Question about Logitech Cordless Mouse
I dont deem to have a middle mouse button
I dont seem t have a middle mouse control, the wheel works fine but nothing happens where there should be a middle mouse I can't seem to find out where I can change settings in windows vista so that I can enable my USB wireless mouse to middle click.  I have a laptop and can only find controls for the pad.
  • er09 Feb 04, 2009
    So, yeah, I was in classic view and went to mouse settings...the only thing I could find from there is information about the pad...I have since downloaded the latest version of Logitech's SetPoint, set the middle button to middle click, and am still unable to use the function...it did not require a restart, but maybe I'll give that a try anyway. Thanks for offering what you can.
  • 2,404 Answers
I believe if you go into the control panel, click on classic view on the left hand side of the screen, then click on the Mouse icon, you should be able to configure the mouse from there. If you can't then download the specific software for your USB mouse and you should be able to do it then for sure.
Posted on Feb 04, 2009
4 wheel drive button dont work
Could be the switch or control board
May 17, 2014 | 2002 Jaguar X-Type
Left click will not work
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7 then click on the >> all control panel items scroll to mouse in the buttons tab you will see the defaults left button right button and middle wheel click you might have to set the left click button again in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar . Or disconnect the mouse from your computer restart.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Hope this helps.
Jan 23, 2013 | Toshiba Satellite C655-S5123
Hi I have a KM80545 (mikomi) Argos value range wireless keyboard. The keyboard has been working fine until the batteries needed changing. Hence I have changed batteries and the keyboard doesn't seem to be...
I had the exact same problem but with my mouse! the keyboard worked so it obviously was a problem related to connecting to the router (USB)
I later discovered that the LED light on the USB is a button, so click that and click the little circular button on the back of your mouse, then be patient, the mouse should reconnect!
Apr 24, 2010 | KME PC Keyboard and Mouse
The middle wheel does not work as a pan option in my AutoCAD 2002 program . Run in vista. Dell mouse SN-H100009B
In your control panel in windows under your mouse options. Make sure that you have the middle options button selected. It could be windows vista has not select it.
Dec 04, 2009 | Dell U0636 Mouse
The wheel and 2 side buttons on the mouse dont work
Try a different mouse to see if the one your using is faulty Check in mouse properties that windows saysit's working properly .If it's a usb mouse check by using another usb device that the usb sockets are working.
Aug 02, 2009 | Computers & Internet
Logitech v220 cordless mouse - worked fine for 6 mths - recently changed battery. worked fine. today, would not move cursor when on a white / light surface (although it has previously just fine). It...
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
Jun 17, 2009 | Logitech Cordless Mouse
I have a wireless mouse. It is a Dell. has light...
Try to re-connect the mouse and keyboard using the connect buttons on the keyboard/mouse and the receiver to the computer.
Mar 01, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Not working
If there any lights on the mouse when you put new batteries in the mouse? If yes then you can still fix it. On the usb controller of you mouse it will have a button on it. Press that button first and then press the button under the mouse. Repeat a few times and see if mouse responses. Then if nothing happens, unplug the usb controller and place it into another port. Repeat the above process and see what happens. Should work fine.
Aug 09, 2008 | BenQ M310 Wireless Mini Optical Mouse
Hi Thanks for the advice on fixing my problem. I solved it by googling the problem. The solution was to go to the 'set point' feature in Logitech and change the 'zoom' setting to 'other', then select 'middle mouse'. THAT WORKED. I like the laser mouse it has a real nice feel to it., and am super happy now i have a middle mouse button to perform commands in my modelling program......................regards julie
Mar 16, 2008 | Logitech MX1000 Laser Cordless...
Middle Button does not work
my MX1000 too, but wierd stuff is that is responsable to tripple middle click ...
Nov 14, 2007 | Logitech MX1000 Laser Cordless...
Logitech Cordless Mouse Logo
77 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
