Question about Belkin (F5D7230-4) Router (587009)
No wireless connection :(
The Belkin Wireless G router works as a second modem (middleman) for my laptop but it won't work as a wireless router. All the little lights light up when I first connect but after a few minutes the "internet" light goes out and I can't figure out why.
  • 73 Answers
If you have your broadband configuration info written down, you could try resetting your router to the factory default settings and then re-configure it.
For most broadband connections, the default settings will work OK, but you should configure your router with a secure administrator password and wireless key.
The user manual for the router as well as configuration software can be found here:
http://www.belkin.com/support/product/?lid=en&pid=F5D7230-4&scid=221
Posted on Feb 06, 2009
Tip
Wireless Network Reset - Belkin
If you are unable to connect your laptop wireless to your <b>Belkin</b> wireless access point/router, the <b>easiest</b> and<b> fastest</b> way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.<br /><br /><br /><br /><b>Reset your router:</b><b><br /></b><br /> <ul> <li><b>Unplug</b> your <i>DSL/Cable</i> <b>modem</b> from power (not your access point/router) Leave this unplugged for now</li></ul><br /><br />Next <ul> <li>On the rear of your<b> Belkin router </b>you will find a small RESET button</li> <li>With the power still on the router,<b> Press</b> and<b> hold</b> (with a pin/pen tip) the <b>RESET</b> button for 10 seconds.</li> <li><b>Release</b> the RESET button a wait 15 seconds for the router to reboot</li></ul><br /><br />almost done.... <ul> <li><b>Unplug</b> your <b>Belkin</b> router from power</li> <li><b>Plug</b> your DSL/Cable <b>modem</b> back in to <b>power</b></li> <li><b>Wait </b>1 minute for the modem to boot up</li> <li>Be sure the ethernet (cat5) cable from your <i>modem</i> is securely plugged into the <b>WAN port</b> on the back of your Linksys <i>router.</i> This is usually labeled <i>WAN</i> or<i> Internet</i> above the jack</li> <li><b>Plug</b> your Belkin <b>router</b> back into power.</li></ul><br /><br />You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.<br /><br /><b><br /></b><i><b><br /></b></i><i><br /></i>Magoo
on Mar 13, 2011 | Computers & Internet
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
Connect my office computer to belkin wireless
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Feb 06, 2010 | Belkin (F5D7230-4) Router (587009)
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin wireless problem
If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
Aug 12, 2008 | Belkin (F5D9230-4) Wireless Router...
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7230-4) Router (587009) Logo
199 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
