Question about GE 106591 Coffee Maker
Stops brewing The coffee maker stops brewing after 6 cups, leaves the other six cups of water in the resovoir. If it turn it off, then on again, it will brew, but not the remaining 6 cups. just one or two. Coffee maker is only a few months old.
  • Anonymous Feb 12, 2009
    I have the same problem and have had the maker for about a couple of months too. Did you get any resolution?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
It's under warranty, return it to the manufacturer for warranty service.
Posted on Mar 02, 2009
Keurig troubleshooting
This problem is addressed on the Keurig website:
http://www.keurigtroubleshooting.com/Keurig-Coffee-Brewer-Problems.html
Scroll down to Partial Cup Brewing
Jan 05, 2014 | Coffee Makers & Espresso Machines
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
My Keurig (one year old) does not brew a full cup (I have it set for the largest cup setting) and it only brews approx 4 oz. then stops.?
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Oct 03, 2010 | Keurig B100 Coffee Maker
My Pot wont brew
mcdevito75 here, Your Mr. Coffee may need cleaning, here"s how, Fill the resovoir with white vinegar, cycle thru the machine 3 times, half way thru the 3rd time stop 1/2 way thru and turn off machine for 30 minutes, then recycle. After that rinse your Mr, Coffeee by cycleing thru fresh water each cycle takes another resovoir of fresh water to get rid of the vinegar. If this is not the problem, maybe the pump is shot. Contact Mr. Coffee by phone or online at Mr. Coffee.com or replace the machine.
Jul 09, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
GE Model 169164 stops brewing
A couple of people on here mentioned he filtration system, or charcoal filter that is in the
water resovoir as being problematic. We removed it. This morning the pot brewed entirely.
Not sure how that all is inter-connected, but it worked.
Feb 04, 2009 | GE 106591 Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
My cuisinart coffee maker just recently started not using all the water I've poured into the reserve. Up 'til today it was leaving the last two cups in the reserve, but today, out of the six cups I poured...
This is a real problem with these coffee makers, and there's not much that can be done. However, there is a work around: before brewing, just hit the button to brew 1-4 cups. It'll still brew a whole pot, it'll use all the water, the coffee will taste no different, and you can still program it however you'd like. Cheers!
Sep 21, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Won't Brew. No water from resovoir to fileter.
To clean your coffeemaker:
1) Pour four cups of undiluted white household
vinegar into the water reservoir.
2) Place a paper filter into the removable filter
basket and close the brew basket lid.
3) Place the empty decanter on the
warming plate.
Make sure to accurately place the
decanter on the warming plate
to avoid the possibility of overflow.
4) Start the brew cycle:
a. Turn the switch to On. Then, press the
brew button to begin the brew cycle.
b. When the water has flowed into the
decanter, turn the coffeemaker Off
and let the water stand for 30 minutes.
c. Repeat Steps 1 – 4b.
Have a nice day!
tc
Apr 16, 2008 | Mr. Coffee ARX23 / ARX20 Coffee Maker
Stops brewing, have to turn it off then on again
This problem seems to happen quite often. If the symptoms are similar to those posted in this string try the solution posted at the bottom. It seems to fix it most of the time.
Apr 14, 2008 | Black & Decker Spacemaker 10-Cup Coffee...
GE 106591 Coffee Maker Logo
156 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Eric Taylor
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
