Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
Whirlpool KUDP01ILBS2 Dishwasher sani rinse light is flashing
Our whirlpool dishwasher isn't cleaning properly and in the morning (we run the machine ovenight, so I don't know if the cycle is finishing) the sani Rinse light is flashing.
It sounds like a heater element issue, but it may also be the water going to the dishwasher isn't hot enough when it gets there. The problem seems to have been when we have had a cold snap.
Any suggestions????
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
SOURCE: whirlpool dishwasher drainage problem..
This sounds like a bad timer. The timer is what tells the pump to drain at specified times. If it gets a bad contact, that timed cycle won't happen.
PS: Do you know for sure that the drain is occurring in mid-cycle? If not, you may just have an obstruction in the drain and/or anti-siphon valve (where the hose connects under the dishwasher.
Posted on Jan 03, 2008
SOURCE: i have a kenmore dishwasher mode 665.16032402
I have the same problem. I have to go through the test mode at least three times just to wash one load of dishes. This dishwasher is a lemon. Sears she recall it. The techs say that they have at least 50 calls a week with the same problem. We need to hire a lemon law attorney and sue the pants off them. If you here anything email me please.
NewJackSwg@aol.com
Posted on Jan 22, 2008
SOURCE: Kenmore Elite 8269645
I have this model, but not this problem (my impeller motor seems to have burned out). Anyway, try pressing Hi Temp Scrub, Air Dry, Sani Rinse, Air Dry, in that order and see what happens. Mine appears to reset and run through a set of warm-up tests.
Posted on Jul 27, 2008
  • 848 Answers
SOURCE: Our Whirlpool KUDP01ILBS2 dishwasher isn't
Heat that is retained in the dishes is largely responsible for drying in this dishwasher. Since plastics do not retain heat very well, they will not dry as well as glasses, ceramics or metal dishes. Rinse aid must be used so that the final rinse water will sheen off of the dishes to accommodate this drying process. The heater element at the bottom of the tub is used to add heat during the drying cycle to aid in this process as well. This model of dishwasher does not have any forced air circulation system. Here are some tips that may help you resolve your drying problem:
  • Make sure that you are using rinse aid. Failure to properly use rinse aid can prevent proper drying. Adjust the amount that is dispensed if necessary. Also, check to make sure that rinse aid level decreases over time indicating that it is being dispensed properly.
  • The NORMAL WASH and POT & PANS cycles heat the final rinse water up to 140 degrees F. Use these cycles to help the drying process.
  • Do not choose the air dry option. This option cuts off the heater element during the drying process. NOTE: The heater element is not turned on during the first 6 minutes of the drying portion of the cycle.
  • Do not overload the dishwasher. Load the dishes to allow for proper water drainage.
This dishwasher has a heater fault detection circuit. If the heater is not working, the control will detect the lack of increase in water temperature. The dishwasher will stop and the CLEAN light will blink seven times repeatedly. The dishwasher would not be able to be used until the problem is corrected and the control is reset.
Posted on Feb 10, 2009
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Normal wash and rinse only lights keep blinking on whirlpool gu1500xtls. tried cancel and uplugging and they still blink
Have Whirlpool GU1500XTLT1 with exact same symptoms, even tried power off but the lights resumed blinking when powered back up. Used solution from "kent168" of 17 Nov 2010 for similar GU1500XTLS1 with a different problem, and IT WORKED: "Reset the machine: press control buttons in this sequence: sani rinse, air dry, sani rinse, air dry, clear."
Jan 18, 2012 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool dishwasher GU1500XTLS1 displays the number 2 and pumps out no other function works
Reset the machine. Press the control buttones in this sequence: sani-rinse,air-dry,sani-rinse,air-dary then clear! That should do it!
Nov 01, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
I have a whirlpool adp951 with a green light flashing
HI,
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
How do i reset my dishwasher adp4504 . i have kept my finger on the start button but just keeps on flashing
Hi!
Try pressing sani rinse and heated dry back and forth. All the lights will light and it will reset itself.
Please see this link for more information---
Whirlpool dishwasher reset
Please rate the solution if found useful.
Thanks
Rylee
Feb 24, 2009 | Whirlpool 18 in. ADP530 Free-standing...
Our Whirlpool KUDP01ILBS2 dishwasher isn't working like it used to. Dishes seem to be getting partially clean, they aren't getting dry at all and it seems they may be being rinsed/washed with dirty...
Feb 10, 2009 | Dishwashers
Whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Mar 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Green clean light flashing dishwasher
Nov 22, 2007 | Dishwashers
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
204 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
