Question about Philips GOGEAR SA6045 MP3 Player
Iam trying to get my melcom alarm panel to work
I need details of manual or where i can get manual
  • 34 Answers
Philips GoGear SA6045/02 (4Gb) mp3 player Manual:
http://www.p4c.philips.com/files/s/sa6045_02/sa6045_02_dfu_eng.pdf
(Google Search for Manufacturer Website, then search Manufacturer's Website for Product, then select appropriate option for Manual)
Posted on Feb 04, 2009
2006 ford Taurus dash lights not working and alarm when headlights are left on is also not working
If you have the owner's manual, check the chart showing which fuse is for the dash lights and that alarm. Try replacing that/those fuse(s) to see if you're back in working order. (Not sure where your fuse panel would be, but try the area under the dashboard on the driver's side.)
Nov 19, 2012 | Cars & Trucks
Tip
Immobilisor
one picture is worth a thousand words ,well here is how to bypass the explorer bosch built in factory alarm .Fist you have to drill the the immobilisor out or the bodywork its situated at the back drivers side LHD vehicles behind the back seat above the wheel arch behind all the paneling .Once you have found it then disconnect it first and then drill the rivits out that hold it all in place ,then under the plastic box is three screws that hold the case together ,then you will have to solder the earth connection to all the points as in the photograph and it will start ,Well it should but the one iam working on at the moment is still not getting fuel so i may have to hotwire the fuel pump direct but at the moment iam still working on the vehicle but the dark defeated me .Anyway as and when i sort the fuel pump out i will modify this tip although it could be the fuel cut off switch caused by the journey on the breakdown truck.So iam not entirely sure but i do have it turning over and a nice spark so iam almost their i think and another hour or so tomorrow i will have it sorted somehow or someway .Well i found out how to get the fuel pump to work you have to drop the fuel tank ond on top of the pump is a frequency controlled switch with 4 wires running to it ,cut the two bigger wires and join then together and then it will fire up this frequency switch doesnt allow the power through till it gets the right signal from the alarm unit so joining the tow wires together defeats it ,leave the thin wires in place they dont need touching -alicantecoli.jpgalicantecoli_0.jpgalicantecoli_1.jpgalicantecoli_2.jpgalicantecoli_3.jpgalicantecoli_4.jpgalicantecoli_5.jpg
on Jan 19, 2011 | Ford Explorer Cars & Trucks
Iam looking for an owners manual for trutech zv450tt8
"why you should not buy a Tru Tech (Funai made them)"
?searchstring=FUNAI (TRUTECH) ZV450TT8&showresult=true&exp=&resultpage=&categories=&msg=&search=search.php&shop=1
Apr 29, 2012 | Televison & Video
2005 Kia Sedona. Battery Died, now when trying to jumpstart the alarm starts going off when cables are connected and jumper car is turned on. Could this be a security feature of the factory installed...
That is exactly what it is. You need to find out how to reset the program. Check your owner manual. It could have it in there. If not, you should be able to call your Kia dealership and they can give it to you. You will need all your info from the vehicle.
Feb 09, 2011 | 2005 Kia Sedona
I need the instruction manual for a toad 101cl car alarm....Can anybody help
i just tried to get into my car, it has a taod immobiliser and alarm fitted, but everytime i open the door the alarm goes off, and i just put the key in to the ignition and the remote fob should disable the alarm but its not, and nothing happens when i turn the key.
Apr 18, 2010 | Vehicle Parts & Accessories
/*---------Nokia 7610 ----------*/ iam using nokia super nova 7610 model , bought it recently,it's worked properly for a couple of months, suddenly software problems bubbled. 1. i cant able to switch off...
It is happening due to virus.
Format ur cellphone & memory card after saving ur data in ur computer.
Always use quick heal antivirus in ur computer.
Thank You.
Mar 29, 2009 | Nokia 7610
Someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
Mar 29, 2009 | HP LaserJet 3055 All-In-One Printer
Lost my key code
press (input) the pp button on the remote 3 times press ok and it should be ok.then go into setup/function/lock and disable lock!
Thanks,
Melcom
Sep 12, 2008 | Wharfedale DVD-M3 DVD Player
Philips GOGEAR SA6045 MP3 Player Logo
247 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
