Question about Numark TT1650 Turntable
No signal going into mixer.
I have 2 TT1650 Numark turntables connected to a Numark DM2050 mixer. I have just bought some new CS1 cartridges. When i play a track i can hear it in my headphones and hear it through my speakers but there is no signal coming through on the signal level weather it be PFL or master. Help!!
    Problem Solver:
  • 6 Answers
Turn Up The Master Level
Posted on Apr 11, 2010
How do i hook a numark tt 1625 turntable to a regular home stereo amplifier...does the ground need to go into anything specific?
Turntables require a special input in the amp (usually marked PHONO) because they require high gain and different equalization - and yes, that ground wire has to go to ground unless you want to get a super annoying 60Hz hum from it!
If your amp doesn't have a phono input, you're going to have to go out and get a phono pre-amp and connect it between the turntable and the amp.
Best of luck!
Feb 26, 2011 | Numark TT1650 Turntable
Im new with the use of the record player since im tired of MP3's. i bought a Numark TTusb turntable connected everything, but the sound is low. i have to crank the volume to the max, and only get low...
A turntable use a magnetic cartridge and its output is only 5 to 10 millivolts.A moving coil cartridge is even lower,.2 to .5 millivolts(thats 1/2000 of a volt)in contrast, a mp3 puts out a 300 to 900 mv signal..so does a CD player. Your turntable does not have enough signal.You need to get an amplifier that has a phono input. Years ago,radio shack used to sell phono preamps that could plug into a tape or cd input.The other option is to buy a used mixer that has a phono input.The mixer output can drive the cd input easily,as the max output from a mixer is 1.5 volts to 2 volts.
Dec 30, 2010 | Numark ttUSB Turntable
How do I get my sound from my Numark TT1625 to play through my DVD/CD speakers?
You need a magnetic cartridge preamp. You then plug your turntable into it and the box into the CD/aux imput of your amp.
May 21, 2010 | Numark TT1650 Turntable
Hi there! i just bought a numark tt1650 and an ortofon arkiv cartridge, connected it properly to my old technics a700mk2 amplifier (phono, grounding and all that) but it still has a buzzing problem...
Try connecting the turntable to one of the other inputs like CD / tuner etc and see if the buzzing disappears. if so then your turntable has a built-in pre-amp so it can be connected to any input except 'phono' as this would obviously be used for turntables without a pre-amp.
a lot of modern turntables now have built-in pre-amps to compensate for certain amps and receivers made without a phono input and can now be connected just like a CD player, tuner etc.
hope this helps.
May 05, 2010 | Numark TT1650 Turntable
Tone Arm acting as arial
A metal tone arm has a ground wire that connects it to the back of the stereo via the Turntable chassis. If this wire is broken (inside the deck of the turntable) or the ground to the stereo is not done, you can have this issue. No, the ground through the audio connectors is not sufficient.
Mar 20, 2010 | Numark TT1650 Turntable
Hi,i need a mains transformer tt1650 Ron,Cheltenham,England.
that turntable wasnt made in the usa . your best bet is to google the same info.
ask where to buy that transformer etc. good luck
Aug 15, 2009 | Numark TT1650 Turntable
Did you buy the gear new? If not, the issue might be with the meter. Also, sometimes the signal isn't loud enough to engage the meter, so try cranking up the Trim and Volume (Master & Line), of course, make sure the volume on your amp is down, so you don't blow anything.
Good luck.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 04, 2009 | Technics SL-1210 Turntable
Cant connect my Numark PT-01 to my Numark DM950 mixer
What do you mean it didn't work? What happened? Are you getting no sound, did the plugs not fit? Please be more specific.
If you are not getting any sound, make sure you connected to the LINE input of the mixer - the PT01 has Line Level outputs, so you CANNOT connect it to the Phono input, as the signal will be too hot for the mixer - so make sure it is in the LINE INPUT. Also make sure the toggle switch on the mixer is set to LINE. There is nothing else to this set up, raise volumes, and that's it. It's very simple.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Jan 08, 2009 | Audio Players & Recorders
Numark TT1650 Turntable Logo
219 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
