Question about HP Pavilion dv6000z Notebook
The wireless card on my laptop broke
The chip is attached to my motherboard and I'm not even sure if its broken, the switch might have just broke, but my question is can i just replace the chip or will it fry my motherboard? how much will it cost to have it fixed?
  • Rachel Jackman Feb 04, 2009
    its an HP dv6000z. I think it is probably the switch for the fact that when I switch it the light doesn't recognize the switch, also I opened it up and tryed to manually switch it and when I did still nothing occured.
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    What is the make and model of the Laptop. I need that to let you know what is going on with it and why do you think that it is the chip or the switch?
    President:
  • 1,902 Answers
Yes, try first to replace the wireless card. It is very easy to access and you should be able to just pop a new one in. Most times the switch is ok.
Posted on Feb 04, 2009
  • 679 Answers
The wireless card is a pretty common replacement part, they can be replaced pretty easily. This is from HP, it explains how to rellace the wireless card, it is quite thorough, If you don't think you can do it then better to send it to them,http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=es&dlc=en&cc=py&docname=c00273322
HP CQ60 MOTHERBOARD PLASIC CLAMP BROKE OFF WHAT AN I USE TO HOLD THE FACE PLATE I RIBBIN IN PLACE
Ahem.....what?
Touchpad flat flex cable connector on motherboard broke?
Whew!
That is laptop motherboard replacement for SURE!
OH I'M JUST KIDDING!
It MAY be motherboard replacement.
See if this will help Bobby,
http://www.laptoprepair101.com/laptop/2011/12/25/how-to-repair-broken-touchpad-connector-on-laptop-motherboard/
Regards,
joecoolvette
Nov 18, 2012 | HP Compaq Presario CQ60Z Notebook
Wireless Switch Broken
here it is -
http://www.manualowl.com/m/Gateway%20Computers/T-1625/Manual/147650
enjoy!
Nov 14, 2012 | Gateway T-1625 Notebook
Wireless switch is broken cannot turn on wireless adapter
Dear Friend,
If the wireless switch broke, you might need a flash light and something very thin and long to turn it back on. Now, if the switch attached to the motherboard broke as well you need to think about getting another motherboard.
You might want to consider and external USB or PCDM wireless card if you cannot turn it on.
Good Luck!
Jan 02, 2012 | Acer Extensa 5620 Notebook PC
Was using my Hp Pavilion dv7 laptop, suddenly turned off while the charger was plugged in. Turned back on then shut off again. Now my laptop wont even turn on, and there are no lights that even come on,...
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 26, 2010 | HP Pavilion dv7-1245dx Notebook
Acer travelmate 5520 will not switch on when powered by battery or ac
Sep 22, 2010 | Acer TravelMate 5520 Notebook
Need info on replacing zapped T41 modem with new card. Is this a simple switch? Or do I need to call in the Mod Squad? Len
I'm not sure what you mean by the T41 modem. If you mean the phone modem the it cannot be replaced because it is part of the motherboard.
If you mean the wireless card, then this can be easily replaced. To access this wireless card, remove the ketboard. There are four screws securing the keyboard and these are labeled with a keyboard symbol. After removing the screws the keyboard can be lifted up. The wireless card is located towards the top LH corner of the laptop and is held in place with screws, it also has two wires (for the wireless aerial) attached to the wireless card.
Aug 13, 2009 | IBM ThinkPad T41 Notebook
Broken wireless switch... wireless is stuck on "off".
Im not sure if there is a workaround for that when the switch is broke but hold down the FN key and press the F4 key and see if that activates the wireless card. If not then you need to get that switch replaced. Hope it helps.
May 16, 2009 | Acer Aspire 3680 Laptop
Gateway laptop, can't connect to internet
Network controller in SouthBridge chip on motherboard needs REFLOW or replacement.
Basically board needs service.
Apr 02, 2009 | Computers & Internet
Fujitsu P1510 wireless card replacement
Some laptops have a modem or wireless card that clip onto the motherboard like how the RAM is fitted to the motherboard. This card is larger than the RAM and may have one or two wires connected to this card. If so you will be able to replace this card.
If the wireless is a chip and is mounted on the motherboard then it would be impossible to replace.
Your only solution to this problem is to buy a PCMCIA wireless card and insert into the laptop's PCMCIA slot or use a USB wireless device. You may have to go into the BIOS and disable the internal wireless device.
Nov 25, 2008 | Computers & Internet
IBM x40 LAPTOP
go to IBM web site and down load and install all your drivers, try to get any upgrades this will probably fix your problem. make sure you get the chip set drivers for sure, and the last thing you want to try is a bios flash. you could even find the ide drivers. get all that you can.
Feb 18, 2008 | IBM (03R0308) for Netvista X40 Motherboard
HP Pavilion dv6000z Notebook Logo
63 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
