Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Pages aren't being sent properly
I have a Brothers intellifax 775. Every time I go to send my faxes, my fax machine feeds the papers through too quickly. I could send through 5 pages and my fax machine still says send pg 1. It just feeds the pages through one directly behind the other w/ no pause to recognize that there are even more pages. Not to mention, the last page's end gets stuck and then the confirmation page says poor line condition. Please help me! I have tried everything I could think of to solve this problem. I work in a doctor's office and we can't send the faxes that we need to until the fax machine is fixed. Thanks!
  • hmsowers78 Feb 04, 2009
    What do I clean the rollers w/?
  • 1,602 Answers
BUILD UP OF INK ON THE POLLERS AND SOME MACHINE HAVE WHERE YOU CAN SETUP INTERMITTING TIME DELAY INBETWEEN FAXING LETTING THE MACHINE COOL DOWN BETWEEN FAXING AND I HAVE ANOTHER PROGRAM THAT MAY HELP IN THIS MATTER CALL GREENPRINT WORLD.COM
ROD
Posted on Feb 04, 2009
  • ROD GANDY Feb 04, 2009
    HOW MANY FAXS YOU DO A DAY AND HOW OLD IS THE FAX MACHINE.
    YOU MAY WANT TO GO ONLINE TO THE MANUFACTURE WEB SITE AND SEE IF THERE IS ANY RECALL ON THAT PRODUCT OR FAQ AREA OR EVEN A FORUM WITH PEOPLE LIKE ME MAY TRY TO HELP YOU THROUGHT THIS PROBLEM.
    IF IT IS STILL SAYING ITS ON PAGE ONE THAN THE MACHINE HAS NOT CONNECT TO THAT CUSTOME IT HAS NO WHERE TO SEND ALL THAT DATA, IT MAY STORE IT IN A BUFFER OR MEMORY STICK BUT MOST FAX SYSTEMS DONT HAVE ALOT OF MEMORY TO STORE THE DATA, MAYBE THE FAX IS NOT SENDING ANYTHING CHECK THE PINE WHEN YOU ARE HAVING THESE PROBLEMS ARE YOU USING A COMPUTER, THE FIREWALL MAY BE STOPPING YOU FROM DOING YOU FAXING NOT THE COMPUTER,
    GO INTO THE CONTROL PANAL IN THE COMPUTER, CHECK THE DEVICE MANAGER AND THE NETWORKING AND SHARING OPTIONS, THAN THE PRINTER FOLDER SEE IF THE FAX IS IN THERE AND IF IT IS GO INTO PROPERTIES,,
    THAN CLICK ON FAX , LOOK IN THE GENERAL SECTION, PORTS SECTION THAN IN MAINTANCE SECTION
    I KNOW ITS ALOT OF WORK FOR YOU BETTER YOU THAN A NETWORK PROFESSIONAL THAT 100.00 HOUR PLUS DOING WHAT IM TELL OR TRYING TO HELP YOU FOR FREE
    IF YOU NEED MORE HELP CONTACT ME ANY TIME
    ROD GANDY SR
    CANDYMANGANDY
    GO INTO CONTROL PANAL, GOTO PRINTER, GOTO FILE,
    THAN GO TO SERVVER PROPERTIES OR SHARING FOLDER OR EVEN PROPERTIES FILE
    SEE IF ANYTHING CAN HELP YOU.
    ROD
Multiple pages
Actually, when you get more than one paper feeding in at a time, it is almost always the separation pad being worn down. Go here to buy a new sep. pad and tell them Ken from National Cartridge Co. sent you there!
http://www.precisionroller.com/paper-feed-components-for-brother-intellifax-5750e/details_9248.html
May 28, 2010 | Brother IntelliFAX 5750e Laser Fax
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
White space in middle of faxes sent or received
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
Jun 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother Inteifax 775 will not send fax
change the mode from TAD to F/T by pressing mode button on panel
Thanks
May 19, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Not pausing to acknowledge
Open up the feeder to see if a piece of paper is holding a switch actuator down.
Feb 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
2 inch vertical solid band on right side when making a copy
There is probably dirt or ink on the scanner glass, this would affect both copying and sending faxes.
Here is a link to the manual and a description on page 74 showing how to clean the glass.
http://www.brother.ca/en/products/pdf/manuals/FAX1270-UG.pdf
Jan 21, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Paper jamming in fax
look for a piece of paper in the paper path. clean all paper feed rollers
Jun 11, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
BROTHER FAX/TELEPONE T76
Unplug and plug back in see if that gets rid of the check paper pls open top cover. Also make sure the confirmation is set. Transmission report on
Oct 31, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
113 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
