Question about Toshiba Satellite A105 Notebook
New battery charges but won't work
My toshiba sattelite has a new battery. It shows fully charged and when I take it out it shows it's missing. The battery light is on, but when I pull out the power cord, the battery doesn't power the unit.
  • mooreclan5 Feb 04, 2009
    is this something I can fix, or does it need taken in?
  • 1,602 Answers
YOU HAVE A FUALT CONNECTION TO THE BATTARY AND NOTEBOOK POWER SUPPLY AND MAY BE A WIRE COME LOOSE INSIDE THE LABTOP
ROD
Posted on Feb 04, 2009
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
Battery will not charge
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often.
There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above.
so if your battery can not full charge,this mean you need change a new battery for your laptop
http://www.aulaptopbattery.com.au
Oct 05, 2012 | Computers & Internet
Lap top is not charging
Sep 16, 2012 | HP Computers & Internet
My Toshiba Satellite A215 - S7422 won't charge and
a problem with the battery or a charger.
Jul 17, 2012 | Computers & Internet
Agptek replacement battery not working
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Nov 20, 2011 | Toshiba Satellite M115-S1061 Notebook
My battery charges but only lasts about 20 minutes once it says it is fully charged. Just purchsed a new battery thinking it was old (laptop is about 3 years old) and the same thing happens.
From what you describe and assuming the new battery was "new", I'd say you have an internal short which is draining the battery over a short period of time. I'd also investigate the accuracy of the battery charge indicator. Download this free utility which will give you a more accurate picture of your battery:
http://www.mioplanet.com/products/batterymeter/
I'm assuming you gave the battery a "commissioning charge" when you bought and used it?
If not, this is something you should do with all new LI batteries. This bit is reproduced from a website that sells batteries for the Toshiba satellite series:
"2. The new Toshiba Satellite a205-s4777 battery pack needs to be circled (fully discharged and recharged) three to five times to reach its optimum performance.
3. Toshiba Satellite a205-s4777 battery will undergo self-discharging when left unused for a long period of time. Thus, it should always be stored in a fully charged state and kept in a cool, dry and clean place.
4. It is normal if the new Toshiba Satellite a205-s4777 battery gets warm when being charged or used. However, please pay special attention if the battery pack becomes excessively hot. This may indicate there is a problem with the charging circuit of the electronic device. Please consult a qualified technician if necessary.
5. To maintain the optimum performance of Toshiba Satellite a205-s4777 battery pack, it is highly recommended to circle (fully discharging and recharging) it at least once a month.
6. New batteries are hard to be charged. Sometimes, your electronic device may indicate a fully charged condition about 10 to 15 minutes when Toshiba Satellite a205-s4777 battery pack is being charged for the first time. When this happens, remove the battery pack and let it cool down for about 10 to 15 minutes then repeat the charging procedure. Sometimes, the new Satellite a205-s4777 battery will suddenly refuse to be charged. If this happens, a suggested solution is trying to remove the battery from the device and insert it again. "
Jul 21, 2011 | Toshiba Satellite A205-S4777 Notebook
The toshiba laptop a505 S6980 will not charge the battery when the AC is plugged in and dies immediately if unplugged . Meters shows 0% available (plugged in), charging. But it is not really charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 20, 2011 | Toshiba Satellite L500-ST2521 Laptop AC...
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Purchased new battery, now NOTEBOOK won't work on battery after full charge
Better you first charge the battery for 16 to 17 hours and recheck the same. If problem persists, change the battery from where you bought it. that battery is faulty. And yes there is no need to install the battery from device manager. Just open the battery compartment and replace the battery with new one.
Feb 13, 2008 | Toshiba Satellite A45-S250 Notebook
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Toshiba Satellite A105 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
