Question about NorStar M7310 Corded Phone
How do I change the default line on our phones
We only use 3 of our 4 lines so when we had the extra line turned off our other phones now automatically default to that line and it is very aggravating having to every time you pick up your phone to call someone having to first push one of the other lines so you can get a dial tone and dial your call.
Restore the factory settings of your mobile byentering the security code of mobile.
Posted on Feb 04, 2009
Problem with my panasonic kx tda 200
1) clean the contacts from the board, with c.cleaner and tight any plug
2) test the wires from the extra line for open, break or defective.
3) test using another phone
4) use the user manual in troubleshooting section and fix it.
God bless you
Oct 09, 2012 | Lands Phones
How many phones can we use at a time in our office? We have 3 currently and six jacks. Can we add more phones?
I'm guessing yes, but it depends on what system it's plugged into. In the U.S. Panasonic sytems come in 308, 616 and 824 models in the TA series, but only 4x4 default in the TAW-848.
These would be the systems most common for the 7731 phone.
So, when you locate the cabinet, if it's a TA-624/824, then you'll see a board with 11 modular jacks, 3 for lines and 8 for extensions. In the 848, it will be 4 lines and 4 extensions if it has not been expanded. If it's an old KXT30810/61610, you'll see the extra jacks on the sytem.
Carl
Sep 21, 2010 | Panasonic KX-T7731 Corded Phone
BIS-10 Phone - How to change default line
If you have a "squared" system (each line assigned to a different button), just press a different line button. To change the order of the lines, slide the "T/P" switch to "P" and press the line buttons in the order you want to use them (ie: Line 4, Line 3, Line 2, Line 1).
If your lines are "pooled" you just get the next available line from the pool - no choosing which line you get.
Hope this helps.
Jun 21, 2010 | AT&T Merlin BIS 10 Phone
KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
4. Press AUTO DIAL / STORE to save your changes.
5. Press PROGRAM to exit program mode and you are done.
Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
You need to go into lines/trunks and change the line typ from unsupervised to supervised so this will stop. How though?
Changing programming on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) - display should read "lines"
4.- Press "SHOW" (top right arrow)- display should ask for a line number
5.- enter in the line number you wish to change the supervision on in a 3 digit format. ex. line 1 = 001
6.- press the show key (top right arrow)
7.- The display should say Trunk/line data
8.- Press "show"(top right arrow) - display should read "trunk type"
9.- Press the next key (bottom right arrow) 7 times"
10.- the display should say "trunk mode: unspr"
11.- Press softkey "CHANGE" to "super"
repeat steps 5 - 11 for the remainder of the lines Press the Rls key when finished
Nov 03, 2009 | NorStar M7324 Telephone
I have an MLS-12D phone that needs odd programming - picking up the handset to call out should default to our main line (Line 1) (right now it defaults to a different line ? Line 2). Also, it should NOT be...
Well, there is a lot of things to do.
First, here is how to do Auto Line Select.
Is it only 1 phone that should be making outgoing calls? Or is it not place any outgoing calls ONLY on line 3?
Jul 30, 2009 | AT&T Lucent MLS-12D Phone
External Speed-Dial Default Lines
You have to remove line 4 from appearing on all of your phones.
Login to your system with Feature ** config.
Go to extensions find lines configuration, and set Line004 not in service on EACH extension.
May 21, 2009 | NorStar Meridian M7310 Phone
Co lines dropping calls on occasion. Sometimes several times a da
Wow, you're running out of hardware options, so time to try the software. Turn your trunks into Unsupervised and see if it changes the operation. You'll probably lose conferencing. The other thing you might try is the timer, but by default it's 460 miliseconds and the next one is 600. If you don't have DS trunks, the Discon timer won't affect anything.
Carl
Mar 25, 2009 | Lands Phones
Programing Ayava partner - 18d Phone
From extension 10 or 11
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
then the order you want the lines to get picked up (if you want to grab line 4 then 3 then 2 then 1, upon going offhook, press "** line 4 line 3 line 2 line 1)
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
Nov 25, 2008 | Avaya Corded Phone avaparp18d
NorStar M7310 Corded Phone Logo
187 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
