably need a manual (Haynes) to go through checking procedures. It has good pics and describes what to do, but many owners simply take the two bolts out of the IAC valve and those that hold the Fast Idle Valve, pull them back without disconnecting the water hoses, and spray the insides of them (especially the screen in one of the two IAC holes) with a good dose of carb cleaner, reassemble and see if that makes things better. The vacuum hose on the starting valve should be carefully checked. .
Hope this gets you started on a fix.
Oct 28, 2009 | 1992 Honda Accord
Car running rough when raining
check the spark plug wires, put water in a spray bottle and spray along the wires,especially by the coil,if the car starts to run bad or you see sparks, the wires are no good, hope this helps, Ray
Apr 03, 2009 | 1999 Mercury Villager
IBM Netfinity 5500 M20 4RY (86624RY) Server Logo
63 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
