Question about Aspire Acer 7520-5324 Laptop
Screen hi everybody i have apire 4315 i crash the screen and after replacing it when i put it on the screen still remain black but you can see the acer logo displaying at the backgroung very faint.please can anybody help me thanks very much
  • 1,602 Answers
If you trashed the screen than you should see black, you may have did some thing to the monitor screen it may have an internal fuse link inside the screen display, the the connects at both end of the monitor connection missing, broken pin or connectors, mis aliegned connection, bitmap convertion system or the GUI portion is fualty some how.
testing a monitor or screen software call sonera technologist software called displaymate for windows a daignostic program for monitors,
you may bee able to find other software at some of the computer download center for free like pc world download software.
rod
Posted on Feb 04, 2009
The Acer Apire 7720-6155 will not boot. Get message "a disk reak error occurred, press ctrl+alt+del to restart. Then the start screen comes on and says"pressF2 go to setup then "prepare...
Hi there,Your Hard Drive is faulty and need to be replaced. It will crash completely sometime soon so its advisable to get it replaced.
Regards
Jul 26, 2011 | Computers & Internet
Acer aspire 5520G laptop,,the screen remains black,,starts up well just the screen remains black
Hi, this fault sounds like the screen backlight inverter has failed. There is not much detail in your question but start the laptop and watch the screen very closely. Watch for the windows logo to appear in the center of the screen. If you can see it but it is very dim then the backlight has failed. A replacement inverter is likely to cure this, it is usually mounted at the bottom of the screen assembly behind the plastic facsia. Also connect an external monitor and then try power up again. If you get a display on the external monitor then the inverter is the most likely cause. Check the connection cable as well before spending out on an inverter especially if the fault was intermittent before final failure. I will need more details to help more if this does not cure your fault.
Hope this helps
Steve at Olive Country Computers in Spain
Feb 15, 2011 | Acer Aspire 5520-5579 Notebook
Restore to factory default
Unlike other laptops, Acer notebook/laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer Aspire 4315 to factory setting.
Step 1: Before starting your Acer Aspire 4315 laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer one to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer Aspire 4315 is reset to factory settings.
Tips: You can also create a backup copy of your notebook data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Aspire 4315 Notebook/Laptops/Desktop, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Jul 26, 2010 | Acer Aspire 4315 Notebook
Acer aspire 4315 Blank Screen!!!!!!!!
You need to Revive the bios back.
Search for Acer bios revive in google
Dec 19, 2009 | Acer Aspire 4315-2963 Notebook
Screen get white when unused for sometime
Just disable the Hard Disk Mode, Hibenation Mode and StandBy Mode at your display properties to avoid hang-ups and system crashes.
Sep 24, 2009 | Acer Aspire 4315 Notebook
System crash after upgraing memory for acer aspire 4315
If u have 2 ram in 1 computer memoryh frequence
conflict betwwen each other if both r differ.
So cheange yhour ram and check both rammeoroy frequence are same .
Mar 26, 2009 | Acer Aspire 4315 Notebook
Black display
start your computer then press f8 to go to advance boot menu then select enable vga to boot. when you get to log in and get your screen try to reinstall the video driver
Jun 04, 2008 | Acer Aspire 4315 Notebook
Driver
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
asd-68
Jan 31, 2008 | Nintendo Game Boy Advance Console
Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
Oct 19, 2007 | Acer TravelMate 290LCi Notebook
Aspire Acer 7520-5324 Laptop Logo
142 people viewed this question
Top Aspire Computers & Internet Experts
Jax Planet
Jax Planet
Joe Goldman
Joe Goldman
john smith
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
