Usually a disc with audio files is not encoded with MP3's, but, rather, audio files. You can check this by manually opening the disc (right click on the player when the disc is in it), and looking at the files. If you only see marker (files of a few kilobits) in "MP3" format, then the disc needs to be "ripped" into MP3 format.
The ratio for audio to MP3 is 10 :1--this means a CD of 700 MB size with 10 tracks will become an MP3 collection of 10 tracks approximately 70 MB in size (this is a standard 128kbps audio quality CD) If the encoding is less (64 or 32kbps), the size of the resulting MP3 is smaller.
The hands down best ripping software to convert your audio CD to MP3's is called Goldwave. Although Nero and Winamp have functionality on a limited basis for this task, Goldwave is a far superior software package to not only rip, but also edit your creations. Once you have installed Goldwave, you use the OPEN CD button to read your files---then save them to your hard drive (in what CODEC or quality you want---MP3, Apple AIF, OggVorbis, etc.etc
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier
That Opal's Easy Rip Software does not recognize Real Video format naturally. You may have to download a free program called Riva FLV Encoder to convert the Real Video files to AVI format. Once they are in AVI format, the Easy Rip software will recognize the file and convert them to your player. If you have lost your installation CD, you can get the Easy Rip software from: www.rcaopal.com
The solution for a Code 10 error is always to unplug the mp3 player from the computer, uninstall all software related to the hardware (in this case, uninstall all Sansa-related software), restart your computer, reinstall all software from the installation CD (you can also get it from Sandisk's website if you have lost the CD), restart the computer one more time, and THEN replug the mp3 player.
There MIGHT be an easier way - you can try running the Sansa Recovery Tool - but Code 10 is almost universally an uninstall/reinstall situation.
. Connect your ML648B to your computer with Windows XP or later. 2. By default your computer will recognize ML648B as GPX MTP Device. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as MTP Device.) 3. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.(Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as USB device.) 4. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop. 5. Double click & open Tools, and run Setup.exe to start installing Video Conversion Software tool. 6. Select defaults options and finish the installation by clicking on Close or Finish. 7. If asked, click on Continue Anyway on Windows XP or Install this driver software anyway on Windows Vista.
<!--[if !supportLineBreakNewLine]--> <!--[endif]-->
1. Connect your ML648B to your computer with Windows XP or later. 2. By default your computer will recognize ML648B as GPX MTP Device. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as MTP Device.) 3. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.(Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as USB device.) 4. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop. 5. Double click & open Tools, and run Setup.exe to start installing Video Conversion Software tool. 6. Select defaults options and finish the installation by clicking on Close or Finish. 7. If asked, click on Continue Anyway on Windows XP or Install this driver software anyway on Windows Vista.
To check if the mp3 is recognized by the computer go to device manager in the compuer properties.
Go to device manager go to hardware tab and search for new hardware, if you see a question mark in the usb port it means that the computer cant recognize it and you may need a driver. Some mp3 have cd installer of its software. Install it in your computer. and try if the computer can recognize it.
also check if your usb port is working properly...
Can i download the Software for my PhilipsGoGear MP3/512MB for free on here? Please!! I lost the CD installation that came with it. Plz, Get back at me!
Email no.1: [email protected]
Email no.2: [email protected]
You must use the Media Convertor software that came with the GoGear installation CD to convert all video files into a format that the GoGear recognizes. If you lost the CD or manual, go to the Philips website - they have both available for download. Under software and drivers, select "Media converter Software"; under documentation, click "User's Manauls" -Tha Mp3 Doctor
Try plugging your USB cable (attached to your player) into the computer before you turn the computer on and boot up . . . I had this same problem with a flash drive that the computer would not recognize if I plugged it into the computer while the computer was already on.
how do u put pix n movies on it?
