Question about Samsung MW5351G Microwave Oven
When new microwave is turned on, the lights in the kitchen dim.
Just brought a 1000w microwave and everytime it is turned on the lights in the kitchen area and small dining area dim. After the microwave goes off, the lights become bright once again. What might be the problem?
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Does your microwave have its own designated circuit, or is it tied in with your lighting? If so, you may have some improper loading going on, which will cause lights to dim as the microwave consumes power while running.
  • Samsung Master
  • 9,098 Answers
Sounds like your microwave's outlet is on the same circuit with the lights.
High-current devices like microwave ovens should be on their own breaker if possible.
If the dimming is very slight, it may be okay.
If it's considerable, it may be a good idea to run a separate line to the microwave's outlet - especially if it starts blowing your breaker!
Posted on Feb 08, 2009
I can't get started with my new 32l microwave
Have you read the owner's manual that came with your new 32l microwave oven. It tells you how to program it.
Jun 16, 2017 | Microwave Ovens
Kenmore 1000w Not Heating Food Items
If it sounds like it is running and it lights up it is not the fuse. In my 24 years of service work I've found that the problem you are describing is cause by the failure of the magnitron ( The device that emits the microwave radiation). As your unit is a built in expensive unit I would look into replacing the magnitron. In cheap microwaves I just suggest replacement. If you need further assistance locating a replacement magnitron feel free to cotact me. It is a relatively easy part to replace. You just open the case and unplug it, unscrew it from the unit, and replace it with the new one. In most cases all you need is a philips head screwdriver and some patience. Anyway, I hope this helps you out in your decicion.
Jul 19, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
Dec 21, 2015 | Microwave Ovens
Light is dim
Why do my lights in my house dim when I use the Microwave or dryer ...
Jan 16, 2010 - I dont run a lot electricity. It seems that if I run something like themicrowave any lights that are on dim. Is something wrong here? I dont see why ... Light on microwave too dim to read -- can it be fixed? ' Yahoo ...
May 11, 2014
My lights dim when I turn on a powerful electrical device ...
Dec 31, 2007
Why causes all the lights to dim and then brighten repeatedly ...
Dec 28, 2006
More results from
Dimming Microwave Light - Breville Support
Apr 10, 2014 - Occasionally, when using power settings that are lower then the normal 100% cooking power, the light inside the microwave cavity may dim.
I have a new Sanyo EM-C877B microwave and following instructions in the manual 3.Microwave cooking or any cooking options I will select the Micro Power 1000W then press Start, turn the dial to choose a...
I suggest you revisit the instruction manual and ensure the new microwave is not performing as per instructions.
If that is so you should contact the supplier without delay.
Sep 08, 2017 | Sanyo EMC8787B Microwave Oven
Microwave power turns off after a few sec running incl oven power
I would suggest having whoever installed the new appliances come back and check out his work. There might be a poorly made electrical connection somewhere, and you might have a potential fire hazard.
You might also have gotten a lemon microwave oven. This happens sometimes. (Usually when I buy something.) Contact the store where you purchased it and ask if they have a service person who can check it, or just tell them what's happening and you want a replacement. They'll just return yours to the manufacturer.
In any case, have this checked out to be sure your wiring isn't at fault.
Mar 08, 2010 | Microwave Ovens
Microwave will no longer heat. Model #MA-1000W
So we can help you, please post a NEW question, and please include your model number MA-1000Was well as the answers to these questions:
When you try to microwave are the inside light, internal cooling fan and turntable all working?
Is there any unusual noise or is it louder or quieter than normal?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Oct 11, 2009 | Goldstar MA-1011 Microwave Oven
Flickering lights
good day,
hope this link below will solve your problem.
kitchen appliances
Sep 24, 2009 | Samsung MW5351G Microwave Oven
My Sanyo 1000W microwave is shooting sparks!!!
you need to replace the cavity cover "the cardboard like",the antenna bearing set "the gun barrel like" and the gear motor.If the "gun barrel like" is stuck up because the gear motor is not rotating excessive heat will occur inside the microwave thus burning the cavity cover.
Mar 20, 2009 | Sanyo EM-A5200SW Microwave Oven
Microwave Ovens Logo
927 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
